#15 |
Drives: Dark Grey BRZ
Thanks for all the input guys. Yeah, I'm from Cali and fill up with 91. Would this noise I'm hearing cause any sort of damage to the engine or transmission?
#16 |
Drives: swp mt '14 brz premium
You can't buy 93 in your part of CA ?
#17 |
Drives: Series Blue BRZ
#18 |
Drives: Whiteout frs
Puerto Rico...2013 model...done it since out of the dealer july 2012, i'm gonna tune in a couple of months because i'm tired of babying it to avoid the crunching and i'm sick of the torque dip.
I Will make a thread upon my results and changes done. Wish me luck. The car is great really, and apart all the quirks, noises and lack power ... its my dream car, i just feel i have to finish the job scion left me when i bought it. |
#19 | |
Drives: Firestorm 2013 FR-S
This could also be a symptom of "lugging"-- being in too high a gear for the engine speed. Timing is determined by engine speed and throttle position. When you increase throttle the timing advances. If you are in too high a gear (too low revs for the speed you are going) you will get pinging / knocking until the knock sensor cuts the timing back a bit. My car is an automatic and I have never heard pinging on 91 gas because the tranny immediately downshifts when I give enough throttle to make the car accelerate. One advantage of automatics. It takes a LOT of knocking to damage an engine, but eventually, yes, it will. |
#20 | |
Do you have an automatic or a manual? If you have a manual the only way to get the revs up quickly is to downshift |
#21 |
Drives: Fr-s
My car do it to. I use 91, 93 and also try octane 130 from sinto racing, and this sound still there.
This sound occur only when the car is engage on any gears, cluth in or not. I cant reproduce this sound in neutral at all. I hate this, i ear it every time i rev match or throtle blips. Hope toyota or subaru can fix this before mu waranty is over. |
#22 |
Had my first fill-up after dealer gas was used up. Sound is still there. On another note, found another thread that has the "crunch" sound. From what a few people mention, it's throttle related and not tip in knock. I'll probably still take it into the dealer after break-in and my registration stuff gets done with.
http://www.ft86club.com/forums/showthread.php?t=67295 |
| High RPM 3rd to 4th Shift Crunch | calmtigers | Issues | Warranty | Recalls / TSB | 1 | 08-01-2014 08:08 PM |
| 6th to 5th Downshift Crunch | jcat5150 | Issues | Warranty | Recalls / TSB | 1 | 04-17-2014 04:41 PM |
| Second Gear Crunch? | NOHOME | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 09-27-2012 03:52 PM |
| 5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? | kharn83 | Issues | Warranty | Recalls / TSB | 9 | 08-06-2012 08:44 PM |
