#57 |
Drives: Toyota MR2 Spyder Turbo
@ Freedom - Coastal air mod is the best mod you can do on any NA vehicle!
#58 |
Official anti-BS squad
Drives: Toyota 86 High 6MT
Apples & apples - compare results from the same dyno, preferably with the same car as well.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
| The Following User Says Thank You to sav For This Useful Post: | Dammod (02-04-2015) |
#59 | |
95RON SAV Tuned |
#60 |
I only see now that the dynos were all done in Cape Town.
I doubt a stock car would make only 119FWKW at the coast. If that was the case everyone would be running to Toyota for misrepresenting the figures when selling the car. They quote 147FWKW
#61 |
I agree.
If you look at the WKW we're getting up here and what the guys are getting in Durban, 119 is definitely WKW. Uless that car was SERIOUSLY sick or running on 93.
95RON SAV Tuned |
#62 |
It could also be a case of the cars being run in different gears, it's just too easy to BS a dyno to get the results you're looking for.
95RON SAV Tuned |
#63 | |
Drives: .
Please see below the graph of the stock 86: ![]() We have dyno'd 86's at various dyno's in Cape Town resulting in different numbers. The Top End dyno (graph is one of the previous posts in this thread) for example, shows a BRZ at about 135kw with our tune pushing it up to around 148kw on 95 PUMP fuel. The key is consistency. We prefer using the more "pessimistic" (M.A.C.E) dyno used in the graphs above and will be using it for all further testing as it has proven to be both consistent as well as conservative. The gear a car is run in on the dyno can be checked by looking at the run "Duration". All of ours are done in 4th gear.
"Some will follow your footsteps, easier than they will your advice."
#64 |
Sounds a bit dodge but I agree - pointless using 10 different dynos, they would never be the same. 119kw is extremely pessimistic but it'll provide a base for % comparison as long as it's very consistent.
The reason I'm saying "dodge" is because your base car for comparison could be the weakest 86 in CT running on a bad batch of fuel - from there every other comparison would probably show gains.
95RON SAV Tuned |
#65 |
@ dammond - dont get me wrong. I'm not saying you posting incorrect info or you are lying or anything. I'm just having a constructive discussion.
WRT the gear in which it was dyno'd, its clear from the speed that all the cars were done in the same gear. Can't trick gear ratios. That's a more accurate way of determining the gear used that looking at duration ![]() Also, if the stock car was done on the same dyno, it seems all the readings are WKW No way in hell a stock car would make 119FWKW at the coast unless its running on 3 cylinders or something
| The Following User Says Thank You to Die$eL For This Useful Post: | Dammod (02-05-2015) |
#66 | |
Drives: .
![]() Agreed! That's an even better.
#67 |
Drives: 86 High SWP
Why not just use the OFT 91tune? Isn't that equivalent to our 95octane?
#68 | |
Drives: .
Unfortunately not it seems: http://www.ft86club.com/forums/showp...4&postcount=42 http://www.ft86club.com/forums/showt...77#post2116077
#69 | |
Drives: 2014 Satin White Pearl GTS auto
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto |
| The Following User Says Thank You to WesleyG For This Useful Post: | Dammod (02-05-2015) |
#70 |
Drives: 86 High SWP
Thanks for those links- I'll have alook see
| The Following User Says Thank You to Cheddaa For This Useful Post: | Dammod (02-05-2015) |
| Feeler: Dyno Tuning Session via Jamesm @ HRI tuning | sw20kosh | Northern California | 27 | 11-28-2014 08:53 PM |
| R/T Tuning & R/T Tuning Speed Shop Review Thread | R/T Tuning | User/Vendor/Sponsor Reviews, Feedback, Comments | 37 | 10-03-2014 03:23 PM |
| Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) | DesertFrs | Northern California | 14 | 04-24-2014 04:15 AM |
| Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 06:55 PM |
| Visconti Tuning - Latest Forced Induction Tuning Info | Visconti | Forced Induction | 340 | 04-30-2013 07:33 PM |
