#981 |
Drives: 2013 Scion FRS
After the next tune, there will be no flkc past 0.9. So why am I still dropping IAM?
ScreamingElectron - SnakeShit |
#982 | |
aeiou
Drives: WRB BRZ
If your battery completely dies, do you need to reflash the maps? Or just let it idle for a few mins to readjust before driving?
My car was running on E85 and has been sitting for a while.
#983 |
Unless your battery dies in the middle of flashing, it won't affect your tune.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#984 | |
Drives: WRB BRZ Series.Blue
This means the ECU is pulling timing. The ECU will keep the timing pulled until a certain amount of time, then start slowing adding timing again in the troublesome areas, until it starts knocking again, or until it adds max timing. Note that IAM won't immediately go back to 1, as it'll need to continue adding timing in troublesome areas until you reach max timing again. You need to log at minimum IAM, and KC values. FLKC is useful when you are toying with rpm & load to try and trick the ECU to knock, or add back timing. |
| The Following User Says Thank You to cookiesowns For This Useful Post: | riboyster (12-06-2015) |
#985 | |
The ecu uses some calculation to look at fbkc and flkc to determine when it will drop iam or increase iam. It apoears to look at the magnitude of the knock and the frequency and duration of the events. You can get the odd spike of say -2 flkc and not drop iam but if you get repeated events of even -0.6 in quick sucession it may drop iam. It then looks for knock free or minimal knock passes through the rpm load areas where its seen knock events previpously to determine if it will increase iam. you can often get your iam back to 1 by doing a number of light steady throttle say 15% throttle runs in second or third from 2000 to 5500 or so. At light loadsecu wont see knock and will increment iam back towards one |
| The Following User Says Thank You to steve99 For This Useful Post: | riboyster (12-06-2015) |
#986 |
Awesome, thanks for both responses. Exactly what I needed to know.
#987 |
Drives: 2013 FRS- Hot Lava
Some help necessary here. Setup:
Open Flash OFT300 package Vortech supercharger (standard pulley) Open Flash Header Stock catback Vortech Maxflow BOV Logs: http://datazap.me/u/sirsol66hotmailc...data=1-2-10-11 Car is showing very very high fuel trims (25+) at idle and low RPM areas. Car is running completely fine but the trims are not settling. No knock at WOT pulls. Exhaust has been leak checked and no issues. I will leak check the intake side this week. One thing I noted is that the BOV is completely open at idle and moving A LOT of air. I never ran the normal vortech bypass valve so I am not sure how the maxflow compares with it. Can this be contributing to the high fuel trims? |
#988 | |
If its venting all |
#989 | |
I did notice that the car is only registering 9 inches of vacuum at idle...and that doesn't sound right. Anyone with the vortech kit that can chime in how much is normal vacuum at idle? |
#990 |
Drives: 2013 Subaru BRZ Limted
Just recently got on this OFT gravy train. Installed stage 1 93 tune and I already understand the hype. Car feels a lot smoother from 1.5k - 4.5k and then whooosh. I can definitely tell the difference, and no stutter from the gas pedal in low speed 1st or 2nd. Thanks @Shiv@Openflash
| The Following User Says Thank You to Subie_Nubie For This Useful Post: | B-R-Z (12-09-2015) |
#991 |
Finally nailed the 89 octane ethanol free tune. Thanks for the help guys. Peak hp is the same, didn't have to pull timing up there.
If anyone wants improved throttle response, better low end torque, and gasoline that doesn't decompose oil and fuel lines, let me know. Also the noisy cricket is gone.
#992 |
Drives: Subaru BRZ 2015 Sport Tech
OpenFlash Manager link is down again....... 404 error
Also OTS v2.0 Beta downloads fine but when unzipping it shows "OTS v2.0 Beta USDM only.zip: The archive is either in unknown format or damaged" Does anyone have a mirror? |
#993 | |
current tunes are 2.07 or try here http://openflashtablet.com/Automotiv...S%20v2.070.zip http://openflashtablet.com/Automotiv...ads/index.html |
#994 | |
| OpenFlash Tablet v1.42b maps now available | Shiv@Openflash | Software Tuning | 159 | 09-13-2016 01:29 AM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 06:23 PM |
| OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted | Shiv@Openflash | Software Tuning | 142 | 07-22-2014 11:21 PM |
| Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 05:43 AM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 09:45 PM |
