| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
| View Poll Results: If all else was equal, would you buy an electric? | |||
| Yes. |
48 | 67.61% |
| No. |
23 | 32.39% |
| Voters: 71. You may not vote on this poll | |||
#71 | |
Hit the road and I'm gone
We own a hybrid Ford C-Max that my wife drives most of the time. It is a very good and reliable car. I would not own an all electric yet for the reasons listed, mainly getting stuck in the middle of nowhere without any way to charge. On the plus side, an electric car ought to be as simple as dirt. Four electric motors, a big-ass battery, and a way to regulate power use. So mechanically, they ought to be more reliable with fewer parts involved. No cooling system for starters. For that matter, no starting system for starters. You don't even need a transmission! If every gas station eventually has a charging station too, then the problem goes away.
Slip, slidin' away.
| The Following 2 Users Say Thank You to babydriver For This Useful Post: | SirBrass (04-28-2015), Ultramaroon (04-27-2015) |
#72 |
Sixteen sodium atoms walk into a bar, followed by Batman.
Slip, slidin' away.
| The Following 5 Users Say Thank You to babydriver For This Useful Post: | Dadhawk (04-27-2015), HunterGreene (04-28-2015), SirBrass (04-28-2015), Tcoat (04-27-2015), Ultramaroon (04-27-2015) |
#73 |
WOW we used two of the most overused chemistry jokes ever in a row!
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Dadhawk (04-27-2015), Ultramaroon (04-27-2015) |
#74 |
It was a team effort.
Slip, slidin' away.
| The Following 2 Users Say Thank You to babydriver For This Useful Post: | Tcoat (04-27-2015), Ultramaroon (04-27-2015) |
#75 |
fabulous
#76 |
fabulous
Never trust atoms. They make up everything.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | HunterGreene (04-28-2015), SirBrass (04-28-2015) |
#77 |
Well as a team for chemistry joke were are barely just oxygen and potassium.
| The Following User Says Thank You to Tcoat For This Useful Post: | HunterGreene (04-28-2015) |
#78 |
Drives: 2015 Firestorm Scion FRS
i wanna tesla p85d....because....insane mode.
#79 |
Hail Magnet
A Uranium atom walks into a bar, sees a bunch of neutrons running around, and splits.
| The Following 3 Users Say Thank You to HunterGreene For This Useful Post: |
#80 |
Back on topic temporarily:
One sort of disincentive to gas stations providing charging stations is that they can't be all that profitable. It costs less than two bucks to charge an electric car battery, which is great for the consumer but not so much for the merchant. if they are obliged to purchase an expensive rapid charge unit then there is probably no profit at all. Also, as electric cars become more common, it will be necessary to have more than one charging station at each "gas" station.
Slip, slidin' away.
#81 | |
Hail Magnet
| The Following 2 Users Say Thank You to HunterGreene For This Useful Post: | Dadhawk (04-28-2015), Ultramaroon (04-28-2015) |
#82 | |
Trust me, I'm the Doctor
EV only works if your overnight end-location is within the range, you stick to optimal speeds to get said range (bye bye good highway speeds, as the range quoted assumes max cruise speed of 55 mph and range decreases greatly if you cruise on lots of uphills, or cruise at normal highway speeds, say 75-85 mph), and end-location has charging ability with the charging speed that'll allow you to fill a mostly drained battery in 6-8 hours. From a standard 110v outlet, you won't be able to charge up the 400mi range battery in that amount of time.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ Last edited by SirBrass; 04-28-2015 at 01:57 PM. |
| The Following User Says Thank You to SirBrass For This Useful Post: | Dadhawk (04-28-2015) |
#83 | |
1st86 Driver!
If there is a profit to be had, someone will figure it out. The problem is there isn't one yet because the volume is too low and the charging takes too long.
![]() Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | SirBrass (04-28-2015) |
#84 | |
That's the major kill factor in EVs, I think: recharging cannot be done quickly. It simply cannot without massively dangerous amps (divide Amp-hour capacity of battery by the charging source's output amperage rating to get the from-drained charge time) that no sane person would want to be casually handling at a charging station. That, OR easily swapped out battery packs like we currently do with battery-powered hobby helicopters and airplanes. Problem there is size & weight. And that's where combustion-powered engines have the advantage. Refueling times are short and it's very easy to do. You don't have to swap out the gas tank to quickly refuel, or wait for fuel to condense from a heavy vapor at source to liquid in the tank and fill up that way (best analogy I could think of to charging a battery), etc. Amps at charge source is the functional equivalent of fuel flow rate from the pump. With a high amp source, you have the VERY dangerous possibility of arcing and electrocution. You have a much lower risk by orders of magnitude of having a spark ignite fuel vapors and catch the car on fire with petroleum fuel unless you're very careless. Whereas with a high amp electric source, it's very easy unless you're well trained and extremely careful in your precautions, prep, and procedure to kill yourself or cause a very dangerous arc. Only way to mitigate that danger is to have a lower amp output, such as what Tesla supercharger stations currently have, and settle for waiting an hour or two while your hybrids and economy cars get the same range till needing to fuel up and are back on the road in 5-10 minutes (and only that long b/c of folks taking bathroom breaks) while you're sitting there for hours.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
| electric cutout | davebrus | Electronics | Audio | NAV | Infotainment | 0 | 03-21-2014 01:26 PM |
| electric short | Abdo | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 02-07-2014 05:14 PM |
| Electric 86 | frosty86 | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 11-10-2012 03:16 PM |
| WRX Electric turbo | Neilus | Engine, Exhaust, Transmission | 42 | 05-03-2012 10:20 PM |
