#169 | |
Reverse Burnouts
Drives: 2013 Argento FRS
You could turn out a VERY good 86 if you did all the work yourself like this guy. http://www.ft86club.com/forums/showthread.php?t=49172 @mrk1 is possibly the only person with the skills and tools on hand to put this quest to the test. Not only can he fab up pretty much anything, its also VERY VERY good work. See I could TRY to fab some of the stuff he has done but the quality would suck and unless you have been doing what he's been doing as a hobby for a VERY long time or actually work with metal like he does. You are going to end up with a really shitty end product that wont last but a few track days before blowing itself up. Bottom line. We need to know how much power the new Z06 puts to the ground. Secondly, how much down force the car makes and how well it turns. Find a track and run the Z06 and see what times it puts down. (A Magazine will most likely do this at a track for your convenience) Then, record track day conditions that the Z06 ran under at that specific track; Humidity, Temperature, ect. This will be your baseline to beat. Modify your 86 without molesting it. That means no roll cage, Stock ground clearance, ect. If you want any chance at being as reliable as the Z06 you would need to run some serious gear on the engine Engine: Custom Low Compression Pistons Custom Cams Titanium Springs, Valves, Retainers Stronger Bearings Billet Crankshaft Dry Sump Engine Oil Cooler Turbo Oil Cooler Upgraded Radiator Very large Intercooler Meth Injection Nitride coat EVERYTHING that you should. Transmission: Replace with something better like a T56 that can handle the TQ. Or you can get a racing transmission either would work. Transmission cooler Rear end: Drive shaft shop Axles and Drive Shaft Full Blown 8.8 rear conversion Suspension: Ohlins or comparable would be acceptable Brakes: Any 6/4 Pot config would work Aero: Full Under body Plate Rear-Downforce Wheels: Something beefy will do The Engine alone would be the MOST expensive single upgrade of the entire vehicle. Hopefully it is assembled correctly and doesn't blow up during it's first start or during tuning. A small mistake could lead you to shelling out for an ENTIRE new engine build. 1 loose bolt could blow up your $15k - $20k engine. (This includes buying a crate engine with 0 miles on it and modifying it.) If you can't post similar times to the Z06 at this point. Then hand your car off to the guy who set the lap time or someone with similar capabilities to see if they cant set a close enough lap time. If you are still treading behind the only suggestion I can give you is to start replacing all the panels with carbon fiber and start shedding weight. You can paint over it to retain a stock-ish look. EDIT The Biggest advantage the Z06 has is that if something does break, you can walk down to the dealer and order a fresh new part. One off parts made for your 86 will be hard to replace in short notice. So on another note. You would have to make multiples of custom parts so you have them on hand because your car wont be covered under warranty with a free rental car you can use while your car is being repaired.
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x Last edited by carbonBLUE; 09-11-2014 at 05:02 PM. |
#170 | |
Road-hole
Drives: 2013 Whiteout FR-S
that's ridiculous...
Just like everyone else, you're counting other people doing the work for you. I rebuild my own engines, been doing it for 25 years. Would I in this case? probably not you can buy a balanced and blueprinted lower compression shortblock for 4K with forged internals so why would I need to. I'm doing things differently than most people would because I bought this car specifically for what it is to test bed certain things I'm designing and prototyping.. I'm not going to get into details here. One of the things I would do if I was going to put that much money into the car would be to take out the trans and the diff and put in a rear mounted sequential transaxle. Remove 60-70 lbs and make the weight dist a perfect 50-50. that's 15-20K right there though. With that done though, you would have to do much less in some other areas. People are making 400 reliably with turbos and stock internals. I wouldn't be going that route, but I can't talk online about some of the things I'm doing. Internals would NOT have to be upgraded to make over 500hp though with what I'm working on. You want to talk about it a LITTLE bit, pm me and I'll give you my number and we can discuss it a little bit. One thing that I'm currently working on that I WILL touch on is an axial compressor based supercharger. Much more efficient than other types and shouldn't even require an intercooler because of that. That in conjunction with the other main thing I'm working on will easily be good for over 500hp, which has been shown to put the 86 on par with a 458 Italia, so do you think a stock Z06 will beat a 458 Italia??? I don't know if I'm going to do all of these things. I have stuff in the works, but you should know about the 'plans of mice and men'. The things that I would be doing would total less than 33K... bringing grand total for me to 53K if I were to attempt to better the Z06 with my car. Again, though, like you said, until we have hard numbers, we won't even know what the Z06 is capable of. I would be happy being on par with the 458 Italia though ![]() Jaden |
#171 |
Praise Helix!
40-50k in mods to beat a stock Z06. And then the Z06 owner spends a little bit of money and puts you right back where you were.
Doesn't seem worth it to me. |
#172 | |
Road-hole
I'd like to see a Z06 owner spend a LITTLE bit of money...
