#939 |
Drives: 2013 Scion FRS
#940 |
Drives: UK GT86
Yes.
That doesn't mean that they are OFT or otherwise compatible. They can only be opened with ECUtek.
.: Stealth 86 :.
#941 |
Worth a try. If it works like any other image file, OFT won't have to open it to flash it.
ScreamingElectron - SnakeShit |
#942 |
Drives: UK GT86
It doesn't, it's encrypted.
.: Stealth 86 :.
#943 |
Well crap.
(I'm inconspicuously gesturing ever so slightly in the direction of my signature)
ScreamingElectron - SnakeShit Last edited by riboyster; 11-10-2015 at 04:55 AM. |
#944 | |
He could then flash the same tune to his mates car if his mate person B if they had another ecutek license, surely not ?? they check vins or some other method ? or tune is locked to dongle dongle locked to license in ecu somehow they stop people sharing tunes else they be posted up here for sharing :-) |
#945 | |
Drives: UK GT86
The reason no-one shares is: A) You'd need to send your dongle to someone with the flashing kit B) They'd still have to pay for an ECU license C) If you've gone to that expense, why get a 2nd hand tune? If I sold on all my mods to one person, I'd pass on the dongle and my tune no issue.
.: Stealth 86 :.
#946 | |
So if two guys had NA car A01G rom they could share tune but only flash with same dongle, vendors must have higher level ? so they can flash over other dongle locked tunes or can anyonbe do that with their dongle ? dont they limit number of cars you can flash with a normal dongle, heard guys have to buy vendor licience of something |
#947 | |
Drives: UK GT86
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | steve99 (11-10-2015) |
#948 |
Kay boys, do your best.
This is a run up in 2nd with the corrections to timing we were talking about. What can I do to make it better? (FYI: I slightly botched the run by not being WOT in the beginning. It's the obviously not WOT part) Originals: http://www.datazap.me/u/riboyster/pu...n?log=0&data=1 Recent: Casual Hilly Driving: http://www.datazap.me/u/riboyster/lo...k?log=0&data=1 2nd Gear Wot: http://www.datazap.me/u/riboyster/lo...t?log=0&data=1 Here's virtual dyno with accurate temps and pressure at altitude ~1200ft, with 2nd gear ratio.
ScreamingElectron - SnakeShit Last edited by riboyster; 11-12-2015 at 03:22 AM. |
#949 | |
Ok you have FLKC knock of almost -2.9 degrees between 2500 and 5000. knock less than -1 is not a big problem especially if its not dropping IAM The afr looks ok also log LTFT leave out road speed and KC learned after you re log with engine load, note the rpm/load where your getting the big knock correction ie over -1 and then pull about half the value from BASE TIMING B table at the rpm load points. see the knock correction links below unfortunately you did not log Engine Load as you need that as you need to know the rpm/loads to pull timing from. |
| The Following 2 Users Say Thank You to steve99 For This Useful Post: | riboyster (11-11-2015), tato.valverde (11-12-2015) |
#950 |
Thanks steve. I'll adjust parameters accordingly and try to do another pull tomorrow. Appreciate the feedback. Do you also have a torque dip at around 6k?
Also, when you say FLKC OVER -1, do you mean a value closer to 0, or a value closer to -2?
ScreamingElectron - SnakeShit Last edited by riboyster; 11-11-2015 at 03:55 AM. |
#951 |
btr.life
Drives: 2022 GR86
Sorry if I missed it somewhere...but, does OFT "smooth out" the rev-limiter by chance? For example, if I am in 2nd gear and hit the rev-limiter, will it "bounce" off the limiter by cutting fuel/spark (or whatever it does to cause the bouncing off the limiter)? Or, will it cruise along smoothly at the limiter with no bouncing?
Thanks!
#952 |
Having just looked at the timing table last night, I can without a doubt tell you that there is nothing smooth about the rev-limiting timing values.
They pull all timing instantly. I think your goal would be to figure out a way to max the rpm just below the limit.
| The Following User Says Thank You to riboyster For This Useful Post: | justinco (11-12-2015) |
| OpenFlash Tablet v1.42b maps now available | Shiv@Openflash | Software Tuning | 159 | 09-13-2016 01:29 AM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 06:23 PM |
| OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted | Shiv@Openflash | Software Tuning | 142 | 07-22-2014 11:21 PM |
| Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 05:43 AM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 09:45 PM |
