86WORX
Old 10-02-2015, 05:32 AM   #869
steve99
Originally Posted by riboyster View Post
Okay thanks. Ive already got borlas on. Just trying to figure out how to maximize power until I can afford my turbo.
Easy tune drop in air filter (skip intakes) and E85 fuel if you have it available and catless header (like you have)
worth about 25-30hp at wheels that about as good as you get NA, about 10hp less for petrol especially if its 91
Old 10-02-2015, 05:38 AM   #870
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
I guess I'm about maxed out then. Hahaha. Well thanks for the insight man. I'll get to the drop in filter one of these months. I've read that the stock intake works fine as far as cold air goes.
I'm in Maui though, and there's not much cold air here anyway :P
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 10-06-2015, 04:37 AM   #871
8686
8686's Avatar
Drives: 86
Dear @Shiv@Openflashtablet ,
I have sold my OFT to my freind and before shipping I was trying to erase my data and tunes (un marry the device) but it is not accepting.
Please can you help us.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 10-06-2015, 04:45 AM   #872
steve99
See the oft tips link below to unmarry the tablet you must
1. Current user must write the STOCK tune back to their car using tablet from the original file slot in tablet.
2.Once Current owner has written back stock tune the tablet can be erased, computer that tablet is connected to for erase MUST be connected to internet so the erase count can be checked.
3. Tablet should nor erase, if not you will need to contact openflash guys by phone or email to reset the erase count they will need you oft serial number.
4. new owner canoot perform these steps must be done on current owners car.
Old 10-06-2015, 05:46 AM   #873
8686
8686's Avatar
Drives: 86
Step 1 and 2 are done
I have sent shiv email with serial number and waiting for his reply to reset the count. My OFT tablet is very old so it has been on 2 cars only.
Sent from my 86 using Tapatalk
Old 10-06-2015, 06:33 AM   #874
steve99
Ok that explains it the old original oft had erase count of 2, the oft guys will sort it for you.
The newer ones its 5 i think before you have to get it reset
Old 10-08-2015, 01:29 AM   #875
riboyster
riboyster's Avatar
Hey, is anyone able to speculate what would happen if I ran the stage 1 tune with unequal length headers? Would the aggressive valve timing give me more torque in the mid range?
Old 10-08-2015, 03:06 AM   #876
steve99
if you have ability to flash stage 1 tune why not flash the correct stage2 uel catless header tune for your uel headers ?
it is always better to use the correct tune you will get the best results when tune matches mods
it wont blow up but it wont be optimal
Old 10-08-2015, 03:24 AM   #877
riboyster
riboyster's Avatar
Just been kinda curious about what it'll do to the torque curve. If it levels the stock exhaust curve out, then does that mean I'll get a torque bump because I've got headers?
Old 10-08-2015, 04:22 AM   #878
JB86'd
JB86'd's Avatar
Drives: JAWS
It doesn't "level" it out, and that's not how a tune works.
It helps but the torque dip is still there on stage 1. On stage 2, with UEL headers, the dip is gone (for the most part depending what headers you have).
What will give you a torque bump is having the correct MAF scale, highest octane available, correct AVCS, optimal fueling, optimal timing. <--- all of those are changed for the stage 2 maps....
Oh and stop using 87, you're making your engine sad.
Old 10-08-2015, 04:44 PM   #879
riboyster
riboyster's Avatar
Just had drive 2 with 89 e0. Cricket almost completely gone, power band much smoother, no timing being pulled yet. Faster 0-60, and no probs involving timing/knock on my pull in 3rd for virtual dyno.
Logs should be getting posted later tonight after work.
Multiplier still at 1.0, 15 miles
Old 10-08-2015, 05:17 PM   #880
JB86'd
JB86'd's Avatar
Drives: JAWS
the ECU won't really drop IAM when you first flash..i'll be interested to see after you put 60 miles on it and do a 2000-7000 pull in 3rd gear if your IAM is at 1.
Old 10-08-2015, 05:37 PM   #881
riboyster
riboyster's Avatar
Didn't just flash. Been flashed for about 3 months, just changed fuel.
Old 10-08-2015, 06:35 PM   #882
JB86'd
JB86'd's Avatar
Drives: JAWS
Ah, you said 15 miles and I misunderstood, thought you had just flashed. Your 89 octane must be magical, because we can't even keep IAM at 1 with top tier 91 octane.
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 01:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 11:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 05:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
