Old 03-18-2015, 07:57 PM   #15
THEWAKLER
USMC
THEWAKLER's Avatar
Drives: DGM BRZ LMT
Originally Posted by BRZnut View Post
wow! No don't have that and my BRZ has been through two snowy winters. When I got my car I did cover the insider of the wheel well (under the fender) with caulk to protect the paint.
Are you lowered? Wheel looks closer that usual to the body
1.4" on ST coils.
Originally Posted by Freetime View Post
There is an obvious impact mark right in the middle. You can see the stress cracks from it. I'm with the poster above, something from the road flew up and hit the edge of the fender just right and cracked it.
I was thinking the same, but if you look closely there are multiple small cracks on the upper edge. There is space/air/gap underneath the top paint, and I believe it cracked after the fact from peeling up.
Yes! What ever cracked it let water in and it has been there for a while for the steel to rust like that. I have a bare metal spot from a stone hit that has been there for the whole winter (with tons of salt) and it is just now starting to rust.
I considered that, and may have missed a small crack when I washed it 2.5wks ago, and the rust could've been forming for a while. But there were no visible signs that I saw.
I'm betting Subaru is going to tell me the exact same, that something flew up and hit it. Probably nothing I can do to prove otherwise. Going to try on Friday anyways.
THEWAKLER is offline   Reply With Quote
The Following User Says Thank You to THEWAKLER For This Useful Post:
Tcoat (03-18-2015)
Old 03-18-2015, 08:01 PM   #16
Originally Posted by THEWAKLER View Post
1.4" on ST coils.
Worth a shot! Even if they won't fix it at least try to get a free touch up pen from them. It worked for me.
Old 03-18-2015, 10:48 PM   #17
BRZnut
Drives: BRZ DGM Limited
Bet they tell you it is because you changed the suspension and that caused more road debris to hit the paint. Then they will void your warrantee (at least for body rust) and send you on your way.
Old 04-22-2015, 04:05 PM   #18
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Thats hwat happened to me
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 04-23-2015, 01:19 PM   #19
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
I have the same issue with a rock chip on the fender located near the headlight. can I use touch up paint on top as it hasn't started to rust yet?
Old 04-23-2015, 02:07 PM   #20
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
paint only cracks like that from flex. especially when cold. factory delamination comes off in sheets, and it would be widespread. not just isolated
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
Tcoat (04-23-2015)
Old 04-23-2015, 02:38 PM   #21
Yep. Give a quick sand with a spot sander and slap that paint in the hole. Little bit of practice and soon nobody will ever know there was a chips.
NyC Zn6 (04-24-2015)
Old 04-23-2015, 05:30 PM   #22
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
@THEWAKLER
That looks like you probably went over a bump or pothole with your wheels turned without enough camber. As others said, paint usually only cracks like that from impact. Touch up paint wont last unless you sanded beyond those crack lines first. Looks like the body shop would be required in your case. Maybe consider those "spot repair" shops if cash is tight.
projek_01 is offline   Reply With Quote
Old 04-23-2015, 08:15 PM   #23
nickmerronesucks
Ned flanders
My car now has 90 percent touch up paint 10 percent factory.
797Performance.com
Old 04-27-2015, 11:57 PM   #24
shellslinger
Drives: Whiteout FRS
You too?! LOL
shellslinger is offline   Reply With Quote
Old 11-30-2015, 08:24 PM   #25
sdwagonjp
sdwagonjp's Avatar
Drives: 2015 Fr-s Firestorm
Any other threads related to clear coat chipping away? I have a few issues with my paint and wanted to see if someone had the same issue. The dealer looked at is and were surprisingly shocked by it. I have paint coming off now and I am able to see the primer. The guy I was dealing with said the way Toyota puts their paint on is bad. He said they dip it and not spray it. Not sure if thats true. Only 4500 miles on her and have had her for over a year. Any links?
sdwagonjp is offline   Reply With Quote
Old 12-01-2015, 01:48 AM   #26
humfrz
Oh, I seriously doubt they "dip" it. How could you get a coating soooo thin, by dipping the object ??......
How about you posting am picture of your car's paint problem ....
humfrz
Old 12-01-2015, 08:07 PM   #27
sdwagonjp
sdwagonjp's Avatar
humfrz
You have any knowledge in paint? Ill snap some pics when I can.
Old 12-01-2015, 09:11 PM   #28
humfrz
KNOWLEDGE OF PAINT ....... ?? HECK YES!
At my age, I have knowledge of lots of stuff ...... I just can't remember most of it .........
Paint ..... oh, yes ......... I remember, back in the day, I used to paint cars for friends and relatives. Yep, back when enamel and lacquer were the only kinds of paints for cars.
An old roadster with 30 coats of candy apple red lacquer (hand rubbed out between every other coat) would make a real looker….
OK, what was the question .......
humfrz
sdwagonjp (12-01-2015)
1st winter and only 2/16 paint chips are rusting! Muskokan Issues | Warranty | Recalls / TSB 30 10-09-2018 05:51 PM
Muteki Wheel Nuts - chipping paint Hags86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 04-26-2015 10:17 AM
Anyone else experience paint peeling? euroshowoff Issues | Warranty | Recalls / TSB 9 08-23-2013 12:39 PM
feeler CA: trade seibon CF fenders for stock red fenders Alliedforces86 Exterior Parts (Aero, Lighting, Etc.) 11 08-08-2013 02:03 PM
Fenders Chipping? Shit Luck Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 04-01-2013 04:20 PM
