86WORX
Old 03-20-2013, 12:39 AM   #57
Tunz
Drives: WRB BRZ Limited
No problem.
Tunz is offline   Reply With Quote
Old 04-25-2013, 08:40 PM   #58
BR Zenith
Drives: 2013 LR BRZ Limited
Originally Posted by Ro_Ja View Post
Body panel misalignment issue is RESOLVED!
After opening a case with Scion Corp., the entire process was transferred to Toyota Sunnyvale (Northern California) who took care of me and the car. After about 3 weeks of processing my claim, I received a call yesterday from Toyota Sunnyvale to bring the car in. I took it down this morning to check in and then drove to the pre-selected body shop in the area. At the body shop, the fix literally took less than 10 minutes and the fender did not have to be removed. Apparently, the whole issue can be fixed by opening the door to access the bolts in the doorjamb and adjusting said bolts. It now looks like how it should have come from the factory. I'm pleased with the whole experience.
I'm curious does the panel now fit flush at the bottom where it was sitting low before? My BRZ has this exact same issue and has been to a body shop but there are still noticeable gaps in both locations.
BR Zenith is offline   Reply With Quote
Old 04-25-2013, 08:55 PM   #59
Ro_Ja
Drives: TOYOTA
Yup. It's all perfectly flush, everything lines up, and the gap between the door and fender is a consistent width all the way down.
Ro_Ja is offline   Reply With Quote
Old 04-26-2013, 10:29 AM   #60
BR Zenith
Thank you Ro Ja
Old 05-05-2013, 11:37 AM   #61
firestorm frs
Drives: 2013 firestorm frs
Im always checking my car for any minor imperfection. I walk outside to take break from work in my lovely fr-s when I notice my panel under my left front headlight is lower than the other side and the clips in between the panels are exposed, I tried popping it back in but did not have any luck. Tack up yet another thing that makes me sad about this car. Body panel issue, CHIRPING, Tail Light condensation, (not a huge issue but,) window marking/scratching, Windows scream when wet and rolled down or up this, this pretty much makes your car look so cheap when your windows screech. love my fr-s for style and driving but the bad far exceeds the good lately..
firestorm frs is offline   Reply With Quote
Old 04-27-2014, 11:15 PM   #62
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Thread back from the dead... I've been noticing my fender/door gap getting larger and larger... next visit to the dealer I am going to point it out.
The Following User Says Thank You to DarrenDriven For This Useful Post:
Packofcrows (11-02-2015)
Old 04-27-2014, 11:24 PM   #63
xia
Drives: 1995 Supra TT & 2013 FRS
WTF.
xia is offline   Reply With Quote
Old 04-27-2014, 11:41 PM   #64
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
It does that. It will go back. I get this after Autocross. It goes back after some time.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 04-28-2014, 11:15 AM   #65
DarrenDriven
NW Region Moderator
I noticed it about six months ago and it has slowly gotten worse as time went on... I don't think it is going back.
Old 05-19-2014, 11:53 PM   #66
Kwise1
Kwise1's Avatar
Drives: Raven FRS
What was the fix for this? Mine is doing it as well.
Kwise1 is offline   Reply With Quote
Old 05-20-2014, 12:23 AM   #67
DarrenDriven
NW Region Moderator
I haven't fixed mine yet... but if you read through the topic I think someone else did.
Old 05-28-2014, 08:58 PM   #68
Kwise1
Kwise1's Avatar
Drives: Raven FRS
Toyota Service Bulletin: Body Panel Fitting Issues
Here is the fix for this issue.
Open the door and locate the lower fender 10mm bolt seen here
Attachment 80179
This bolt is loose causing the fender to not stay flush with the door
For the passenger side loosen up this bolt, close the door and carefully push the fender to make it flush, then tighten the bolt.
The driver side is a little more difficult and requires two people, one to tighten the bolt and the other hold the fender in place. If you try to tighten the driver side bolt without holding the fender, the fender will bow out even more.
First loosen the bolt, then have the other person very carefully push on the fender to align it with the door.
Do not push the fender to hard or it will cause a dent ( they are very thin).
Have the person hold the fender in place while you tighten the bolt.
I did this fix last week and it's still flush.
The Following 8 Users Say Thank You to Kwise1 For This Useful Post:
DarrenDriven (05-29-2014), dhuang (04-30-2015), DocWalt (07-14-2016), Kristian (07-18-2016), microbionic (06-05-2016), MJones_RB (03-07-2017), MrAmalto (01-04-2015), Sigh-on-Rice (09-15-2014)
Old 05-29-2014, 11:30 AM   #69
Chattanooga FR-S
Chattanooga FR-S's Avatar
Drives: Monogram Firestorm
Yeah, but is it herra frush?
Chattanooga FR-S is offline   Reply With Quote
Old 05-30-2014, 11:53 AM   #70
Ddreder
Ddreder's Avatar
Drives: 2013 FR-S, 1990 Miata
The body lines on my fr-s are sure arent as perfect as they should be.. I dont really notice unless I look closely but I mean for a car with 16K miles on it the panel gaps should be perfect!
Ddreder is offline   Reply With Quote
Search this Thread:
Advanced Search
Seat belt issues skoodge Scion FR-S / Toyota 86 GT86 General Forum 55 08-04-2014 04:41 PM
Steering Issues? (Toyota Recall) Buggy51 Other Vehicles & General Automotive Discussions 8 11-10-2011 03:07 AM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 03:20 AM
