#85 |
driving smoother faster
Drives: Sold
I had already posted...quick update...after a few track days and one AX event at Lime Rock Park (short 40 sec lap track with fun turns/camber and elevation changes), I decided to keep buying Toyo Proxes RA1 in 235/40-17 on 17x8 RPF1 rims. Also have JR SC, AP Racing Sprint BBK, Carbotech XP12/AX6 (track/AX), Ohlins R&T, camber -3f/-2.5r. Got the RA1 shaved and heat cycled but next time will get them with full thread. I like to keep close to the limits of traction but on the conservative side...it's rare to see me throw the car around into power slides (they are fun!). RA1 wear like iron and are very predictable with smooth gas pedal and hands. Slicks will always be quicker when up to temp but I am only doing HPDE and some AX and I'm amazed at how well RA1 are holding up so far. It was fun watching three instructors drive my car at the LRP AX course and hearing them comment on the setup. Wouldn't use them in the rain below about 6/32 thread but they handle rain very well at 9/32 thread new.
I may get Hankook R-S3 for summer street and to try them on track/AX but will stay away from slicks for now (never tried them) since RA1 work well for me. |
#86 | |
Drives: 2013 Raven Scion FR-S
... still 2nd place though .The C51/71 is rated at the same performance/points hit at Hoosier R6 so definitely a good alternative. The C90/91 are comparable to A6s.
Emmanuel Baako: NASA-Southeast Race Control & NASA Florida Race Director
![]() RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T ![]() |
#87 | |
| The Following User Says Thank You to phastafrican For This Useful Post: | dp1 (08-20-2014) |
#88 |
Drives: 13' Scion FRS Track car
@phastafrican so you don't experience any ABS problem with the hoosiers ? Are you doing the pedal dance ?
i think I'll get myself a set of BFG R1 and I heard some having ABS problem as well, I hope it is a driving style thing, if not that would be a pain. |
#89 | |
#90 |
I have been trying to find a picture of the fuse box and steering angle sensor. ir you have a chance to post them that would be great, I don't think anybody posted these pics on the forum yet..
My car is back together and I will be trying it early september, I don't want to have my day spoiled by some nanny
#91 | |
Drives: 2022 BRZ Limited
| The Following User Says Thank You to glamcem For This Useful Post: | phastafrican (08-23-2014) |
#92 | |
You're probably stressing too much about the tires and ABS. A day at the track with this car is never ruined by having ABS.
| The Following User Says Thank You to phastafrican For This Useful Post: | glamcem (08-23-2014) |
#93 |
I have multiple reasons why I went the way I did:
#94 | |
#95 | |
I'd buy it right away . As you said playing with the rpm and the dance before going on the track is nerve wrecking . I can't think about doing it. That why I want to make sure I know where are the stuff I can pull out ![]() I'll look into it and try to grab a picture of the steering wheel sensor plug. |
#96 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
I've been looking but haven't seen where someone has stated that they've tested with & without ABS and have a difference to report (for example, threshold braking with no ABS is 4' shorter than with any amount of ABS engaged - OR - 3/4 ABS is 6' shorter than threshold braking without ABS). The latter is the case with my car, but it's not a twin. I have novice-to-intermediate students with twins in upcoming events, and this would be useful for me to know. |
#97 | |
![]() RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T ![]() Last edited by phastafrican; 08-23-2014 at 11:18 PM. |
#98 | |
2) This is also true. So what I'm interested in is a generalization, although it's my suspicion that a result from testing with OEM brakes would hold true for modified brakes as well. I may well be reaching there. Ideally, each driver would perform this test with his or her own car. After all, why make assumptions about the method by which you can realize your car's maximal braking capability when you can determine it for yourself empirically. |
| How to warranty your stock tires and save money on Pilot Super Sports | SpeedR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 81 | 03-31-2016 10:48 PM |
| Slicks upgraded axles 1/4 mile? | Fabron757 | Forced Induction | 13 | 06-29-2014 07:25 PM |
| Track-only Race Compound Tires recommendations & Q's. On stock wheels. | fooddude | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 03-27-2014 12:47 AM |
| Auto-x, slicks & tire temps | mtimney | Tracking / Autocross / HPDE / Drifting | 6 | 10-19-2013 10:30 PM |
| Choice of slicks for HPDE | CB762 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-02-2012 10:25 PM |
