Old 07-24-2014, 06:44 PM   #57
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by JuniorAWD View Post
Guys like you take the internet way to serious. You should start some sort of forums rights support group. This way you guys can talk about how bad the forum is because they dont like your OPINIONS.. or as you call them "facts"
Lonewolf is offline
Old 07-24-2014, 06:45 PM   #58
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
@jamesm last reply, that was removed, actually spoke to the fact that there is shared responsibility for what occurred. It was probably the most progressive post in this thread. It wasn't meant as a JR & Prime Motoring bash fest.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline
The Following 4 Users Say Thank You to ecko04 For This Useful Post:
ATL BRZ (07-24-2014), Luis_GT (07-24-2014), Sportsguy83 (07-24-2014), sw20kosh (07-24-2014)
Old 07-24-2014, 06:50 PM   #59
JuniorAWD
Drives: GTR 9.0@170_XT 10.8@130_GC 8.3@165
Originally Posted by Manji View Post
Cool story bro.
I have no idea about any of those things you mentioned. Thank you for putting me in my place.
I'm not going to argue over who's tuning cock is bigger.
My post was simply to make others aware that there was a counter position, and that those with any rational thought will then look into the topic in more depth and draw their own conclusion.
Your welcome and thanks for proving my post
Not arguing tuning cocks...
I guess I must have misread because You directly posted your tuning "facts" when clearly as you just posted don't have any tuning knowledge. Then you attacked my knowledge by posting that "they know learned overboost protection" blah blah blah .. So which one is it? Are they facts about overboost? Or were you just talking out of your ass and making assumptions then trying to pass them off as facts.
JuniorAWD is offline
Old 07-24-2014, 07:04 PM   #60
vgi
Drives: frs
Originally Posted by Jesse@JDLAutodesign View Post
I'm not taking sides here as i know more than anyone motors let go perhaps a lot more often than what people see or read online...It's part of the game and anyone wanting to play should be prepared.
I've personally lost a motor before due to a melted wastegate line, it was 100% my fault and a last minute hack job to get on the dyno at 2am to make an event while waiting on AN lines to show up the next day. However i've never seen these fittings or plugs back out or completely fall out. I've also never used locktight nor seen anything in Tial's instructions (I just opened a few MVS and MVR gates here at the shop to check) to do so on anything other than the water fittings, which makes sense for water based on the thread used. I've usually found because of the difference in materials in the gate vs. the fitting the fittings are usually tighter and harder to get out over time due to expansion/heat cycles, etc.
Thank you, you Tial cock is big!
vgi is offline
Old 07-24-2014, 08:29 PM   #61
FirestormFRS
You guys are entirely wrong for pulling out your pitchforks on the tuner this time. The OP paints himself as a liar/thief with the original post with the warranty claim bullshit.
Prime and Junior with solid reputations vs. some dude that messed up his install and then considers defrauding the manufacturer as a way to get a new engine.....
Y'all make no sense
FirestormFRS is offline
The Following 3 Users Say Thank You to FirestormFRS For This Useful Post:
JuniorAWD (07-24-2014), PrimeMotoring (07-25-2014), SDIAZ (07-24-2014)
Old 07-24-2014, 09:02 PM   #62
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Originally Posted by Target70 View Post
that really sucks.
I am not heavy into the turbo discussions, but I am surprised I haven't heard anything about overboost protection at all. In my 240 there was a simple $50 box with an adjustible pressure sensor that cut spark if you went above your set limit. Seems like a cheap form of insurance if going FI.
It was a Hobbs pressure switch, and a 12V relay run between the ecu and the coil wire.
http://forums.nicoclub.com/how-to-ne...n-t148380.html
as there are different views here about fuel cut causing knock in high compression engines, I am just posting this as an alternative. If you are spending 5-7k on a turbo kit, $50 doesn't sound like a very expensive insurance policy.
*edit: I can't say for sure what our ecu would do if the signal to the coil was interrupted
Target70 is offline
Old 07-24-2014, 10:09 PM   #63
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
This thread gave me a headache. Too much drama.
cdrazic93 is offline
Search this Thread:
Advanced Search
So my engine blew up.... alliedcam1 Engine, Exhaust, Transmission 57 12-28-2013 03:50 PM
dyno tuned today WhiteFR-S Engine, Exhaust, Transmission 2 10-18-2013 03:40 PM
What would You do if your motor blew? TyperRspec789 Forced Induction 58 07-02-2013 11:54 PM
Went to the DYNO Today, Stock* results are in! Z3D Engine, Exhaust, Transmission 30 03-06-2013 10:49 PM
Baseline dyno test today on my new BRZ Those Meddling Kids Engine, Exhaust, Transmission 2 08-25-2012 11:52 PM