This is the problem with that idea. There is a point of diminishing returns where the amount of money you have to spend to get beyond a level of performance is crazily out of proportion. You don't have to spend any where NEAR that much to put yourself really close to the level of performance of a Z06 in an 86, but to go substantially beyond that gets REALLY expensive. And as I've already stated, you could buy a bare bones vette and put 25-30K and be better than the z06 too... So really, it just comes down to whether you... A) have 85-90K to spend right NOW, B) want to have the ability to take it to the dealership and complain when something goes wrong(and we know the dealerships are ALWAYS on point with fixing issues under warranty-insert SARCASM-) and or C) Don't care about having the pride of doing your own personal modifications to the car you drive. I do find it funny though that the majority of people in the (can't be done) camp drive something ELSE...lol let's see what comes next. Jaden |
#173 | |||||||||||
Reverse Burnouts
I'm interested. Build thread? ![]() Quote:
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#174 | |||||||
Drives: 2006 Cayman S, 2007 Outback 2.5i
Are they though? How many of those people track their cars, and how many can make it through a full track day without any overheating or other problems? Just making 400hp on an occasional highway pull is very different from being able to make 400hp reliably for long periods. Quote:
#175 | |
Praise Helix!
And if you did put 40-50k in mods in a FRS, you'd destroy the car... Figuratively of course. It would not be as streetable as a Vette, or have as many creature comforts. Don't care, just want to go to the track? That's cool I suppose. But you can be damn sure if I'm spending 100 grand on a car it's going to be something I can drive every single day without tiring of it. So I'll add another option for you. D) Have pipe dreams that and want to justify your purchase and say "what I have has the potential to be better than X" Seriously, I saw the exact same shit happen over at GenCoupe when it came out. People were like PRAISE THE NEW JESUSCAR! So tell me this. How many twins out there are running 10s or 11s all day long? And then can that same car then go to a track that isn't straight and then haul balls in the twisties as well? And then drive home with no reliability issues whatsoever. Because that's what the Corvette does. I'm no Corvette fanboy. It's just a damn good car that performs well above its price range. And the comment about people driving other cars. I bought the Abarth because it was 95% of the fun of a FRS for 75% of the cost. Oh shit and I can make it faster and better than a stock FRS for the same money as a FRS too!
#176 |
Road-hole
I already said I'm not going to discuss it online...
I already said I'm not going to discuss it online, too much risk..
I will say that it will add 60-90% of hp adding NO additional fuel while reducing strain on the internals of the engine... Jaden That should give an idea of WHY I won't discuss what it is. |
#177 | |
Road-hole
And I'll NEVER claim that you couldn't...
Jaden |
#178 |
Sure, that gives me a perfect idea. Because it isn't possible. You can't add 60-90% hp with no additional fuel and no additional stress on an engine.
#179 | |
Road-hole
You guys make me laugh...
![]() Jaden p.s. I couldn't actually care less. I got the twin because of the room in the engine compartment for testing my prototypes and because it's a light weight RWD platform. It does get funny watching all the twin bashers though and seeing what they have listed that they're driving... almost invariably something OTHER than a twin... |
#180 | ||
#181 | |
Drives: 370z
Nordschleife, Germany (20600 m) 12. Chevrolet Corvette ZR1 7:19.63 169 '08 647 / 1530 Jim Mero 13. Chevrolet Corvette Z06 Z07 Package 7:22.68 168 '11 512 / 1394 Jim Mero 28. Ferrari 458 Italia 7:28.00 166 '09 570 / 1485 Hockenheim Short, Germany (2604 m) 8. Chevrolet Corvette ZR1 1:08.30 137 '08 647 / 1530 13. Chevrolet Corvette Z06 Z07 Package 1:08.70 136 '11 512 / 1394 30. Ferrari 458 Italia 1:09.70 134 '09 570 / 1485 Laguna Seca, USA (3602 m) 2. Chevrolet Corvette ZR1 1:33.70 138 '08 647 / 1530 Randy Pobst 5. Chevrolet Corvette Z06 Z07 Package 1:34.43 137 '11 512 / 1394 13. Ferrari 458 Italia 1:36.22 135 '09 570 / 1485 Randy Pobst |
#182 |
Drives: 2006 Evo IX SE
Yup. I'm reminded of one of those shows (I think it was Fifth Gear) where they had a stock GT-R and a modded Evo (may have been a "stock" Evo X FQ-400 or something else with similar power), and there was still a big gap in their performance... and the Evo is no slouch, plus it already has a turbocharged motor anyway along with a lot of the goodies needed for performance. So all this talk is crazy.
| Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC | mav1178 | Other Vehicles & General Automotive Discussions | 1 | 05-23-2014 11:47 PM |
| 2015 86/BRZ vs 2015 Eclipse | botbs | FR-S / BRZ vs.... | 55 | 04-16-2014 05:07 AM |
| Is it just me or Twins are everywhere now? | DrawingWaves | Scion FR-S / Toyota 86 GT86 General Forum | 93 | 03-20-2014 10:31 PM |
| The twins | pnig | BRZ Photos, Videos, Wallpapers, Gallery Forum | 2 | 02-06-2014 07:52 PM |
| The Twins!! | iaclimber4 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 10-03-2013 03:20 AM |
