Old 11-21-2014, 04:33 PM   #379
underpowered
Drives: brz
What are you other mods? Do you have any before numbers?
underpowered is offline   Reply With Quote
Old 11-21-2014, 04:34 PM   #380
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
What are the mods? Mustang Dyno's normally "read" lower correct?
yomny is offline   Reply With Quote
Old 11-21-2014, 04:38 PM   #381
Trefoil
Trefoil's Avatar
Drives: GBS BRZ Harrop SC/PTuning Header
I waited to dyno until after installing the header, but initially I had around 190whp and 170wtq with no tune. I have the header, 2.5" Nameless catted F/O pipe, 2.5" resonated Perrin CBE, and a TRD panel filter. The AFR goes a bit crazy with all of that on, so you will want a tune for safety and power gain.
*EDIT* That initial number is with all of the parts on the car and performing a baseline run after the calibration run.
Trefoil is offline   Reply With Quote
Old 11-21-2014, 04:43 PM   #382
Trefoil
Trefoil's Avatar
I believe you're correct. The most shops use Dynojet because they're more consistent between eachother but read higher since they only use weight rather than resistance (via PAU).
Old 11-21-2014, 05:21 PM   #383
D.Scrye
D.Scrye's Avatar
Drives: Hot Lava FR-S
@Trefoil- would you please upload the chart without the info box? I'd love to see the curve.
Why not?
D.Scrye is offline   Reply With Quote
The Following 2 Users Say Thank You to D.Scrye For This Useful Post:
*KID* (11-21-2014), Calum (11-21-2014)
Old 11-21-2014, 06:21 PM   #384
sw20kosh
Drives: 2013 Black FR-S
Yes but these dynos can be calibrated to read however you want.
There is no way he is making 190 whp no tune with just exhaust on a true low-reading mustang. That 190 number is more in line with a dynojet and that is even a bit high for a dynojet. This dyno looks like it reads high not low.
The Following User Says Thank You to sw20kosh For This Useful Post:
Xero-Limit (11-25-2014)
Old 11-21-2014, 06:32 PM   #385
DarkSunrise
DarkSunrise's Avatar
If that's Circuit Motorsports, they dyno'd a stockish BRZ at 174 whp and made around 191 whp with a tune.
2022 BRZ Build
2013 FR-S Build
Old 11-21-2014, 06:48 PM   #386
Trefoil
Trefoil's Avatar
I pulled those numbers from my photographs and memory. That may have been after the first reflash using Bob's EL tables that he's created.
This graph wasn't the final result, but close to it. The "dip" isn't noticeable at all - contrary to what many might imagine. But Circuit was able to greatly diminish not only the depth but also the width of that area. The AUCs are good.
*EDIT* Now I remember. The first thing Bob did was reflash, so in a way, that was a tune.
Old 11-21-2014, 10:13 PM   #387
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Different dyno, different day.
This dyno reads a stock BRZ/FRS at 160whp/138wtq. Trefoil came to us with all parts already installed. The 190whp was generated using my base tune, not the stock tune.
I later flashed a stock tune onto the car to try to get an idea of what things looked like without a tune, but the AFRs were all over the place and went dangerously lean on high load, so I abandoned the attempt. This is why it is important to get tuned as soon as possible after installing aftermarket parts, as you don't know what the affect is on how the engine is running unless you are able to data log.
- Bob
Circuit Motorsports is offline   Reply With Quote
The Following 3 Users Say Thank You to Circuit Motorsports For This Useful Post:
Hyper4mance2k (12-04-2014), Trefoil (11-21-2014), Valentino (05-26-2015)
Old 11-22-2014, 01:01 AM   #388
Wepeel
Drives: '13 BRZ Ltd
This header looks like the real deal.
- Bob
What is your take on the dip?
Wepeel is offline   Reply With Quote
Old 11-22-2014, 10:26 AM   #389
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
All the dynos on the first post have a torque dip and that was with a 3" race exhaust. This header was designed for max power not removing the dip.
Mad_Mike is offline   Reply With Quote
Old 11-22-2014, 09:19 PM   #390
Circuit Motorsports
With respect that this is another vendor's thread, please see our tuning thread under the software tuning area for more details.
- Bob
Old 11-24-2014, 04:41 AM   #391
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Alright, last vid for me on this thread. Some good sounds on this one. Enjoy :-)
[ame]http://youtu.be/A5w54dudo24[/ame]
rb6freak is offline   Reply With Quote
The Following 13 Users Say Thank You to rb6freak For This Useful Post:
10Stars (11-25-2014), bjun (11-24-2014), Bramick (11-24-2014), buddy32 (11-24-2014), GhostOp86 (11-24-2014), Hyper4mance2k (12-04-2014), JonAvalon (11-24-2014), kanundrum (11-25-2014), kosoku (05-23-2015), lucid215 (11-24-2014), midnight23 (11-24-2014), Mrc@ptuning (11-24-2014), yomny (11-25-2014)
Old 11-24-2014, 12:02 PM   #392
s30series
Drives: 2015 BRZ Series.Blue
Originally Posted by sato View Post
Do it... Do it!
So apparently they fired their tuner last week. Shitty thing is I have an HPDE event on Sunday. This is not looking good for me.
s30series is offline   Reply With Quote
200hp na, 4-1 full, merge collector, ptuning, race header
WTB: Equal-length (EL) catted header ck-GT86 Engine, Exhaust, Bolt-Ons 1 04-10-2014 08:31 PM
PRE Stepped diameter 4 to 1 double slip collector Header Jmonty Engine, Exhaust, Transmission 9 02-28-2014 10:24 AM
BRZ/FR-S/GT86 – 4-1 Equal Length Header Group Buy P&L Motorsports Groupbuys 634 12-03-2013 06:36 PM
*PHASTEK* DC Sports Equal Length Header PhastekSport Engine, Exhaust, Bolt-Ons 3 11-14-2013 11:17 PM
