Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 07-30-2014, 07:07 PM   #43
FV
FV's Avatar
Drives: 2007 Honda S2000, 2013 BRZ LMT
Claim adjuster here
If this was my claim and I saw the footage, I would put the other vehicle at fault. We look for the proximate cause of the accident, which would be the lane change not you speeding down. Plus we can't see your speedometer anyways, who is to say you were driving faster than the speed limit. Good luck, every claim adjuster is different though.
The other car didn't look before changing lanes, if they did they would have noticed your speed and not initiated the change - insurance logic.
Last edited by FV; 07-30-2014 at 07:10 PM. Reason: Noticed light turned red, decision still remains the same
FV is offline   Reply With Quote
The Following 8 Users Say Thank You to FV For This Useful Post:
Braces (10-15-2014), chas3wba0 (07-30-2014), Giccin (10-14-2014), litemup (07-30-2014), Marchy (07-30-2014), RIP.S2000 (08-11-2014), skeet (07-30-2014), Sojhinn (07-31-2014)
Old 07-30-2014, 07:18 PM   #44
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
Yeah, I'd say the SUV is at fault (typical SUV driver no-look, no-signal bullshit driving), but there's no way in hell you'd have made that light. The only good news is that it looks like if when you ran the red that nobody'd have been able to T-bone you since the left turn lanes for the road you were on activated. Hopefully people across from you would have seen you and delayed their lefts.
Also, when in doubt, mash the shit out of your brake pedal. ABS is there for a reason. Don't wait for someone else to do something smart to avoid a crash (they won't). Even if you get rear-ended as a result, at least it's their fault and not yours.
Ganthrithor is offline   Reply With Quote
The Following User Says Thank You to Ganthrithor For This Useful Post:
Old 07-30-2014, 07:26 PM   #45
chas3wba0
chas3wba0's Avatar
Drives: Yes
Originally Posted by FV View Post
Claim adjuster here
Thanks for the insight; I just spoke to my adjuster on the phone and he said pretty much the same thing. Not gonna assume I'm in the clear yet, but in any case, I'll remember that I likely could have avoided the accident entirely if I'd slowed down with everyone else. Lesson learned
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 07-30-2014, 07:26 PM   #46
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
you are not allowed to accelerate through a yellow light...
Originally Posted by chas3wba0 View Post
Judging from the engine sound, I don't think I can deny that I got on the gas a little bit when it turned yellow. Just not sure if it's a valid reason to pin any fault on me in this case... yes, I'm just fishing for confirmations here
It is illegal to accelerate through a yellow light; however, you did not pass the white lines at the light, so you had not done anything illegal or that would make you at fault in this situation as far as I can tell.
It was the other cars responsibility to ensure he had plenty of room to change lanes. I would say it is his fault or a no fault.
Jaden
Jaden is offline   Reply With Quote
The Following User Says Thank You to Jaden For This Useful Post:
Old 07-30-2014, 08:42 PM   #47
Ubersuber
Drives: BRZ Pearl White
I don't think you were at fault even if you would have run the red illegally. Your illegal intent does not absolve the actual illegal action of the negligent driver.
It is only illegal to fail to stop for a yellow light if you are able to do so "safely".
If someone ahead of you in the adjacent lane stops then that is some evidence (not conclusive) that you could also have stopped. However, if you are going faster than that other person then what applied to them may not apply to you. It is a judgment call which is why there are no yellow light cameras, only red light cameras. Running a red is always illegal, and rightly so.
A lane change that results in a collision is almost always 100% the fault of the lane changer. If someone in front of you stops for a yellow light you MUST be able to also or you are following too close. Changing lanes in order to avoid having to stop is illegal. Changing lanes at the last minute so as to stop at the red in the front of the line is stupid and usually illegal if traffic is using that lane and approaching the light.
It is not illegal to enter an intersection against a yellow light even if you are speeding unless you could have stopped safely before you reached the intersection. The speeding is illegal but not "running the yellow". It is not illegal to speed up and enter on the yellow unless as an alternative to speeding up was the ability to stop safely. It isn't always safest to brake, occasionally acceleration is safer, even to speeds above the speed limit or otherwise "safe speed".
Finally, I have noticed that our little cars are so low and so small that many drivers of big vehicles apparently fail to notice us. Legality is ALWAYS secondary to safety.
The phrase is: he was right, dead right in fact.
