#15 | |
Drives: Whiteout FR-S
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#16 | |
It'll even read pedal position, steering angle, wheel speed sensors, etc. |
#17 | |
I totally agree that seeing 270F regularly on a Subaru motor will decrease the life of the engine dramatically. |
#18 |
Drives: WRB BRZ Series.Blue
Thanks for the helpful insight.
I'm not pushing the car hard yet.. but I eventually will. I'll start looking into oil coolers and watching my oil temps closely with the OFT on harder driving sessions. I'll also put the AiM SOLO DL on my wish list soon! |
#19 | |
The point is to simulate the RPMs of hard driving, as RPMs are the primary influencer on oil temperatures. Watch how quickly and how high your oil temps get. Alternatively, just sit on the highway at 70-75mph in 3rd gear for even just 60 seconds, and watch the temp. |
| The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
#20 |
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
So I was curious and I called Mobil to ask them about the 0W20 oil itself and what it likes for temperatures. Their tech guys said ideal operating temperature is down at 212F. It is TESTED to waaaaay above that (up to 500F) and will work fine at 300F, but the ideal being 212F does lend additional validity to the desirability of adding an oil cooler to the engine.
#21 | |
Sounds like they gave you a sales pitch, rather than data. |
#22 | |
Drives: 2013 GBS BRZ Limited
1 - Lower oil temperatures = Higher oil pressures 2 - You want your oil as cool as possible (to keep the pressures up), but no lower than 212 for extended periods to assure that water is boiled off. Water vapor is a by-product of combustion, so it gets into the oil from the blowby. So get an oil cooler, but get one that includes a thermostat. |
| The Following User Says Thank You to stugray For This Useful Post: | litemup (08-13-2014) |
#23 |
Drives: Dodge Stealth
Quality oils will maintain their lubricating properties and enough viscosity to keep your pressure up at high temps but, like already mentioned, it's far from ideal. It varies depending on who you're talking to/application/oil but personally I start to worry if my oil temp (on any car) gets above the 260ish region. I also change my oil right after a track day, especially if I'm hitting temps like that.
With that said we have a new oil cooler kit that should help you guys out: http://store.maximalperformance.com/...i-1981916.aspx |
#24 | |
Drives: 2013 Black FR-S
#25 | |
-Mike Paisan ![]() Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
#26 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | AZP Installs (08-11-2014) |
#27 | |
| The Following 2 Users Say Thank You to AZP Installs For This Useful Post: | CSG Mike (08-11-2014), Tt3Sheppard (08-12-2014) |
#28 |
We do use the 13 row 613 Setrab core and the thermostatic Mocal sandwich plate. We're working on getting track numbers. This is the combination that we thought would work best for the everyday/occasional track guys and were catering to the mass market more than the hardcore heavy track use guys. In hindsight this may have been the wrong thread to post this in considering. :p
With that said this kit uses high end components and should put a decent dent in the oil temps (track testing to come to back that up). If one of you guys would like to work with us to develop a HD track-ready cooler I'm up for it and can give you guys everything for our cost in exchange for testing. Just let me know. |
| The Following User Says Thank You to Maximal For This Useful Post: | CSG Mike (08-12-2014) |
| Should I be worried ? | Brooklyn | BRZ First-Gen (2012+) -- General Topics | 8 | 03-12-2014 01:18 PM |
| No CEL Should I be worried?? | Mr.Jay | Issues | Warranty | Recalls / TSB | 5 | 04-05-2013 11:51 AM |
| a bit worried | MontrealFRS | Issues | Warranty | Recalls / TSB | 7 | 09-14-2012 07:46 PM |
| 5k oil change, worried about changes.... | bloomy116 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 09-11-2012 09:23 PM |
| Anyone worried about not fitting in the car? | budakajana | AUSTRALIA | 35 | 06-27-2012 08:55 AM |
