#29 | |
Drives: Nevermorange FRS
I've run just about every tire listed here in racing conditions except for the A6, BFG and TD.. I've never heard of or seen the Maxxis RC1. The Hankook C51 is great on cars where you heat both front and rears evenly like AWD or RWD because they SUCK when cold but are miracles of Jesus when hot. They won't give up and they can be punished like a sadomasochist without a safe word. However, not best bang for the buck as they cycle out almost as quickly as Hoosiers do. To me, an "R-Comp" assumes that it won't be driven on the street. So when you're talking "best bang for the buck" I have to say Toyo RR. It's 95% of a Hoosier R6 in lateral grip, can be punished almost as bad as a Hankook C51 and heat cycles like an RA1. I have almost 30 cycles on mine they and they still give me within .05 lateral G's as they did when new. Some even say they get better after 5 or so cycles. You don't have to pay for shaving (like an R888 or RA1). I've matched my personal best times (and a couple class track records) on RR's that I previously set on R6's. My vote for best bang for the buck R-Comp is:
SCCA T4 - FRS
#30 |
Thanks for all of the great feedback so far, guys.
To answer a few questions: - I will surely be getting a spare set of rims and will only be running these tires on the track - Given how lethargic this car is in a straight line, my goal is to maximize fun (ie speed) in the corners. So, my ultimate goal is crazy, never-ending grip. Secondary goal is to see if I can get close to / match the cornering speeds of my C6Z06 (PSS tires), which I'm tracking less and less given it's about 3-4 times as expensive in terms of running costs - Budget is somewhat flexible, just looking for best bang for the buck. This is my daily driver... would stock suspension & alignment still get a lot out of slicks, or would this really be a waste of money without stiffer springs & aggressive camber? |
#31 |
Oops i brain farted after seeing some ridiculous posts.
#32 |
IMO, total waste without stiffer springs and a more aggressive alignment. The stock suspension won't be able to control the body movement from the much higher grip, and you'll be rolling hard over onto the shoulders.
| The Following User Says Thank You to wparsons For This Useful Post: | ATL BRZ (08-19-2014) |
#33 | |
Drives: 2022 BRZ Limited
that's probably what I am going to get next, thanks again
#34 |
Because compromise ®
Drives: Red Herring
Yes, definitely. While there are no stadium prizes there are definitely bragging rights. If I am faster in my underpowered car than you in your more powerful car then I "win".
#35 | |
Drives: Red Herring
#36 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#37 | |
NASA SpecE30 Racer
As I mentioned the sizes are very limited in Toyo RR due to Toyo only producing them for Spec Tire series where we all run the same tires.
- King Tut
#38 | |
NASA SpecE30 Racer
My advice to you is that if this car is your daily driver, then stick with some fast street tires and a compromised street/track alignment and just enjoy your track weekends. Should you decide to make this car a track only car, then step up your suspension, alignment, and hop on some R comps.
- King Tut
#39 |
driving smoother faster
Drives: Sold
Best Slicks / Race Tires for the Money
My compromise for year-round (north east) street use and warm months track use (up to 10 track days per year):
- For cold months, street driving only, change alignment to -1.5f/-1r and use dedicated wheels with winter tires when temps drop below 45. - For warm months, street and track driving, change alignment to -3f/-2.5r and swap between dedicated wheels with summer street tires (Michelin PSS) and dedicated wheels with track tires (Toyo RA1). I see uneven wear on the insides of the summer street tires due to camber as price of admission for having a good setup for track. May get cheaper summer street rubber when PSS wears out but they have to work well in the wet on street and track. Car has many mods. Summer/track camber requires at least camber plates in front and LCAs in rear. |
| The Following User Says Thank You to dp1 For This Useful Post: | CSG Mike (07-16-2014) |
#40 |
^^ The uneven wear on the inside should be almost non-existant if you're running zero toe.
| The Following User Says Thank You to wparsons For This Useful Post: | Trac Toy (07-17-2014) |
#41 | |
The stock suspension and alignment is not designed to work well with r-comps/slicks. Another thing with r-comps and slicks is you WILL need to take a serious look at your brakes. You should with sticky street tires too, but with r-comps you should at least be thinking about a BBK and possibly brake ducts to make life easier. How much track experience do you have? A common question that often goes unanswered is: Do you want to be a better driver or do you just want to set your fastest laptime this weekend? If it's the latter, then yeah, get the r-comps but in the long run you'll learn more on quality street tires before stepping up to r-comps. - Andy
Website
https://www.racecompengineering.com/ Instagram: https://www.instagram.com/racecompengineering https://www.instagram.com/theapexfiles <- tech articles |
#42 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
Your goal is to find out what your tire temperatures are when you're running hot laps, so you want to pull into the first open slot in the hot pits at the end of a hot lap, not a cooldown lap. Don't forget to take your foot off the brake once you come to a complete stop. To get the most accurate readings, you'll use a helper or two to collect the data - one to take the temps and, if you aren't using a pyrometer that stores readings, another helper to write down the temperatures that the pyrometer operator calls out. (Yes, your goal is also to get this data taken ASAP.) If necessary, you can of course take the temperatures yourself. To speed the taking of the front tires' temperatures, turn them to the right or to the left to expose the faces to the pyrometer operator. Don't forget they're turned when you get ready to take off again! lol As has been mentioned elsewhere, start with the tire that sees the greatest loading on the track. That tire is the most important out of the four. BTW, taking the temperatures is the easy part - interpreting them is as much art as it is science. That's been my experience, anyway. |
| How to warranty your stock tires and save money on Pilot Super Sports | SpeedR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 81 | 03-31-2016 10:48 PM |
| Slicks upgraded axles 1/4 mile? | Fabron757 | Forced Induction | 13 | 06-29-2014 07:25 PM |
| Track-only Race Compound Tires recommendations & Q's. On stock wheels. | fooddude | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 03-27-2014 12:47 AM |
| Auto-x, slicks & tire temps | mtimney | Tracking / Autocross / HPDE / Drifting | 6 | 10-19-2013 10:30 PM |
| Choice of slicks for HPDE | CB762 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-02-2012 10:25 PM |
