86WORX
Old 09-15-2014, 01:35 PM   #169
steve99
Originally Posted by GT86meMR2 View Post
So the only changes in the US93 Tune compared to the EU Tune is the Ignition timing - advance Base timing B table? so just copying that table in the EU tune should do it?
Yes the only difference between 91/93 tunes is 'base timing B" table , so just edit or copy it from the appropriate 93 tune. Just do a compare between the usa 91/93 tunes just to be sure.
GT86meMR2 (09-15-2014)
Old 09-15-2014, 01:47 PM   #170
steve99
Originally Posted by lucid215 View Post
only thing im concerned about is the high (13) afr before 4300 rpms. is that a issue?
Open your tune file and then look at the "Primary Open Loop Fuel" Table the AFR should follow the values in that table under load in open loop.
Probably where you have to average/adjust the values from the open loop and closed loop maf scaling. You could tweek the maf scaling a bit if your kean.
lucid215 (09-15-2014)
Old 09-15-2014, 01:52 PM   #171
lucid215
ill have to look at that when i get home
lucid215 is offline   Reply With Quote
Old 09-15-2014, 04:36 PM   #172
benlaz88
Drives: 2013 Asphalt FRS
Im new to all this tuning and logging. Can anyone tell me is this good or not? I'm running stage on 1 oct91. The mod i have are AEM ETI intake, Motiv Test pipe, 2.5 perrin catback res. I would appreciated. It will be long learning process to understand this. =)
http://www.datazap.me/u/benlaz88/1-run?log=0&data=1
benlaz88 is offline   Reply With Quote
Old 09-15-2014, 04:40 PM   #173
GT86meMR2
GT86meMR2's Avatar
Drives: MR Spyder/GT86
When I compare images there seem to be 3 differences between the 93 and 91US map
Base Timing B
Idle speed stability B
Ignition Timing Compensation MAP Delta (Clutch Depressed)
However when I compare the EU UEL map with the US 93 UEL map I get Equal tables 70 Changed tables 219 and missing tables 119
I'm new to this stuff but is there really that much of a difference between the EU and US map or am I doing something wrong?
GT86
Current Mods: Ace Header with 350 OP-Berk Frontpipe-Miltek Resonated Catback-OFT-k&n drop in filter
GT86meMR2 is offline   Reply With Quote
Old 09-15-2014, 04:45 PM   #174
steve99
Base Timing B
As you found comparing ROM's from different series can yeild weird results as the def files are different and may contain extra or missing tables not defined in the other ROM series.
Its just the base timing B you need just copy the difference to your rom it will just be the higher rpm timing. about 1 degree difference from memory.
Old 09-15-2014, 04:54 PM   #175
GT86meMR2
GT86meMR2's Avatar
Yeah just noticed comparing a different UEL 93US Rom to the EU room only had 2 difference's :p it's even more complicated than I thought :p anyway thanks for the help
GT86
Old 09-15-2014, 04:56 PM   #176
JB86'd
JB86'd's Avatar
Drives: JAWS
Read @steve99 's OFT tutorials and tips in his signature and I promise you will learn a LOT about logging and what's normal. For starters, turn off VVT intake and exhaust and log FLKC and maybe IAT instead.
The Following User Says Thank You to JB86'd For This Useful Post:
benlaz88 (09-15-2014)
Old 09-15-2014, 05:42 PM   #177
Efferalgan
Drives: Toyota GT 86
Originally Posted by Shiv@Openflash View Post
I don't see anything obviously wrong with the file. Please email me at shiv@openflashperformance.com and we can troubleshoot
Installed OpenFlash Manager on a different PC, updated the OFT firmware and everything went smoothly! Sorry for bothering and thanks again for the excellent work done! Will be testing v2.06 tomorrow
Efferalgan is offline   Reply With Quote
The Following User Says Thank You to Efferalgan For This Useful Post:
Shiv@Openflash (09-15-2014)
Old 09-15-2014, 07:36 PM   #178
tmichel
tmichel's Avatar
Drives: Sonic Blue 2014 GT86
Loaded up all the new goodies but haven't been for a real run in the car yet but just want to say thanks to the team at OFT and Steve99 for all the hard work and helpful advice and how freely they share their knowledge.
tmichel is offline   Reply With Quote
The Following 3 Users Say Thank You to tmichel For This Useful Post:
OnkelC (09-16-2014), Shiv@Openflash (09-16-2014), steve99 (09-15-2014)
Old 09-16-2014, 02:55 PM   #179
355rockit
Drives: Sci FR-S, Fer F355, Toy Highlander
v2.06 Stage 2 UEL tune Idle Dip issue
I loaded up the v2.06 Stage 2 UEL 91 octane this past weekend. I've been noticing that the idle dip when AC is on has returned. This is issue wasn't present in the previous B01C tunes since it was based on the stock ROM that fixed the idle dip. Anyone else seeing this?
355rockit is offline   Reply With Quote
Old 09-16-2014, 03:10 PM   #180
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
The B01C tunes are still based on B01C software so all the idle stability fixes are still there. But after each ECU, there could be several days of ECU learning required in order for idle stability to be at 10/10ths.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
355rockit (09-17-2014)
Old 09-16-2014, 03:53 PM   #181
OnkelC
OnkelC's Avatar
Drives: 2017 Fiesta ST
@shiv, is the toyXXX.dev file no longer included in the download?
OnkelC is offline   Reply With Quote
Old 09-16-2014, 05:35 PM   #182
Shiv@Openflash
Drives: 2013 FRS
It wasn't included because the .bin files are all available. No sense in loading a .dev file when you have access to the .bin files
OnkelC (09-16-2014)
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] Shiv@Openflash Forced Induction 226 03-12-2019 10:26 PM
iOS 8 beta 1 not working on BRZ USB Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 4 04-13-2015 09:17 PM
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT Shiv@Openflash Forced Induction 3 07-26-2014 01:23 PM
OFT 1.42 vs 1.5x Beta Who notices a Difference? Cross Software Tuning 11 03-21-2014 04:17 PM
Anyone want to beta-test some door speaker spacers? phenryiv1 Electronics | Audio | NAV | Infotainment 63 08-20-2012 10:02 PM
