Old 08-08-2014, 12:19 AM   #1
Fainten
Fainten's Avatar
Drives: white brz
Ac freon
I need to know how much freon i need to recharge and what type
Fainten is offline   Reply With Quote
Old 08-08-2014, 01:34 AM   #2
RussianNinja
Drives: Prius 08 Base Model
I'm confused as to why your AC needs a recharge?
RussianNinja is offline   Reply With Quote
Old 08-08-2014, 02:22 AM   #3
enjetek
Drives: 93.5 supra t & prius
R134? O.o
enjetek is offline   Reply With Quote
Old 08-08-2014, 02:33 AM   #4
YMAA
Maximum puntential
YMAA's Avatar
Drives: 2013 DGM BRZ 6MT LTD
I brought my car to the dealer to have the AC looked at when it quit blowing cold air on a trip to Virginia earlier this year. They said quite a few BRZs (and I'd assume FR-Ss as well as they're made in the same factory) weren't completely charged from the factory before being shipped out. No leaks or anything in the system, just had enough coolant to get through one season.
They filled it under warranty and leaktested the system, no charge.
Perrin CAI + intake tube || Tomei UEL || OFT Stage 2 tune
YMAA is offline   Reply With Quote
Old 08-08-2014, 02:30 PM   #5
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
R134A and check the sticker under the hood.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 08-10-2014, 02:05 AM   #6
HapaHaole
Drives: Grocery cart
13.8oz plus or minus 1.8 oz OR for those metric folks
390g plus or minus 50g
R134A refrigerant.
SOLD: 2014 BRZ Limited WRB 6 Speed.
HapaHaole is offline   Reply With Quote
Old 08-10-2014, 02:19 AM   #7
extrashaky
Drives: 2014 BRZ Limited
Are you completely evacuating the system with a vacuum pump or just adding to what's in there already?
Old 08-10-2014, 05:49 AM   #8
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
Your dealer is clueless.
ntron1 is offline   Reply With Quote
Old 08-10-2014, 05:09 PM   #9
Fainten
Fainten's Avatar
Drives: white brz
I was fixing a salvage brz project i have going on and i needed to know since condenser and radiator was replaced.
Old 08-10-2014, 05:11 PM   #10
Fainten
Fainten's Avatar
Drives: white brz
Old 08-10-2014, 05:12 PM   #11
Fainten
Fainten's Avatar
Drives: white brz
R134A refrigerant.
Is that including the oil?
Old 08-10-2014, 09:03 PM   #12
HapaHaole
Refrigerant oil has noting to do with the refrigerant capacity information, Oil is a separate spec. ND-OIL 8
Toyota is semi stingy with the information , but states to add in what was removed from the system.
Most HVAC recovery machines has a separate bottle for oil, you have to measure how much came out and replenish it based on that.
Old 08-10-2014, 09:12 PM   #13
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Not to mention you shouldn't just start tossing refrigerant in to a system that could possibly have a leak. That stuff is still bad for the environment.
Have a certified and trained vehicular HVAC tech take a look at it.
Bobblehead is offline   Reply With Quote
Old 08-11-2014, 11:14 PM   #14
Fainten
Fainten's Avatar
Drives: white brz
ok because my BRZ has nothing of oil or 134a because it was sitting for more then 1 year in a salvage lot, with a broken condenser and radiator.
