Old 08-13-2014, 11:42 PM   #85
poptart
Drives: 2000 Corvette
Originally Posted by FRS Dad View Post
Right, because nothing turns a buyer off like the idea of getting a used car that has a newer engine with less miles on it.
In the case of a late model car like this, I would absolutely rather buy a used car with no stories than have to worry if the dealership that screwed up something as simple as an oil change, is actually capable of swapping a long block without messing something else up. Probably won't be a lot, but I'd ask for some diminshed value.
poptart is offline   Reply With Quote
Old 08-13-2014, 11:45 PM   #86
FRS Dad
Drives: 2015 FRS
Originally Posted by Tromatic View Post
You've been arguing against that the whole thread, no? Did I miss something?
Yes. You missed the day they taught sarcasm at school.
2015 FRS M6 Argento, 2014 Audi Q7, 2012 Audi A5 (Traded),2012 VW CC, 2010 Mercedes S550
FRS Dad is offline   Reply With Quote
The Following User Says Thank You to FRS Dad For This Useful Post:
HunterGreene (08-14-2014)
Old 08-13-2014, 11:51 PM   #87
Tromatic
I was the instructor. I know for a fact you were absent.
Good luck with this:
WTS: 2013 Scion FR-S, 23K miles. First oil change at 8K with 5 quarts of ATF, only driven for 2 hours before actual oil used. Asking 18K, willing to accept 10k.
Tromatic is offline   Reply With Quote
Old 08-13-2014, 11:52 PM   #88
FRS Dad
Drives: 2015 FRS
You always have to compare the actual service records against the CarFax history. CarFax is very vague, and they only catch work done at the dealer or accident reports by VIN. Repairs at indie shops, or body damage that didn't result in a police accident report doesn't make it.
DOV would be a stretch.
Old 08-13-2014, 11:53 PM   #89
eyedeez
eyedeez's Avatar
Drives: 2014 Firestorm FR-S 6MT
I'm 12. What is this?
eyedeez is offline   Reply With Quote
Old 08-13-2014, 11:53 PM   #90
fradet
Drives: sentra ser
Sure, why not? Maybe the President of Toyota Heavy Industries could personally fly in and blow the guy. Seriously though, why does the car need a new engine?
Well this was said : Since I was over 10 miles away they wanted to tow it "because it may do damage to the car"
Im assuming they were worried about the engine. Im also assuming they know potencial domage transmission fluid could do the engine but maybe they dont know ? Maybe you do know but you said an extended warranty isnt unreasonable. So that being said, personally would prefer cash over an extended warranty and I gave 2 arguments so he can get the most of it.
To get a clear picture, we need to know from a good source if transmission fluid can "destroy" or harm this engine on the long run.
fradet is offline   Reply With Quote
Old 08-13-2014, 11:54 PM   #91
FRS Dad
Drives: 2015 FRS
Wrong guy. I've never been to truck driving school.
Old 08-14-2014, 12:01 AM   #92
Chimera
Drives: FRS
Waiting for someone knowledgeable in fluid dynamics to speak up.
Old 08-14-2014, 12:03 AM   #93
andrewmay9
Drives: 2014 scion frs asphalt
stop fighting over the internet. give the guy advice and move on
andrewmay9 is offline   Reply With Quote
Old 08-14-2014, 12:03 AM   #94
FRS Dad
Drives: 2015 FRS
It's fair to state that they don't know what the effects are because it's such an odd occurrence, but wanted to err on the side of caution and flat bed the car. It certainly wasn't GOOD for the car, obviously.
I think you have two options before you:
1) Have the engine torn down, the parts cleaned and inspected by a Subaru tech, and have the area Subaru factory rep sign off on the reassembled engine.
2) Take it on faith that no permanent harm was done, have the shop do a couple of short interval oil and filter changes and accept the extended warranty.
Option one just seems horribly invasive and is likely to turn up nothing, plus it'll tie the car up for a couple of weeks. Let me follow up with my brother tomorrow. He's a great tech and his advice is always spot on.
Old 08-14-2014, 12:04 AM   #95
noobcake
noobcake's Avatar
Drives: EVO X
Originally Posted by husker741 View Post
I will PayPal you $5 to quit making threads.
noobcake is offline   Reply With Quote
Old 08-14-2014, 12:05 AM   #96
FRS Dad
Drives: 2015 FRS
Well I hope you're all happy now. The Internet Police just showed up. Nice work everyone.
Old 08-14-2014, 12:11 AM   #97
Tromatic
Neither have I! Unless it was breaking 939 tires for the lazy slags who were supposed to be doing the job. And there was sarcasm.
Old 08-14-2014, 12:14 AM   #98
FRS Dad
Drives: 2015 FRS
Okay, I did some research on this. Apparently ATF is thinner than motor oil, and it is a common practice on higher mileage engines to run a mixture of ATF and oil for a short period to clean sludge out of the engine, then do a couple of regular oil changes to flush any remaining ATF out: This was posted in response to a guy who had accidentally used ATF instead of motor coil.
"Actually, people used to put 'some' transmission fluid in the engine oil right before an oil change because trans fluid helps clean the gunk out.
I wouldn't keep it in there but I wouldn't have any problem with driving it for a couple days then getting an oil change."
Source:
ASE Master Tech for 22 years.
So it doesn't seem like the two fluids are totally incompatible. If they mix together readily then they can be flushed out together as well.
Dealer Service Center Oil Change Nightmare FRS-Texas Engine, Exhaust, Transmission 28 08-15-2014 05:27 PM
Dealer service 5/13.... Tromatic Software Tuning 4 05-13-2014 03:26 AM
Best Scion service center in LA area? G.I.Choe Southern California 12 04-19-2014 12:47 AM
First Dealer Service Umbie BRZ First-Gen (2012+) -- General Topics 7 12-12-2012 10:50 AM
First Engine Oil change, DIY or Service? davey90 AUSTRALIA 25 09-13-2012 02:56 AM
