#43 | |
Drives: Lawn moweR
taking into account pipe/flange Thickness (Picture B) (Ie. outer Diameter) ? Im assuming the pipe thickness is approx. +- 1.5mm Last edited by FT_86_SM_GP; 04-13-2015 at 09:55 PM. |
#44 |
Official anti-BS squad
Drives: Toyota 86 High 6MT
Why would he measure the flange?
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
#45 |
Drives: PEARL WHITE GT86 TRD
#46 |
Haha true story!!
95RON SAV Tuned |
#47 | |
Drives: .
| The Following User Says Thank You to Dammod For This Useful Post: | FT_86_SM_GP (04-14-2015) |
#48 |
Drives: Lawn moweR
Thanks
Reason for asking is that I am researching headers and overpipes combo's and noticed the different sizes with various brands Eg. Borla UEL Header: Collector "Outer" Diameter - 2.25inches (Approx 58mm) Primary Tube Outer Daimeter 1.625inches (Approx 41mm) (Not sure how to interpret this data from the Borla website) Tomei UEL Header and Kamak Dynamic UEL Header: 60.5mm Diameter (Not sure if its inner or outer pipe Diameter?) It seems like the Tomei or Kamak UEL Headers are the way to go if you want better airflow / performance and a refined rumble. I recently got myself a Borla Version 2 UEL header purely for the love of a louder rumble and the resulting exhaust tone. (Did not (realize) think about performance when purchasing it )I was advised by Borla that there is no need to change the stock overpipe as it will not make much difference... (Stock overpipe has a Diameter of approx 54mm) I do trust their judgement and advice from their reputation and R&D... But I am still trying to understand how the stock overpipe (being 54mm in diameter) will not make a difference if changed to an aftermarket 63mm overpipe ? Maybe the Borla UEL Header is 54mm "Inner" Diameter as well? (Scary how restrictive it is - Same to stock) - I do know that trying to keep all components a consistent size (From Header to Muffler Ie. "Header Back system?") will optimize airflow and enhance performance.. To stick with stock overpipe... or not ![]() Here is a rough picture of what I am trying to explain / need advice on... |
#49 |
Drives: Lawn moweR
I managed to get some time tonight to measure the inner Diameter of the Borla UEL:
Borla UEL Header has a similar Inner Diameter to the Stock header. (Excuse the poor camera angles and R2 Ruler) 1st juncture port exit = +-45mm (Stock is 45mm) 2nd juncture joint pipe = +- 54mm (Stock is 54mm) |
#50 |
Drives: Toyota 86
Maybe if you compare these to the Toyota 86 exhaust you will see a difference.
From what ive read (on this forum) the Toyota exhaust is the one that is so much more restrictive than the Subaru. Maybe you will see the differences in sizes there? Just a thought... |
#51 | ||
Drives: .
Although Borla claim to see no difference with adding an appropriately sized overpipe, other vendors have found the opposite to be true. Granted, in both cases this could be down to marketing. Don't get me wrong, I don't think you would see massive gains in power (NA) but when you have a few components that all make a "negligible" difference, those "negligible" differences can add up to being a good 7kw (for example) and we all know that when staying NA every kw counts...budget dependent. I don't think swapping your Borla header out for a Kamak/Tomei will result in enough of a gain to actually FEEL the difference, but when combined with an overpipe, DIF and free'er flowing 63mm exhaust, it might actually add up to something. It might be worth mentioning: We haven't managed to get hold of a set of Borla headers for back to be testing personally, but a well respected member from Durban who has no affiliation to any specific company has confirmed that the Kamak headers seem to flow better then the Borla's they tested. Quote:
Are your referring to the headers which are being measured above? If so, the BRZ and GT86 have the same stock headers. |
| The Following User Says Thank You to Dammod For This Useful Post: | FT_86_SM_GP (04-15-2015) |
#52 |
#53 |
Why are we splitting hairs over a horsepower or two?
95RON SAV Tuned |
#54 | |
Drives: 2014 Toyota 86
Satin White Pearl 2014 Toyota 86 High
| The Following 2 Users Say Thank You to ShaunWRX For This Useful Post: | Dammod (04-15-2015), FT_86_SM_GP (04-15-2015) |
#55 | |
Drives: Lawn moweR
"I highly doubt it would be noticeable at all. The over pipe is only a few inches long, and since it's not smaller than your headers, I don't think it would do anything. Now if it were smaller than your headers, it would be creating a pinch point, but if all your numbers are correct, that's not the case." The sound of his exhaust setup is insane ![]() [ame="https://www.youtube.com/watch?v=ocO6y-R3GHk"]Borla UEL headers, PLM over pipe, Tomei front pipe, Tomei 60R, OFT 1.58 stage 2 tune, FR-S BRZ GT86 - YouTube[/ame] |
| The Following User Says Thank You to FT_86_SM_GP For This Useful Post: | ShaunWRX (04-16-2015) |
#56 |
Drives: Lawn moweR
I contacted TMSS in JHB and got a quote of R1,150 excl VAT for a custom 2.5inch/63mm Outer diameter overpipe.
Beats aftermarket overpipes which are +$200 to $300. I had a look at their work on Facebook (Search: "TMSS Motorsport") and I must say its exhaust porn for me..... ![]() ![]() ![]() But those Mandrel Bends ![]() ![]() Will look into the cost of getting a custom exhaust from these guys. Heres some exhaust porn:
| The South African Feel Good Thread | Fish Eagle | AFRICA | 666 | 06-16-2018 03:18 PM |
| South African Forum | Dammod | AFRICA | 6 | 03-20-2014 01:16 PM |
| Toyota South Africa release pricing on the Toyota 86!! | PREDATOR786 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-16-2012 07:10 PM |
| FRS / BRZ in Seatle to show to South African Enthusiast? | RudiG | Northwest | 9 | 06-22-2012 04:59 AM |