Ubersuber is offline   Reply With Quote
The Following User Says Thank You to Ubersuber For This Useful Post:
Old 07-30-2014, 09:30 PM   #48
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
That's an unsafe lane change on Pilot's part. He should have used his signal yet no changing of lanes should happen at the intersection but he was theoretically not in the intersection when he changed lanes. Yet speeding up toward the light when driver in other lane is stopped. It's a toss up. Lucky you didn't hit the Ford.
AVodka14 is offline   Reply With Quote
The Following User Says Thank You to AVodka14 For This Useful Post:
Old 07-30-2014, 10:29 PM   #49
AznBRZer
Drives: 16 CBS WRX Limited
OP should've eaten more pork buns.
[ame="https://www.youtube.com/watch?v=8tFiRPLOQRc"]pork bun - YouTube[/ame]
AznBRZer is offline   Reply With Quote
Old 07-30-2014, 10:37 PM   #50
retoocs
Not true. There are no CVC's that says it is illegal. Yellow light just means stop if you can, proceed with caution if you can't.
retoocs is offline   Reply With Quote
Old 07-30-2014, 10:55 PM   #51
chas3wba0
chas3wba0's Avatar
Drives: Yes
LOL I just started playing that game
Old 07-31-2014, 12:29 AM   #52
Jaden
Road-hole
From what I understand... the law is a bit vague...
The law varies from state to state, I'm not sure what state the op is in...
In California, as long as you didn't accelerate and your front wheels are past the white line before the light turns red, you are good. I believe the vehicle code only references being past the white line before the light turns red
Jaden
Old 07-31-2014, 12:58 AM   #53
retoocs
Jaden
Op is in San Ramon.
CVC 21453a only states you have to stop at the marked limit line on a red light. Nothing about yellow light. A cop can't write you a ticket for going through a yellow, no CVC.
Even the DMV video states you can go through a yellow.
[ame="https://www.youtube.com/watch?v=SJjhQyU0Wlw&t=0m20s"]California DMV - Rules of the Road #7 - Signal Intersections - YouTube[/ame]
The Following User Says Thank You to retoocs For This Useful Post:
chas3wba0 (07-31-2014)
Old 07-31-2014, 01:43 AM   #54
Pete156
I like to eat!
I'm going to rant on YOU. You were driving like a douche. You were in the left (fast) lane during most of the video. Yes even city streets have a fast lane. You were being passed by cars in the slower lanes during most of the video. The only time you appeared to accelerate was when the light turned yellow and the other driver turned into your lane (legally with his signal on). Your reaction time was that of a sloth.
If I were the judge you'd be in drivers education class.
Rant over.
Pete156 is offline   Reply With Quote
The Following 3 Users Say Thank You to Pete156 For This Useful Post:
chaoskaze (07-31-2014), glamcem (07-31-2014), Mini Cooper S (10-16-2014)
Old 07-31-2014, 06:17 AM   #55
chas3wba0
chas3wba0's Avatar
Drives: Yes
Rant over.
Ah yes, I've been expecting you. Thanks for your input, but half the shit you said isn't even true/relevant, so I'll kindly elaborate for you:
I live in this town and drive this road daily. I know whether or not people here consider the left lane a "fast lane", and they don't. Most people just speed past 50 in the 45mph zone in any of the three lanes available. You should see me on actual highways... I abide by the left-lane-for-passing-only rule like you wouldn't believe.
This time in particular, there was a cop right in front of me, meaning everyone is driving 5 under. I'm keeping up just fine with traffic until we start going down the hill. There, I shift to 4th and use engine braking to maintain ~40mph going down the hill--as I always do--while everyone else bombs the hill and rides their brakes the whole way (forgive me for trying to be efficient).
And no, the other driver did not signal. Try watching in 1080p.
Old 07-31-2014, 09:46 AM   #56
kevman_101
Drives: 2013 Scion FRS
Tell them you were heal toeing a downshift. Made it sound like you accelerated, but actually downshifting to slow down .
kevman_101 is offline   Reply With Quote
The Following User Says Thank You to kevman_101 For This Useful Post:
Search this Thread:
Advanced Search
Brake Light Switch Fault - TSB Fix Dezoris Issues | Warranty | Recalls / TSB 2 01-21-2018 03:39 AM
Brake Switch Fault | TSB FIX Dezoris Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-11-2014 11:11 PM
MOAR fault codesss! jonbonazza Engine, Exhaust, Transmission 2 09-20-2013 03:47 PM
Torque fault codes help derka-derka Issues | Warranty | Recalls / TSB 2 05-24-2013 10:07 AM
CEL/Idle Fault - Toyota GB Statement Kodename47 Issues | Warranty | Recalls / TSB 5 10-25-2012 09:27 AM
