86WORX
Old 07-22-2014, 10:02 AM   #15
nocwage
MMTT
Drives: 2019 Subaru BRZ
Originally Posted by Lawnik View Post
Yes
But I just took the bulb out and crushed it
With the Shorai charger it recovered quickly
Lol
Hah ya I think I'll do the same.
I don't need a light in there, the trunk is rarely used except hauling stuff to the track.
nocwage is offline   Reply With Quote
Old 07-22-2014, 12:52 PM   #16
P@ul
Apostle
P@ul's Avatar
Drives: JesusMobile
Originally Posted by nocwage View Post
Shorai battery, I wish I had bought the earthX one since it HAS the over discharge AND charge controller ON the battery.
If this one is toast I will buy EarthX
Them FEELS! I read about EarthX after I bought the Shorai.
The BMS is built into the EarthX; it's the only lithium ion starter battery I've seen properly setup like that!
I found the supplier that manufactures the Shorai battery and they have optional hardware to add a BMS. But it's an additional circuit board that has to be integrated into the packaging; it's not something you can really buy on your own and bolt on to your battery. I might just order parts and build my own next time.
P@ul is offline   Reply With Quote
Old 07-22-2014, 01:02 PM   #17
Pete156
I like to eat!
The EarthX and Shorai are not Lithium Ion but Lithium Iron Phosphate batteries. Quite different.
Pete156 is offline   Reply With Quote
Old 07-22-2014, 01:03 PM   #18
Chimera
Drives: FRS
cheap led strip from kmart, auto zone, etc, and 2 spade connectors and you have an upgrade + lights that `virtually` can never drain your battery.
Old 07-22-2014, 01:16 PM   #19
P@ul
Apostle
P@ul's Avatar
Drives: JesusMobile
*eyeroll* Lithium Ion is a generic name covering all the lithium ion based battery chemistries. But thanks...
Old 07-22-2014, 01:20 PM   #20
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
Ha. I had this happen once. Props to @quark for the low power bulb tips!
denkigrve is offline   Reply With Quote
The Following User Says Thank You to denkigrve For This Useful Post:
quark (08-12-2014)
Old 07-22-2014, 01:23 PM   #21
zinzan
zinzan's Avatar
Drives: Subaru BRZ 2014 Limited WRB
Anyone else kill their battery with the trunk?
Happened to me once. I'm really careful to confirm the trunk is closed now. I notice it closes completely easier now than when the car was new.
I open the trunk fairly often. I keep detailer spray in the back, as well as an umbrella and my sunshade. And I do use it for groceries or home depot runs.
I did replace the bulb for a brighter LED. Didn't even think about the low power aspect. Nice!
-Z
zinzan is offline   Reply With Quote
Old 07-23-2014, 08:49 PM   #22
monkeyslide17
monkeyslide17's Avatar
Drives: frs
I'd just say hit the button and turn the key fob trunk opener off and have to use key to open the trunk. That would save your batt.
monkeyslide17 is offline   Reply With Quote
Old 07-23-2014, 09:21 PM   #23
B$
86
Drives: Monogram Whiteout
How about not closing the trunk like a little girl?
B$ is offline   Reply With Quote
Old 07-23-2014, 09:23 PM   #24
Ernie L
Ernie L's Avatar
Drives: 2014 BRZ black premium
I don't think it is the trunk bulb that is draining the battery. with my headlight switch in AUTO mode and trunk open the headlights stayed on. They did not go out after a short interval when exiting the car as they normally do. I was parked in my garage and unloading packages from the trunk. I made a couple of trips and noticed that the headlights were still on..Once I shut the trunk the headlights went out shortly after..as they normally would.
I do not know if they would have stayed on or not if I had not closed the trunk. My guess is they would have.... its a convenience feature I assume....This may not happen if you park in the daylight..my garage is an under house garage and fairly shady even in daylight..the auto headlights do come on when I pull in to it.
I'm not sure if the running lights would act the same way if you parked in the daylight with headlight switch in AUTO and the trunk open...I going to see about that
Ernie L is offline   Reply With Quote
Old 07-23-2014, 10:25 PM   #25
litemup
Drives: around
Booooo.
Mean-spirited -15
Unfunny -10
litemup is offline   Reply With Quote
Relocating Battery to trunk ML Engine, Exhaust, Transmission 35 08-03-2015 01:58 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
Fuel or Battery Kill Switch? nabil_frs CANADA 3 03-09-2014 09:43 PM
Battery in the trunk scottman Electronics | Audio | NAV | Infotainment 14 10-06-2012 08:26 PM
Relocating battery to trunk Ess Vee Engine, Exhaust, Transmission 17 10-02-2012 05:32 PM
