86WORX
Old 08-28-2016, 08:46 AM   #589
WRBrzRX
Drives: runs&drives
DELETE THE THREAD
wait what
WRBrzRX is offline
Old 08-28-2016, 12:49 PM   #590
wooly35
Drives: 2014 Scion FR-S LS3
Its too late now. The hype is to big. Deleting this thread wont do a thing.
2014 scion FR-LS3 lol
wooly35 is offline
Old 08-28-2016, 06:25 PM   #591
cf6mech
Drives: FRS Silver LS1 swapped.
In the process of sending Data logs with MRS equipment to have can-bus intergration.......to be clear.....this information is for a LS1 with an 05 GM E40 ECU.......E40 ECU of another year are quite different and would require seperate logs to decipher.......And yes this is my thread not Vorshlogs......they as many others refuse to fall into the keyboard expert cross examinations of so called experts on the internet who can easily hide behind a moniker.......I dont own a business nor call myself an expert on car builds or can-bus ......but sharing my build so others who would like to learn or avoid mistakes or know the right contacts to do this as well will have the resources.
cf6mech is offline
The Following 5 Users Say Thank You to cf6mech For This Useful Post:
Aaronimoe (08-28-2016), djjd42 (08-28-2016), Draco_PR23 (08-29-2016), Nickosport (08-29-2016), Zer0 (08-29-2016)
Old 08-29-2016, 10:26 AM   #592
MRS-Colin
Drives: 2001 Impreza 2.5 RS
...and I've got about everything I need from them so far
Colin Beck
MRS-Colin is offline
The Following User Says Thank You to MRS-Colin For This Useful Post:
cf6mech (08-29-2016)
Old 09-13-2016, 12:15 PM   #593
MRS-Colin
Flight booked to TX to do final testing and integration into Rick's car.
Colin Beck
The Following 13 Users Say Thank You to MRS-Colin For This Useful Post:
8686 (09-13-2016), ATL BRZ (09-14-2016), Calum (09-13-2016), carbonBLUE (09-13-2016), cf6mech (09-13-2016), civicdrivr (09-14-2016), Floggin Tires (09-13-2016), kch (09-13-2016), MaximeT (09-13-2016), Nickosport (09-14-2016), Sportsguy83 (09-14-2016), wooly35 (09-13-2016), Zer0 (09-13-2016)
Old 09-13-2016, 06:02 PM   #594
Zer0
Drives: 2015 frs
Good to hear more progress is being made. Keep the updates coming.
Zer0 is offline
Old 09-13-2016, 08:08 PM   #595
cf6mech
Done a lot of little things to the car......Texas heat is nasty and have been focused on cooling things down.
cf6mech is offline
The Following User Says Thank You to cf6mech For This Useful Post:
Old 09-13-2016, 08:21 PM   #596
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
I'll be waiting for a full disclosure of the little details and all.
BTW I'm excited for how far you come along, good choices and congratulations on where you're at.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline
The Following User Says Thank You to Floggin Tires For This Useful Post:
Old 09-13-2016, 10:40 PM   #597
Zer0
Drives: 2015 frs
Is the mishimoto radiator adequate or are you looking for a better radiator for your swap?
Right now I'm going to manual brakes. I got the dual circuit master cylinder, fabed up a adapter plate, actuator rod ,and changed the pedal ratio. I removed the abs block retaining the electronics that were attached to the block. Just need to fab up the lines to complete brakes.
Redoing the wire harness in the engine compartment to get more room and clean it up a bit. Next I want to move to cooling components, and then fuel system. I already removed the spot welds for the old mounts on the Cross member and the tunnel. @#$& I need to start a build thread.
Zer0 is offline
Old 09-13-2016, 10:49 PM   #598
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Lsx swap thread with emblem mods?
Shame..
SHAME!
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline
Old 09-13-2016, 10:54 PM   #599
cf6mech
Actually I was thinking about what your doing with the brakes......still holding out for the slight chance ABS will ever work......the radiator is a Mishimoto.....right now it seems to be working......I had oil temp issues running it hard.....oil cooler and a good one is a must.
cf6mech is offline
Zer0 (09-13-2016)
Old 09-13-2016, 11:23 PM   #600
Zer0
Drives: 2015 frs
I pulled the ABS fuse immediately after hearing about "ice mode" I will give a review of the brake setup after the swap is done and running. Weather it turns out good or bad I will give a honest review, and what if any adj were made. I may be out that way in October next year if you haven't done it by then so you can feel it in person.
Thanks for the heads up on the oil cooler. I have a Setrab oil cooler sitting at the house now. Time to start designing and fabricating brackets i guess.
Zer0 is offline
Old 09-13-2016, 11:28 PM   #601
Zer0
Drives: 2015 frs
Shame..
SHAME!
What's a emblem mod?
Zer0 is offline
Old 09-14-2016, 12:54 AM   #602
cf6mech
Nevermind!
cf6mech is offline
Thorpedo (09-14-2016)
Search this Thread:
Advanced Search
FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates Steeze_Its Brakes, Suspension, Chassis 7 06-27-2014 10:32 PM
FS: Vorshlag Front Camber Plates h4nh Brakes, Suspension, Chassis 1 03-01-2014 11:49 PM
FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) serial gixxer Brakes, Suspension, Chassis 18 05-20-2013 09:51 PM
WTB: Front Vorshlag Camber Plates YDNA Brakes, Suspension, Chassis 0 05-03-2013 06:31 PM
Maybe a repost, but have you seen the Vorshlag project car? Bart1 BRZ First-Gen (2012+) -- General Topics 3 01-07-2013 02:19 PM
