#1023 |
Drives: 2013 Scion FRS
I just want the kraftwerks kit. And I also want to keep using oft
ScreamingElectron - SnakeShit |
#1024 |
Drives: UK GT86
Then you need an SD patch for your ROM.
.: Stealth 86 :.
#1025 |
Aggree with other guys re tune it made for the specific kit only
as the charasteristics of the SC will be different and the maf housing will be different and the vortech kit requires a MAP sensor change to 2.5 bar omni sensor so the tune is only suited to that kit. This will be same deal for the oft turbo kits you need to use exact same components made for the tune. |
| The Following User Says Thank You to steve99 For This Useful Post: | Lokenzi (12-22-2015) |
#1026 |
It's gonna be a pain. But on the bright side maybe it's something I could donate to shiv
#1027 |
Not A Member
Drives: 2014 Mustang GT
Can you use the OFT with the Jackson Racing kit?
#1028 |
If I'm not mistaken, its practically the same thing. There is no tune for it on OFT
#1029 |
So yeah...Anyone have any ideas on what TuneBot is? I have this imagination in my head that it's a program that revs your motor while taking measurements and develops a working tune for whatever you've got.
Running out of options here on tuning the supercharger.
#1030 | |
Running out of options? Pretty much no tuner besides Shiv tunes with OFT. Your ONLY option is ECUTEK or something much more expensive. |
#1031 |
Eh I'll just tune it myself with OFT.
#1032 |
Drives: UK GT86
In that case I would recommend using the Vortech tune as a base but be aware you'll need to change quite a bit to do with fueling etc. It won't be a case of shoving it on and seeing if it runs. However I would expect the stuff like AVCS to be good enough, which is pretty much why I'd use it. A decent front O2 scale will also be a must.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | riboyster (12-26-2015) |
#1033 |
So what would the big changes be? O2 and MAF scale? Would timing change at all? AFR?
(I shot the idea of buying one at the fiancee [now that I can afford it after tons of overtime] and she gunned me down with the wrath of the Red Army) Blah blah blah....wedding...moving fees....wedding...spending time together blah blah
#1034 | |
Drives: UK GT86
- O2 sensor scales can be found on here, there's a good thread somewhere by @ztan - Reduce timing everywhere above loads of 1 - MAF scales changes to make it run richer - Tune closed loop MAF - Tune open loop fuel - Add timing as required Don't get caught up in chasing a perfect MAF scale in open loop. It'll be a lot of test and tweaking.
.: Stealth 86 :.
#1035 |
Drives: 2016 Oceanic FR-S
Hey guys, I just got OFT for xmas. I have a newer FRS and it has the F00C stock rom. I saw a RomRaider file for it but I want to be sure I'm doing things right and not being naive. Could someone help me get OFT working right? I'm going to be running 92 octane 95% of the time and I have the UEL OFH, TRD washable filter, and the TRD muffler. I already sent oft an email, but being xmas time I figure it'll be a minute before they get back to me. Thanks in advance for any help!
#1036 |
You'll want the F00C Stage 2 91 octane tune to start.
Once you get an idea of how to use OFT, you can start looking back into this thread. There's a lot to learn here on tuning. It's a mindf**k at first, but not too bad once you get used to it.
| The Following User Says Thank You to riboyster For This Useful Post: | Akya2120 (12-27-2015) |
| OpenFlash Tablet v1.42b maps now available | Shiv@Openflash | Software Tuning | 159 | 09-13-2016 01:29 AM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 06:23 PM |
| OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted | Shiv@Openflash | Software Tuning | 142 | 07-22-2014 11:21 PM |
| Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 05:43 AM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 09:45 PM |
