#491 |
Drives: UK GT86
Open the Idle Speed Target tables and increase anything lower than 750 to 750.
.: Stealth 86 :.
#492 |
Drives: 2014 Argento FRS
#493 | |
![]() If I may ask why are you changing the idle?
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | SoCalArgento (03-30-2016) |
#494 |
Thanks for the info @FRSBRZGT86FAN
I got lightweight flywheel with clutch and idle has dropped to ~700rpm and drops slightly more when using a/c and rear defroster. Just trying to raise it a tiny bit to compensate rpm to stock rpm. Sent from my iPhone using Tapatalk |
#495 | |
Hmm... I think there may be more compensation than just the idle tables for when a/c kicks on or a high power draw @steve99 would probably know, Try the tables regardless it doesn't hurt.
#496 |
I'll give this a try for the time being and thanks for screen shooting rr.
#497 | ||
when you put on lightweight flywheel\clutch assemblies its upsets the ecu idle compensations as it now lower mass and it can over and undershoot . The whole idea of a flywheel is to smooth out the rotation of the engine firing pulses. |
#498 | |
Yeah I suspected it would include numerous tables. I changed the idle control tables as mentioned above and it has helped. This is only a temp fix for the time being as I'm going s/c with EcuTEK and hoping tuner can adjust idle more meticulously. |
#499 |
Drives: Wrb 2014 limited brZ
Is it safe to run Jdl uel CATTED header with stage 2?
#500 |
The Stig's German cousin
#501 |
#502 |
Drives: 2013 Fr-S UltraMarine
keep getting this message..tried to reset the ecu by removing negative terminal. And still ecu is in recovery mode. Any other suggestions besides taking it to dealer to figure out my ecuSent from my SM-G920V using Tapatalk |
#503 |
[EUROBEAT INTENSIFIES]
Drives: 2015 Scion FR-S Steel
Having an issue with my OFT/Open Flash Manager.
I guess there was an update on the OTS tunes since it has been a while. (I had V 2.074) I downloaded the new tunes and unzipped them. Plugged it into my laptop and ran Open Flash Manager. Let it do it's thing and attempted to upload an updated EL Stg 2 E85 tune but it gave me an error. I'm sending this from work so I don't have a screen cap. I even tried adding a .bin file from v2.074 and it wouldn't work either. Anyone have this issue before?
![]() Last edited by TheMedakaBox; 04-10-2016 at 03:27 AM. |
#504 | |
![]() Here is my error message. What do? Sent from my XT1254 using Tapatalk
| WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 08:13 PM |
| Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 09:27 PM |
| FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 03:08 PM |
| FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 03:49 PM |
| Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 08:14 PM |
