#15 | |
Drives: 2022 BRZ Limited
may cause the premature tire wear on the outside edges too.. I would definitely consider at least 8.5" or 9" wide tires (slightly wider wheels are better for contact patch and sidewall stiffness) for flipping the tires on the wheels I would contact with the manufacturer and ask them I would also ask the ideal negative camber to run these tires with (for instance, Nitto recommends anywhere from -2.5 to -5 camber for their NT01 tires), many people flip the Nitto NT01s on the rim with no problem since inner and outer compounds are the same but of course you cannot use them in the rain due to the tread pattern when they're flipped like the symmetrical R comps .. I think it shouldn't be an issue but wouldn't hurt to ask them
#16 |
i'm sorry, what?
Drives: Canada
![]() is my question really that vague? I don't understand.
#17 |
cool meme, a bit overplayed but whatever
..and no your question is not vague at all, I wonder if my answer was really that vague since you found it "completely and wholly irrelevant stuff" I was just trying to help troubleshooting the issue that you have been having, that's all
#18 | |
i'm sorry, what?
Drives: Canada
appreciate the attempt but you touched on topics not all all relevant as there are no "issues" with the car that i'm trying to "fix" I merely wanted to know if the amount of tire left on the shoulders of the tire in this picture sufficient to last 2 more autocross events or would I be wise to flip them to the otherwise untouched side the fact that the tire is so worn is not an issue, I have been abusing them all summer the fact that they are 235 is not an issue, I chose to do this as a test the fact that I'm on a stock rim is not an issue, because I am in C-Stock and I cannot upgrade the width of my rim the fact that I'm on stock camber ( with bolts 1.3*) is not an issue, because I am in C-Stock and that's the most camber I can put in the car the tire's compound is same left to right, this is not an issue the tire is directional, but that too is not an issue in fact, these tires look like these after an approximate 75 runs + 6000 km commuting, which I think isn't bad at all. winter will be here in two months and these will go into hibernation until I burn them off next spring at a lapping day or something I simply want to maximize the grip I have left for the last two events, and I'm debating whether to pay the money for the flip and the consensus is that yes, I should flip them, which is what I will now do.
#19 | |
and both @simpleisbest and @vroom4 said similar things "too much tire for that rim size" ..except, that you're in a specific class that doesn't allow you to run any wider wheels or more aggressive camber which I didn't know until I read your last post.. I don't know Autocross rules as I never really attend any of them. .in your case, I would definitely flip them on the rim. I am not sure if you can heat cycle out non-competition tires in an AutoX event so you might be able to run them to the cords by flipping and rotating them regularly, if HC is not an issue
#20 |
Drives: '13 BRZ / '11 Outback / '06 Tundra
My experience with flipping tires (R comps and street) is that by the time you flip them it's too late (because I'm cheap). They will be slower once you flip them (but, yes, they will last longer). If your goal is to simply finish the season, then flip. If your goal is to be as competitive as possible, then don't flip.
Count on the first event after flipping being a throw away (at least the first several AX runs). In the future, flip them way sooner. |
#21 |
NASA SpecE30 Racer
Flip them and run them till you are ready for a new set. I tend to run my Toyo RRs till they cord. Even if they aren't good enough for the fastest lap, they still work fine for practice or early runs.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z Last edited by King Tut; 08-27-2014 at 05:21 PM. |
| The Following User Says Thank You to King Tut For This Useful Post: | glamcem (08-27-2014) |
#22 | |
i'm sorry, what?
Drives: Canada
actually, I've won 2 sets of Toyo tires this season (from two separate events) so it's not a money issue... it's just that there are only 2 events left! Then a long winter. So I'd rather order tires in the spring as I don't have a place to store them properly.
#23 |
NASA SpecE30 Racer
I didn't want to imply it was a money issue. I edited my post. That is some serious contingency. The best we can get is $300 toward a set of Toyos per weekend and they cost $700 for a set.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#24 |
i'm sorry, what?
Drives: Canada
ABRA KADABRA!
shoulda done it sooner.... not sure how "uncompetitive" they'll be having already done 13 events, but we'll see. they look brand fucking new, LOL really wish for a better camber curve but such is stock class.
| The Following User Says Thank You to 7thgear For This Useful Post: | tahdizzle (02-13-2015) |
#25 |
Senior Citizen
Drives: Scion FR-S
What tire pressures do you typically run?
#26 |
i'm sorry, what?
Drives: Canada
| The Following User Says Thank You to 7thgear For This Useful Post: | simpleisbest (02-13-2015) |
| DIY - Flip Key Fob conversion with pics | draggin_az | DIY (Do-It-Yourself) Guides | 178 | 05-10-2020 05:34 PM |
| Switchblade Flip key | Mr.Jay | DIY (Do-It-Yourself) Guides | 23 | 09-03-2014 12:16 PM |
| STD 86 Flip Key | Ryan86 | AFRICA | 4 | 09-30-2013 03:41 AM |
| Flip Key for my Twin | CamryDS | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 08-22-2013 05:56 PM |
| KW V3: To flip or not to flip | wootwoot | Tracking / Autocross / HPDE / Drifting | 40 | 05-07-2013 06:38 AM |
