#29 | |
#30 |
Drives: Blue BRZ
hope you get it worked out soon man.
#31 |
Drives: 2014 Pearl White BRZ
Sorry about the car man.
#32 |
Boosted
Drives: Not a supra....yet
Im really surpised, i had a shop incorrectly install WG lines on cousins brz, the car overboosted on an FA20crap base map(OVER15PSI) a couple of times and the motor didn't blow :/. The car has since been tuned nemours times and now runs over 12psi on 91 perfectly fine
#33 |
Drives: 2013 GBS BRZ Limited
I would ask for logs for all the runs they did that day.
If you have proof that the boost was being controlled in the earlier runs, and then not controlled in later runs (all while under their care), then it is definitely their fault. |
| The Following User Says Thank You to stugray For This Useful Post: | Boofneenee (07-24-2014) |
#34 |
Dismember
Drives: 2013 Red Scion FR-S
If they didn't do every single bit of the install, you're on your own. Putting the car on the street and the keys in the mailbox is pretty standard for picking up a car after hours. Should they have waited for you and given you a hug? The dyno is a pretty intense place. Things can and do go wrong there. In the end, you pay to play.
View this as a chance to get a built engine. I'd call up Full Blown, MAP, or Element.
| The Following 3 Users Say Thank You to EAGLE5 For This Useful Post: |
#35 |
Toyotas don't have boxers
Drives: GTV86, ISF, TE27
nek minnit
#36 |
NASA SpecE30 Racer
The wastegate plug coming out is a possibility, but a good tuner and shop should be monitoring boost and that should not have blown your motor. I would ask for more details or proof of what occured when the motor blew. They should have been datalogging the car with EcuTek at the time the motor blew. I would like to hear the other side of the story from @PrimeMotoring and @JuniorAWD.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#37 | |
Drives: FRS with 2jz, 2015 STI 9.68@147
You have been in contact with Junior and myself the entire time and no point did we tell you to "fuck yourself." You basically said that to us when you said to leave your car on the street and youll pick it up tonight. None of that gets mentioned though, its just "Prime Motoring blew up my car". Whoever installed the wastegate and did not follow instructions should take responsibility for the car overboosting. Last edited by PrimeMotoring; 07-24-2014 at 01:17 PM. |
| The Following 5 Users Say Thank You to PrimeMotoring For This Useful Post: | gramicci101 (07-24-2014), Mad1723 (07-24-2014), Ny Brz (07-27-2014), speed6sam (07-26-2014), youcantseeme24 (07-24-2014) |
#38 | |
This is what we find when trying to figure out why the car overboosted. ![]() Tial recommends all fittings be loctited on, even the water fittings. This is a wastegate we had laying around. I didnt have the bag with the airport fittings because it was thrown out after the fittings were loctited and installed to dry. ![]() Noticed the other port was hand tightened on and pulled it off to see if there was loctite applied....none ![]() The other plug is underneath the dyno or somewhere in Kai's car. We could not find it to see but that is what we found. Everyone can play the situation as they please but we can not control hardware issues caused by user error. Like i mentioned, if this was our install, we would be buying Kai a new motor. |
| The Following 6 Users Say Thank You to PrimeMotoring For This Useful Post: | DJCarbine (07-24-2014), gramicci101 (07-24-2014), Mad1723 (07-24-2014), Ny Brz (07-27-2014), the new guy (07-24-2014), whataboutbob (07-24-2014) |
#39 |
i'm sorry, what?
Drives: Canada
[ame]http://youtu.be/tTTiCBxKV4c[/ame]
| The Following 3 Users Say Thank You to 7thgear For This Useful Post: |
#40 |
Wonder if they have data of what boost blew it up.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
#41 |
Drives: 2012 WRX, 2003 RSX Type S
So why are we fi these cars instead of buying a wrx, sti, genesis 2.0t, 370z, 335i, Ore any turbo car stock, worth factory warranty? So glad I'm gonna stay NA
#42 |
Drives: Asphalt FRS
Because its just the game of modding cars. And trust me, I have seen countless WRX's, STI's, Genesis 2.0's and 370s destroy engines all the time, (even stock ones) I don't see how they are any different. And there are plenty of N/A stock FRS/BRZ's that have blown engines as well. There are also plenty of boosted FRS/BRZ's running well without any issues, including my daily driven one.
| The Following 8 Users Say Thank You to MAPerformance For This Useful Post: | Cal3000 (07-24-2014), Chad86 (02-21-2018), jamesm (07-24-2014), Ny Brz (07-27-2014), Powersfrs (07-24-2014), PrimeMotoring (07-24-2014), Sportsguy83 (07-24-2014), whataboutbob (07-24-2014) |
| So my engine blew up.... | alliedcam1 | Engine, Exhaust, Transmission | 57 | 12-28-2013 03:50 PM |
| dyno tuned today | WhiteFR-S | Engine, Exhaust, Transmission | 2 | 10-18-2013 03:40 PM |
| What would You do if your motor blew? | TyperRspec789 | Forced Induction | 58 | 07-02-2013 11:54 PM |
| Went to the DYNO Today, Stock* results are in! | Z3D | Engine, Exhaust, Transmission | 30 | 03-06-2013 10:49 PM |
| Baseline dyno test today on my new BRZ | Those Meddling Kids | Engine, Exhaust, Transmission | 2 | 08-25-2012 11:52 PM |
