#29 |
Drives: 2017 STi WRB
thanks for the quick reply. what circular piece are you talking about? the clips/washer that kind of sandwich the baffle?
#30 |
Drives: white-out FR-S
#31 | ||||||
Drives: 2013 Subaru BRZ
If you turn the fittings completely in, it should not cause any issues. That being said, you are unlikely to be able to re-install them and obtain an appropriate seal. If you need to remove the fittings in the future, let us know and we can set you up with replacement fittings. Quote:
Thanks -John |
| The Following User Says Thank You to Mishimoto For This Useful Post: | Donbrz (12-17-2015) |
#32 |
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
I think I have The rattle too. I'll send an email. I'm also short one worm gear clamp. Otherwise, this seems like a solid part.
#33 |
#34 |
Drives: 93' Supra & 13' 86 GTS w/Aero
Hi, I have received one of these baffled catch can kits in Australia for Christmas and when I went to put it in the car I found the mounting bracket that came with it won't fit. I was wondering if there was meant to be a different bracket for the RHD cars as there are 3 hoses instead of one running along the top of the bay (see photos attached).
I'll be contacting the store when they return from the Christmas/New Year break but thought I might check here in the meantime. Thanks. |
#35 | |
Sorry for the inconvenience! Thanks -John |
#36 |
mishimoto fixed my rattle by sending me a replacement part I'd say a year ago. Thanks guys for being so quick on sending the replacement part!
#37 |
#38 |
does anybody know if this will work with an innovate supercharger?
Yeah its an auto, deal with it.
#39 | |
-John |
#40 |
BoostedBRZ
Drives: Turbo BRZ
Don't mean to revive the thread from a month ago, but I do have a question for the mishimoto team...
I happened to have bought your universal 3 port catch can. I'm running the kraftwerks supercharger kit. Is there any different in the 3 port catch can? Also, because I purchased the universal one without knowing there was one made specifically for the car, is there any way I can order the mounting bracket separately? For anybody else that would like to answer how do you have your 3 port catch cans set up with the hoses running where? Thank you! |
#41 | |
I am not so sure the 3-port is the catch can you will want for this vehicle. We typically recommend the 3-port for vehicles with two breather lines, such as the EJ25 which has one coming from each valve cover. The FA20 only uses a single breather line and a single PCV line, both of which will need to be routed into a can of their own. For the FA, we found the PCV circuit to capture the most fluid out of the two. The breather line did not show any accumulation in our tests. This could change with the addition of forced induction. My recommendation would be to stick with a single two-port for the PCV line and potentially an additional single two-port for the breather line. Our direct-fit setup can be used for the PCV line and will include everything necessary for installation. You have a few options here. 1. Install the 3-port and acquire brackets and hoses from our team. Plug additional inlet. 2. Return 3-port and purchase direct-fit kit. 3. Install 3-port and construct a bracket and hoses in DIY fashion. Plug additional inlet. My recommendation would be option 2 as this will be the cleanest looking installation. You can then add on a breather catch can in the future if you feel it is necessary. Sending this list to you via PM and we can work out a solution for you! Thanks -John |
| The Following User Says Thank You to Mishimoto For This Useful Post: | SkAsphalt (05-26-2016) |
#42 |
Drives: Subaru BRZ Series.Blue
I just ordered these this past weekend and attempted to install it today but ran into a small problem. The catch can does not fit with the STI Flexible Strut bar. The 2 fittings get in the way.
| Mishimoto Build Thread: BRZ/FR-S Silicone Induction Hose | Mishimoto | Engine, Exhaust, Transmission | 23 | 11-29-2018 12:35 PM |
| Mishimoto Build Thread: BRZ/FR-S Performance Cold-Air Intake | Mishimoto | Engine, Exhaust, Transmission | 90 | 12-03-2016 07:22 PM |
| FS:WA- ADD W1 REd Baffled Universal Aluminum Catch can | glamcem | Engine, Exhaust, Bolt-Ons | 0 | 07-05-2014 08:15 PM |
| mishimoto oil catch can mounting | jonbonazza | Engine, Exhaust, Transmission | 3 | 03-30-2014 03:13 PM |
| Win a Mishimoto Oil Catch Can! | Mishimoto | Announcements, Contests, Giveaways | 68 | 10-23-2013 06:27 PM |
