Old 09-16-2015, 10:45 PM   #393
cf6mech
Drives: FRS Silver LS1 swapped.
Originally Posted by modernbeat View Post
We will put together a FAQ for the BRZ like we did for the BMW E36 that will contain those part numbers. The front accessories aren't a buy-and-bolt solution. We made a couple custom parts to make it all work right. I'd imagine we will package those parts for the swap also. We are starting to build some competition cars with electric assist steering swapped into them, so I expect they will have the same accessory kit except for the AC parts.
Jason you have a PM
cf6mech is offline
Old 09-18-2015, 03:37 AM   #394
Zer0
Drives: 2015 frs
You will be getting my business hopefully after my suspension and brakes are completed you will have everything ready to go.
Zer0 is offline
Old 09-18-2015, 04:47 PM   #395
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
This-----> http://www.jegs.com/i/Blueprint-Engi...ductId=1647808
Plus this-----> Vorshlag LSX kit
Would equal and
IceFyre13th is offline
Old 09-20-2015, 07:16 AM   #396
JTOFJPN
You're like the...
JTOFJPN's Avatar
Drives: '13 6MT FRS / '14 Ram 1500 Sport
Read through the whole blog and posts here... Maybe I missed it but will this kit be compatible with only LS1/LS2? It sounds like due to money constraints on the owner the kit will not be developed with the LS3 in mind? Can you speak to this at all or give insight into how much harder it would be to use a LS3 + your kit as opposed to a LS1/2 hybrid like you have?
Thanks & I'm looking forward to more info as this kit progresses! Ahem, pricing/timeline.
2013 Whiteout 6MT FR-S
2014 Ram 1500 Sport
JTOFJPN Build Thread
JTOFJPN is offline
The Following User Says Thank You to JTOFJPN For This Useful Post:
CxG (10-26-2015)
Old 09-20-2015, 03:08 PM   #397
djliquidsteele
Drives: Scion FR-S
Which LS you choose shouldn't matter. They should all mount up the same.
djliquidsteele is offline
The Following User Says Thank You to djliquidsteele For This Useful Post:
CxG (10-26-2015)
Old 09-20-2015, 04:23 PM   #398
boomslang
Drives: Toyota
Just a thought:
Emtron Australia has the FR-S/BRZ CAN conquered.
One of their offerings is a "budget" SL8 box for about 30% of the cost of a Motec.
This way you would not have to have a GM ECM, Subaru ECU, and a CAN translator/hack device in the car to run an LSX swap.
boomslang is offline
Old 09-21-2015, 05:10 AM   #399
JTOFJPN
You're like the...
JTOFJPN's Avatar
The problems I see is the intake tubing/throttle body... the ECM controls and it's ability to connect to their future black-box setup. Among other small things they mentioned were LS1/2 specific in their blog (accessories on front of motor, etc).
2014 Ram 1500 Sport
JTOFJPN is offline
Old 09-21-2015, 08:31 AM   #400
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
All of those parts are interchangeable, the bore doesn't matter.
Sent from my XT1095
Parting out HERE
civicdrivr is offline
The Following User Says Thank You to civicdrivr For This Useful Post:
CxG (10-26-2015)
Old 09-21-2015, 11:51 AM   #401
modernbeat
Vorshlag R&D
modernbeat's Avatar
Drives: A new one every month
Any of the non-EGR intakes should work. The EGR compatible intakes have a longer neck for the throttle body that could interfere with the stock hood.
Jason McDaniel at Vorshlag Motorsports
modernbeat is offline
The Following 3 Users Say Thank You to modernbeat For This Useful Post:
bumppinKota (09-21-2015), civicdrivr (09-21-2015), CxG (10-26-2015)
Old 09-26-2015, 02:27 PM   #402
Newfoundland_scion_frs
Drives: 2013 Scion FR-S,and more :)
Edit:found the answers to my questions after more research so no need for me to waste your time with questions I already know the answers too.
Thanks
Last edited by Newfoundland_scion_frs; 09-27-2015 at 09:15 AM. Reason: Found the answers to my questions
Newfoundland_scion_frs is offline
Old 10-13-2015, 10:33 PM   #403
Arrowsmith
Drives: walking...L-O-L
Smile Any Updates?
Any updates on this? I'm really digging the project and the workmanship!
Arrowsmith is offline
Old 10-13-2015, 11:49 PM   #404
cf6mech
Back in their shop now for sway bar development and can bus to follow.
cf6mech is offline
The Following 2 Users Say Thank You to cf6mech For This Useful Post:
civicdrivr (10-14-2015), Draco_PR23 (10-14-2015)
Old 10-13-2015, 11:51 PM   #405
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
^ sounds good.
How that transmission feeling?
Miles?
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline
Old 10-14-2015, 05:20 AM   #406
cf6mech
Interesting pod cast with Slip Angle with Terry Fair from Vorshlag Motorsports and the FRS engine swap, and in manys opinions, why they are the best at what they do.
http://shoutengine.com/SlipAngle/ter...orsports-12976
cf6mech is offline
Search this Thread:
Advanced Search
FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates Steeze_Its Brakes, Suspension, Chassis 7 06-27-2014 10:32 PM
FS: Vorshlag Front Camber Plates h4nh Brakes, Suspension, Chassis 1 03-01-2014 11:49 PM
FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) serial gixxer Brakes, Suspension, Chassis 18 05-20-2013 09:51 PM
WTB: Front Vorshlag Camber Plates YDNA Brakes, Suspension, Chassis 0 05-03-2013 06:31 PM
Maybe a repost, but have you seen the Vorshlag project car? Bart1 BRZ First-Gen (2012+) -- General Topics 3 01-07-2013 02:19 PM
