#225 | |
However i figure from your posts that your wide sticky tires had suffient grip on the road that the clutch let go before the tyres. ie the clutch burning smell. You will get a better launch letting the clutch out at a controlled rate rarther than just dropping it especially wiyh wide sticky tyres and a stock clutch. else all you will achieve is stuffing your stock clutch. |
| The Following User Says Thank You to steve99 For This Useful Post: | KonTheory (09-20-2014) |
#226 | |
Drives: SWP BRZ
#227 |
| The Following User Says Thank You to steve99 For This Useful Post: | zc06_kisstherain (09-20-2014) |
#228 | |
Drives: SWP BRZ
I only use shell 93. I will try sunoco when gas gets near empty. |
#229 |
Drives: SWP BRZ
@steve99
should i run 91 tune instead of 93? if it's not too serious, i will just leave it with 93 tune i have. i havent tried different brand of gas yet |
#230 | |
The IAM drop appeared to be caused by low rpm high load knock again not serious but you would have to manually edit table to correct that. |
#231 |
Drives: GTS86
I have loaded the new 2.06 files to my tablet, at the same time I have changed the exhaust to catted header Equal length, no second cat, 2.5 inch system.
I wish to know what is the best tune for me on 100 E10 Octane fuel here in Australia Should I be on Stage 2 or remain on Stage 1. Thank you Robert |
#232 | |
Drives: Toyota 86 GTS
It's VERY important you run this first as a baseline to make sure you have no leaks, no fuel problems (P100 is mixed on site), etc. Then you can try more aggressive tunes. Don't be disappointed if they don't work. Stg2 EL 93 - cam timing may be too aggressive for catted header Stg2 EL 91 - try Stg2 EL 91 if Stg2 EL 93 KNOCKS OVER 6000rpm Stg1 93 - try Stg1 93 if Stg2 EL 93 KNOCKS BELOW 6000rpm OR if Stg2 EL 91 knocks anywhere Stg1 91 - fall back to Stg1 91 if Stg1 93 KNOCKS OVER 6000rpm Message me and we'll add you to the Aussie OFT fb user group. Finally, if you have to ask which is the best tune, the answer is Stg1 91 i.e. the OTS tune. |
| The Following User Says Thank You to Wayno For This Useful Post: | Annahra (09-22-2014) |
#233 |
On another note I have a knock free log for the first time.
OTS 91AKI map United P100 Apexi filter Stock exhaust except UEL header and op. http://datazap.me/u/wayne/206-stg2-u...ta=1-7-9-11-12 |
| The Following User Says Thank You to Wayno For This Useful Post: | steve99 (09-22-2014) |
#234 | |
Drives: 2013 FRS
#235 |
Drives: Sonic Blue 2014 GT86
keen to join too
#236 |
Drives: GTS86
Thanks Wayno.... comments noted.
#237 | |
Drives: 2012 Toyota 86
#238 |
| OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] | Shiv@Openflash | Forced Induction | 226 | 03-12-2019 10:26 PM |
| iOS 8 beta 1 not working on BRZ USB | Kids Heart | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 04-13-2015 09:17 PM |
| v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT | Shiv@Openflash | Forced Induction | 3 | 07-26-2014 01:23 PM |
| OFT 1.42 vs 1.5x Beta Who notices a Difference? | Cross | Software Tuning | 11 | 03-21-2014 04:17 PM |
| Anyone want to beta-test some door speaker spacers? | phenryiv1 | Electronics | Audio | NAV | Infotainment | 63 | 08-20-2012 10:02 PM |
