#883 |
Drives: 2013 Scion FRS
Been using 92oct e10, and my IAM is steady. Not sure who my gas station sources from, but it ain't anything special
ScreamingElectron - SnakeShit |
#884 |
Alright, logs are ready. This fuel is 1/4 93oct e10, and 3/4 89oct e0, so it's not perfect. But I do have numbers. I WAS able to get the IAM down to 0.88 at one point by driving hills in 4th, but it quickly snapped back to 1 within 2 minutes.
First log is casual driving on my way to the highway, slight hills. Nothing too exciting. Second log is a shoddy WOT in 3rd from about 3000 rpm (if I recall correctly). Third log is casual driving after work at mid afternoon temps up the highway on a slight grade. Note that I got the IAM to move about 10 minutes after the 3rd log took place. Knock correction experienced once on the last log while upshifting into 5th. Happened again once later. All driving was performed on Stage 2 (91oct) tune. Tell me what you guys think here... http://datazap.me/u/riboyster/casual...g?log=0&data=1 http://datazap.me/u/riboyster/pull-3...r?log=0&data=1 http://datazap.me/u/riboyster/casual...2?log=0&data=1 Last edited by riboyster; 10-09-2015 at 02:36 AM. |
#885 | |
Drives: Toyota 86 GTS
It's running rich after 3.6 MAFV. You'll get more power copying the maf scale from Stg1 or the scale in the Stg1 rom I uploaded.
#886 |
Interesting. You have that prob on your car?
#887 |
Drives: JAWS
I did. I'm running a custom scale very close to the stage 1 scale, got my AFR much closer to commanded AFR. (Which you should log in the future).
You should also try Wayno's smoothed stage 1 scale. |
#888 | |
Drives: FR-S Whiteout
That lean spot in the 2nd log looks familiar. I assume you applied Wayno's load limit tables? What's your exhaust setup?
Intent > Content
cowardice is the mother of cruelty. |
#889 | |
PLEASE POST LOGS IN THE DATA LOGS THREAD, NOT THIS ONE. It's annoying as fuck. |
#890 |
Have you successfully modified the IAT compensation tables to have stable AFR under OL operation? I'm going to try to get that figured out so I dont have to run the tunes so rich just so I don't lean out with hot intake temps.
Intent > Content
#891 |
No, there's far more important things for you to spend time on before that. You shouldn't be getting hot intake temps unless the car in not moving and it's heat soaking. It will be impossible to calibrate anyway unless the rest of the tune is completely stable ie static.
#892 | |
Intent > Content
#893 | |
Also, you got a link?
#894 |
#895 |
Okay thanks guys. I'll probably get to it this weekend.
Actually, just did the modifications now. Pulled the load limits from Wayno's stage 2 uel, and the MAF from stage 1. I was trying to get those neat-o radiator fan values, but they won't copy over. Also kinda interested in the cold start. AFR likes to linger at about 0.4 less than commanded.
ScreamingElectron - SnakeShit Last edited by riboyster; 10-09-2015 at 04:36 PM. |
#896 | |
| OpenFlash Tablet v1.42b maps now available | Shiv@Openflash | Software Tuning | 159 | 09-13-2016 01:29 AM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 06:23 PM |
| OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted | Shiv@Openflash | Software Tuning | 142 | 07-22-2014 11:21 PM |
| Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 05:43 AM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 09:45 PM |
