Old 08-12-2014, 05:07 AM   #449
troek
troek's Avatar
Drives: 2012 Toyota 86
so far other than the 44 tables my rom dosnt have that that the state side one has, these are the tables that are changed between 1.5x stage 2 and 2.0 stage 2 uel 93 octane:
knock correction advnace max a
overrun fueling cut counter rpm threshold
misfire count map threshold a
misfire count map threshold b
various input rising load activation ECT Load tables
are any of these performance orientated?
Old 08-12-2014, 06:02 AM   #450
steve99
something weird going on there mate.
The 1.5 to 2 tune have big changes to MAF scaling and OL Fuel tables.
for sure.
Old 08-12-2014, 07:42 AM   #451
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by JB86'd View Post
Stock intake, unmodified, AFE dryflow filter. You on the 2.0 maps?
I'm using an afe r5 oiled filter element (supposed to flow more cfm than the dry one). maybe its time for me to wash and reoil it. You'r logs were reading up to 4.03v, mine on stg 1 v 2.0 tune is topping out at 4.01v.
Old 08-12-2014, 08:01 AM   #452
steve99
Originally Posted by clintavo View Post
Has anyone else noticed hesitation/ bogging at 1500 rpm when floored?
I realize this is a somewhat rare scenario, but I have run into it twice:
Loafing around a parking lot in 2nd gear, suddenly to get out of someone's way.
Starting from a stop uphill.
It is repeatable; floor it at 1500 rpm and it completely bogs. It never happened with 1.3 or 1.6
BTW the throttle calibration seems much smoother in this tune : )
Thanks Shiv!
Stock intake ??
also log whats going on include long Term fuel trims LTFT see if its are way off like over 10%
Old 08-12-2014, 08:01 AM   #453
troek
troek's Avatar
for sure.
Yeah thats what i was thinking as well. Might have to just wait till shiv gets around to the japanese rom, im at the bottom of the list being the only one over here lol
Old 08-12-2014, 08:10 AM   #454
steve99
Just compared a stock D00G to OFT modded D00C and their is a couple of weird tables and values that look a bit suspect in the DOOC rom actually, it late though and maybe my brain fading. Think I;m going to be lazy and let shiv do it.
Old 08-12-2014, 08:11 AM   #455
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Japanese rom is done, I've posted it already - I'm guessing Shiv just has to transfer the maps.
Td-d is offline   Reply With Quote
The Following User Says Thank You to Td-d For This Useful Post:
troek (08-12-2014)
Old 08-12-2014, 08:24 AM   #456
troek
troek's Avatar
Old 08-12-2014, 09:55 AM   #457
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
I keep getting a "post catalyst fuel trim too lean (bank 1) " code from this beta maps. And on top of that someone times when I crank the car to turn on it doesn't. The bash lights up but the car doesn't turn on like if the battery wasn't charged. Takes it like 2- tries to turn it on
Juanito08 is offline   Reply With Quote
Old 08-12-2014, 04:34 PM   #458
clintavo
Stock intake ??
Modified stock snorkel. I'll post a log. Thanks
clintavo is offline   Reply With Quote
Old 08-12-2014, 06:10 PM   #459
JB86'd
JB86'd's Avatar
Drives: JAWS
@steve99 @Shiv@Openflash
just took a new datalog and got the IAM to drop from 1. Seems that partial throttle mid-rpm fine knocking is what's bringing my IAM down mostly. There are quite a few FLKC events under 1.0..no actual Knock Correction, and LTFT does not go above or below +4 and -4.
Are those FLKC events something I should make an effort to edit out in the map or get a custom e-tune, or are they not a problem?
http://datazap.me/u/joshbustos86/frs...1-2-9-10-11-12
keep in mind I'm on CA 91 oct and it's about 80* F out.
Old 08-12-2014, 06:23 PM   #460
Kodename47
Kodename47's Avatar
Drives: UK GT86
FLKC is when loads are more stable and are easily tuned out. I would just make sure they are consistent. I've said multiple times to use VGI's utility to log these events to see how to adjust the map.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
JB86'd (08-12-2014)
Old 08-12-2014, 07:04 PM   #461
steve99
+1 on @Kodename47 comments.
log it a couple of times note the RPM and Engine Load where knock occurs consistently and the amount of negative correction of FLKC or Knock correction FBKC. (Don't worry about the positive FLKC as that is the ECU putting back timing it took away.)
have a read here
http://www.ft86club.com/forums/showthread.php?t=61820
pull timing from the appropriate cells in BASE_TIMING_B reflash = happy.
looks like about 0.7 or so needs to be pulled from 3000-3600 loads 0.6 to 1 but do a couple more logs.
Once you IAM get back to 1 you might need to pull a bit of timing at the upper RPM range as well.
JB86'd (08-12-2014)
Old 08-12-2014, 07:55 PM   #462
Kodename47
Kodename47's Avatar
Drives: UK GT86
Ignition timing adjustments can be done as below:
Originally Posted by Kodename47 View Post
The way I have used to easily see what's happening is as below, using VGI's Tool.
- Go to Log Stats screen
- Import Log
- On the set axis button, copy in your base timing table and verify (save for future if you want)
- Set X axis as engine load
- Set Y axis as RPM
- Set Data as FLKC
- Set a filter as FLKC < 0
I would then check the mode value and the count. You can repeat for FBKC too. Obviously if you log pull by pull then you won't need to do that, but if you're logging more than that, it can be useful to see other problem areas.
.: Stealth 86 :.
Kodename 47 DJ:
JB86'd (08-12-2014)
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 01:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 11:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 05:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
