86WORX
Old 05-30-2012, 02:28 PM   #15
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Originally Posted by serialk11r View Post
possible rudimentary cam specs? 255 degrees duration...hmmm. Toyota says the Prius is more like 265, and I somehow remember seeing a similar chart for a different (it was a "medium speed" engine, from some sort of sedan, maybe the 2GR) engine and it was around 255 as well, but with a much lower torque peak. Perhaps this means a longer duration cam can net some top end gains :O
You might be right, but that is the static duration.
Considering VVT, it might not be as bad as it seems.
uspspro is offline   Reply With Quote
Old 05-30-2012, 03:52 PM   #16
Boosted2.0
Boosted2.0's Avatar
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
Originally Posted by Gardus View Post
Very interesting info, thanks, but still no ECU "name".
If I have time I'll pull my glovebox out and try to see who makes the ECU tonight. I know for sure Denso makes the Direct injector control box.
Boosted2.0 is offline   Reply With Quote
Old 05-30-2012, 04:19 PM   #17
Dimman
Kuruma Otaku
Dimman's Avatar
Serial, also remember effective duration. (Yes I know I've told you before...) Because of how slowly they initially open you usually cut ~50 degrees of the advertised duration.
eg:
3SGTE 256 degrees but 204 @ .050" lift
2JZGE 248 degrees but 200 @ .050" lift
Because titanium.
Old 05-31-2012, 03:45 AM   #18
Gardus@Supersprint
Drives: Clio TCE
Thanks a lot Boosted, that would be very useful!
Gardus@Supersprint is offline   Reply With Quote
Old 05-31-2012, 04:17 AM   #19
coyote
coyote's Avatar
Drives: Slowly
http://www.romraider.com/forum/viewtopic.php?f=8&t=8475
coyote is offline   Reply With Quote
Old 05-31-2012, 04:28 AM   #20
Gardus@Supersprint
Drives: Clio TCE
Thanks!
Old 05-31-2012, 11:40 AM   #21
illmatic
illmatic's Avatar
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
So it seems like he was able to extract the ROM. Interesting...
illmatic is offline   Reply With Quote
Old 05-31-2012, 11:49 AM   #22
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by coyote View Post
Do you have any screenshots?
Old 06-05-2012, 05:25 PM   #23
illmatic
illmatic's Avatar
If it uses the Renesas SH7059 found in the Euro Diesel, more info can be found below.
http://subdiesel.wordpress.com/ecu-a.../ecu-hardware/
Old 06-05-2012, 06:29 PM   #24
coyote
coyote's Avatar
Drives: Slowly
Apparently the file size is only 1MB, which suggests it's an SH7058.
Note, none of this is first hand info ... I don't have access to a car yet.
Old 06-05-2012, 10:20 PM   #25
Ishii Motors
Ishii Motors's Avatar
Drives: Scion FRS
Here's some pics
Ishii
Ishii Motors is offline   Reply With Quote
Old 06-06-2012, 08:52 AM   #26
Gardus@Supersprint
Drives: Clio TCE
Good job! I've just sent the pictures to my friend who works on many Denso ECU.
Old 06-06-2012, 01:28 PM   #27
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by Ishii Motors View Post
Here's some pics
Ishii
Many thanks again! ^^^That was pulled from an FRS, so the BRZ should be the same.
Old 06-06-2012, 05:58 PM   #28
Ishii Motors
Drives: Scion FRS
This is also available for piggy back stuff and whatever else would require tapping into the ECU wires.
http://ishiimotors.com/engine/ecu-jumper-harness.html
Ishii
Toyota GT 86 model car mickey177 Scion FR-S / Toyota 86 GT86 General Forum 3 05-10-2012 04:49 PM
Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) switchlanez BRZ First-Gen (2012+) -- General Topics 68 02-14-2012 08:16 AM
Pics for 3D model DaReaper FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 23 01-23-2012 01:31 AM
Name of Production Model? mrxandthexfactor Scion FR-S / Toyota 86 GT86 General Forum 50 11-05-2011 09:13 PM
Is it wise to buy an all-new model car when it first comes out? Raiden Scion FR-S / Toyota 86 GT86 General Forum 39 01-29-2011 11:57 AM
