Old 07-26-2014, 09:22 PM   #127
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
I have loaded up v2.0 Stage 2 UEL 93oct put 120 kms on my FRS. Here are some datalogs if I could get the old J.V. style "looks good' from Shiv it would be greatly appreciated.
(trick answer: J.V. wouldn't look at the logs)
http://datazap.me/u/dmmccrea/july-26...zoom=1495-2580
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 07-26-2014, 09:25 PM   #128
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Looks fine but a little rich. Not really costing you much power though. What header are u using? Any other mods?
Old 07-26-2014, 09:30 PM   #129
Apoc
Apoc's Avatar
I'm using the best header ever OFH. I have TRD intake also. I'm 3400 ft elev. too.
“The World is Flat”
[||•]=(86)=[•||]
Old 07-26-2014, 09:31 PM   #130
dodouble
Drives: 2013 frs
not sure if stupid question, if it is im sure someone will point out why...
since us folks here in canada are in north america usdm market is the same as ours?
simpler put can i use this now?
dodouble is offline   Reply With Quote
Old 07-26-2014, 09:34 PM   #131
Apoc
Apoc's Avatar
You may need to have translated to french...
But seriously you should be good to go.
“The World is Flat”
[||•]=(86)=[•||]
The Following User Says Thank You to Apoc For This Useful Post:
DC2R (07-27-2014)
Old 07-26-2014, 09:39 PM   #132
dodouble
Drives: 2013 frs
thanks for the info, im actually billingual. my grammar in english is horrible though.
The Following User Says Thank You to dodouble For This Useful Post:
flippy (08-15-2014)
Old 07-26-2014, 09:51 PM   #133
fast_dude
Drives: 2014 Scion FRS
Got what I needed.
2014 Scion FRS- Kw2 suspension, Openflash headers, Openflash tablet, Invidia N1 exhaust, Invidia Overpipe, Nameless catted front pipe, TRD intake, Enkei RPF1s with Hankook RS3 tires, carbon fibre front lip, TRD knockoff spolier, SPC lower control arms.
fast_dude is offline   Reply With Quote
Old 07-26-2014, 10:06 PM   #134
wparsons
wparsons's Avatar
You'll be fine, I've been on 1.6b and 2.0b for a few weeks now.
Updated to stage 1 93 octane tonight with a fresh tank of Petra 94, I'll get enough km's on it tomorrow morning to give it a good test at an autox.
flickr
Old 07-26-2014, 10:21 PM   #135
Optimus Prime
Optimus Prime's Avatar
Drives: Whiteout 2013 FR-S
So I flashed the A01D stage 1 93 octane map and immediately got CEL code P0700. I cleared it and after 20 miles or so it still hasn't come back. Anything to worry about?
Also wanted to say thanks Shiv! Such a huge difference between stock and with a flash. Even the lowly auto feels quick (though I know it's not).
Optimus Prime is offline   Reply With Quote
Old 07-26-2014, 10:50 PM   #136
Shiv@Openflash
Drives: 2013 FRS
I think that code is normal after flashing a 6at car. It's a transmission control unit error caused by a communication loss during the ecu flashing process. You can clear it like you did or just let it reset itself after a few drive cycles. No harm either way.
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
enwave (07-26-2014), Optimus Prime (07-26-2014)
Old 07-26-2014, 11:42 PM   #137
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
dont know if i've missed a post but will their be any tune stage 2 BPB ? or should we take the new stage 2 2.0?
@Shiv@Openflash
i'm not complaining if their wont be any update on this, as I see everything new you give on this product as a bonus
Walla Walla is offline   Reply With Quote
The Following User Says Thank You to Walla Walla For This Useful Post:
Silver Ignition (07-27-2014)
Old 07-27-2014, 12:32 AM   #138
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by edeekeos View Post
Wonderful. Thanks so much!
Update: Just tested the v2.01 Stage 2 EL E85 A01C in the shop car (already running E85) and no problem whatsoever. Ran great right out of the gate. And all the other CAL IDs versions for this tune are identical so I don't think there is anything wrong.
I'm not sure if this applies to you, but you are likely to run into some rough running upon start-up if you just switched over to E85 (from gasoline) and flashed the E85 map. This is because there is still some gasoline in the fuel lines (between fuel tank and fuel injectors) that need to be burned off. This only takes a couple minutes of driving (or at lot longer if the engine is just idling). During that time you will be running rich and a little rough with very negative fuel trims. It will magically clear itself within a minutes. During that time, just drive normally and refrain from going WOT as you will be disappointed in the performance. But once the gasoline burns off, you will be back in business and running very nicely. Again, I'm not sure if this explains your situation but just a thought.
Cheers
Shiv
Old 07-27-2014, 12:34 AM   #139
Shiv@Openflash
Drives: 2013 FRS
@Shiv@Openflash
Instead of making releasing another 132 maps for BPB use, I'm post a thread this week on how to convert any map into a BPB version of that map. Long story short, it just involves making some changes to a couple ignition timing related maps. Very simple and anyone can do it through ROM Raider. It's just gotten to the point were we have so many maps for so many different set-ups that doubling the amount of maps isn't quite prudent (for my sanity!)
Cheers,
shiv
The Following 8 Users Say Thank You to Shiv@Openflash For This Useful Post:
flippy (08-15-2014), Mad1723 (07-27-2014), raven1231 (07-27-2014), Silver Ignition (07-27-2014), steve99 (07-27-2014), Turdinator (07-27-2014), Walla Walla (07-27-2014), zdr93523 (07-30-2014)
Old 07-27-2014, 02:13 AM   #140
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Cheers,
shiv
With all your Porsche, FI, Miata projects, you'll have to find a way to automate that shit, otherwise, you'll have to hire an intern doing just that
Mad1723 is offline   Reply With Quote
Search this Thread:
Advanced Search
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 01:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 11:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 05:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
