#911 |
Drives: WRB BRZ Series.Blue
FWIW: I just re-did my maps the other day. Running the latest D00C Stg1 with LC activated. ( was kinda fun the first time )
I decided to re-do my timing tables and just use the basic stg1 but re-mapped to using a flat 5.98 knock advance table and the car purrs compared to before. I guess the holes I plotted before along with the crazy stock KC advance wasn't that great.. When i was running stg1 OTS though, it would knock pretty bad. Now it's great, even ragging on it, it's anywhere from 0.89-0.95. For those having knock issues, I'd try re-mapping your timing tables to use a flat knock advance table as recommended by Wayno in his guide to see if that helps you. |
#912 |
Drives: 2013 Scion FRS
Interesting. I may end up trying this flat knock advance as well. Still been monitoring the IAM on 89 Oct, still doing okay. Good to know there are options.
ScreamingElectron - SnakeShit |
#913 | |
#914 |
So how are we looking in terms of power output with the new knock tables? Obviously a little less than a knock free tune. But how much?
#915 |
actually if you smooth the timing and remove the little spikes that cause the knock you actually dont loose any power just the knock. and by adjusting the di\pi you can run more timing even on lower quality fuels
#916 |
You're a brilliant man Steve. Thanks.
I'll reflash tomorrow, romraid tonight. EDIT: random question: does AVG. MPG stop at 29.0? Haven't moved from there in like a month.... Last edited by riboyster; 11-06-2015 at 02:23 AM. |
#917 |
i think the instantaneous mpg is sent to dash from ecu then the dash calculates the average mpg. no it should not stop or stick, try cleareing it with dash buttons, select then hold for a coupke of seconds.
#918 |
Interesting. Didn't know you could do that. Thanks again!
#919 |
Drives: UK GT86
I reckon that would suggest that that is your average then. If it's a long term average it is more likely to settle at a figure and not move very much unless drivig styes change.
.: Stealth 86 :.
#920 |
That's what I was thinking. Either that, or it doesn't go below 29. Haha
#921 | |
Drives: 2015 Subaru BRZ Series.blue
Sent from my HTC One M9 using Tapatalk
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks. |
#922 |
Mine has been getting lower ever since I bought the car nearly 3 years ago.
But lets not get off topic.
| The Following User Says Thank You to riboyster For This Useful Post: | Strife26 (11-06-2015) |
#923 |
Drives: 2014 GT86
I did reset after each tank during first year. Simply to familiarise with average mpg at different weather conditions, with AC on and off, and to compare that calculated number to what real mpg is from how much really fuel used and distance driven. From litres filled up till full (and knowing real capacity of tank), i also checked how much volume left in tank when reserve light lits up, so i can somewhat better guesstimate how long i still can once low fuel indicator warning in on.
I may do real mpg check again, when some performance bolton upgrades will be installed and tune applied for interest/comparison sake. BTW, it's nice feature to have two odometers, Trip A & Trip B ones. I usually reset A to evaluate mpg between fillups, and reset B one once low fuel warning is on, to not travel too long with limited fuel left. And yes, sorry for continuing offtopic.
| The Following User Says Thank You to churchx For This Useful Post: | Strife26 (11-06-2015) |
#924 |
Drives: 2014 BRZ sterling silver
Ordered my OFT Thursday the 5th got it on sat the 7th. Flash with the 2.0 93oct stage 1 b01c.bin. Just got back from driving it only 5 miles and what a difference the dead spot is nothing like it was it feels more like a Honda v-tech. except its not dead on the bottom it pulls good till about 4 grand then it screams. great job SHIV
| The Following User Says Thank You to oldgunfan For This Useful Post: | Strife26 (11-07-2015) |
| OpenFlash Tablet v1.42b maps now available | Shiv@Openflash | Software Tuning | 159 | 09-13-2016 01:29 AM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 06:23 PM |
| OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted | Shiv@Openflash | Software Tuning | 142 | 07-22-2014 11:21 PM |
| Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 05:43 AM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 09:45 PM |
