Old 09-01-2014, 06:35 AM   #15
CSG David
CSG David's Avatar
Originally Posted by troek View Post
I have the hc-cs which is the same compound i believe, i think pedal control is extremely linear. So far they seem to be pretty easy on my rotors too(dixcel).
HC-CS is different from HC+800. HC+800 is the same as HC+, but assembled in a different facility (same everything except the pair of hands that puts them together).
HC-CS has a lower friction coefficient, but it is quite linear, so it is better for more control and longer stints. Less bite, but overall average is very solid. HC+/HC+800 on the other hand have more bite, but the friction curve is different as you go through the operating temp range.
The Following User Says Thank You to CSG David For This Useful Post:
kevaughan (05-09-2022)
Old 09-01-2014, 08:57 AM   #16
troek
troek's Avatar
Drives: 2012 Toyota 86
well there you have it.
Old 09-02-2014, 03:36 PM   #17
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Dust is bad with any performance pad i suppose. How well did u bed them in? These are significantly harder to bed in than other pads ive had. (This is all assuming the hc-cs and 800hc are the same or very similar. 800hc is their pad for non jdm vehicles.)
Didn't quite bed them as i was leaving them to scrape off the previous pad transfer layer but after a couple of hard stops, the bite was awesome! True about the dust and performance pads, its to be expected.
yomny is offline   Reply With Quote
The Following User Says Thank You to yomny For This Useful Post:
CSG Mike (09-02-2014)
E-Brake issue "clunking noise" when pulling the e-brake while rolling. Kinzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 06-20-2018 11:14 PM
Window Regulator Mounting Bolts - Noise Issue & Part Revision? PollosHermanos Issues | Warranty | Recalls / TSB 1 03-06-2014 11:39 AM
No Issue/Noise on BRZ European Models? Trap63 Issues | Warranty | Recalls / TSB 15 09-04-2013 04:29 PM
Electronic Heating and AC control in FRS cagster Cosmetic Modification (Interior/Exterior/Lighting) 5 04-08-2013 10:09 AM
