Old 03-10-2015, 04:59 AM   #15
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Who are you going to get to tune your Cossy SC?
Old 03-11-2015, 03:48 AM   #16
enigma
Drives: Asphalt 86
It's up in the air right now. I'll be starting with the base tune from Cosworth that's included and going from there...
enigma is offline   Reply With Quote
Old 03-25-2015, 06:58 PM   #17
enigma
Drives: Asphalt 86
Hmm... what do we have here...?
The Following User Says Thank You to enigma For This Useful Post:
kosoku (03-25-2015)
Old 03-25-2015, 09:53 PM   #18
kosoku
Drives: 2013 fr-s
great write up. Simple, not over the top....I like it! I was going for something similar on my wanna be blog (below). I'll keep checking this one for sure!
kosoku is offline   Reply With Quote
Old 03-26-2015, 02:16 AM   #19
enigma
Drives: Asphalt 86
Cosworth Stage 2.0 Kit arrives!
First part of April for the install!
Big thanks to Jeremy and Yo @ FT86SpeedFactory as well! They were super helpful and kept me updated while waiting for it to ship! You guys are just stellar, as always!
Old 04-08-2015, 03:11 AM   #20
enigma
Drives: Asphalt 86
April 7th, 2015
Cosworth SC Install & Spark Plug replacement
Well, today was the day folks! The build has started! Chris @ Cosworth has been super awesome chatting back and forth with me. He got the directions out to me really quickly, and got the tune emailed over to me within MINUTES!
Her last couple pics as an NA car...
Mileage at the start
I weighed all of the parts prior to starting the install. My method was essentially weighing myself and then holding the parts and weighing myself again, as most of the stuff is pretty bulky and hard to weigh on its own.
Results came back as follows:
Manifold and supercharger: 44.6 lbs
Heat exchanger (IC): 4.75 lbs
Belt, brackets, IC pump, etc.: 7.5 lbs
IC hoses: 6.8 lbs
Intake pipe: 5.7 lbs
Total: 69.35 lbs. This total has NOT taken into account anything that I'm removing from the car (OEM intake manifold, swapping my Injen intake for the OEM airbox). I'd assume when all is said and done, the total weight added to the car will be in the neighborhood of 60-65 lbs.
I did run into a snag when fitting the throttle body onto the new manifold as the instructions seem to imply that a new throttle body gasket was included, but nowhere to be found in my various bags of goodies. I've reached out to Chris @ Cosworth to see if maybe I'm just mistaken, but I can confirm that the OEM piece definitely doesn't seem to fit. I was able to go to a local parts store and find a gasket that would fit, but will get a definite answer before doing any dynos or heavy testing of the car.
We also ended up changing the spark plugs in my car as it has 53k miles. I know they're not technically due until 60k, but I figured with as many track days as the car has seen and the fact that she's about to go FI, it couldn't hurt. We did have to loosen the motor mounts and jack the engine up to change them (Boxer engines for the lose as far as that goes). Not fun.
Lastly, the hoses don't seem to be labeled at all. Not sure if this is the norm or the exception. The instructions included with the kit seem to think that they're all labeled, but I couldn't find anything on any of my hoses that seem to imply where they all go. Doing a bit of reverse engineering and eyeballing from the included install pictures to determine it. So far, no major issues. Planning on snapping a few pics along the way to show what goes where just in case others have the same problems.
Stopped for the evening after getting the IC mounted. Hoping to finish up tomorrow afternoon!
Showing which 3 hoses are fit to the heat exchanger...
Will update tomorrow, hopefully after I get a chance to drive her! I'm also planning on taking videos, so stay tuned!
Old 04-08-2015, 03:51 AM   #21
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Subbed! Great journal. Screw the cars, you got a big f'ckin house!!!!
hmong337 is offline   Reply With Quote
Old 04-08-2015, 11:01 AM   #22
Honad
Drives: 2013 Series 10 FR-S
Heh, thank you.
That's actually my house.
Honad is offline   Reply With Quote
Old 04-08-2015, 12:16 PM   #23
enigma
Drives: Asphalt 86
Originally Posted by Honad View Post
Heh, thank you.
--^ Lol, indeed! It's my brother's house (whose Series 10 is in the driveway ). I just use him for his help and his lift. :p
Old 04-10-2015, 03:32 PM   #24
enigma
Drives: Asphalt 86
April 10th, 2015
4AM... something burbles to life.
I'll post more when I have more time, but something finally came to life around 4AM last night...
Initial thoughts without having the time to give a full write up? My gentlemen bits made my pants shorter while driving it. Just awesome. This is how this car should have come from the factory.
The Following 5 Users Say Thank You to enigma For This Useful Post:
Ammunition (04-10-2015), craigpitts7 (05-28-2015), GuerillaRacing (04-10-2015), Insurme1 (05-05-2015), Scottemad123 (04-10-2015)
Old 04-10-2015, 03:39 PM   #25
weederr33
weederr33's Avatar
I came.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
drewbot (05-29-2015)
Old 05-28-2015, 04:21 PM   #26
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Sub'd!! Really hoping I get to catch you Tomorrow.
DustinS is offline   Reply With Quote
Old 05-28-2015, 07:26 PM   #27
craigpitts7
craigpitts7's Avatar
Drives: 2013 WRB BRZ
You have a really nice car and a good eye for quality.
craigpitts7 is offline   Reply With Quote
Old 05-29-2015, 03:07 PM   #28
Top-Secret
Drives: FRS monogram
what made you pick the cosworth SC or say vorteck or kraftworks?
Top-Secret is offline   Reply With Quote
Ohlins Road & Track - settings (clicks) for street/track/ax dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-27-2016 10:36 PM
MVP Track Time 2013 Great Lakes/Midwest Track Dates Feffman Great Lakes 5 09-07-2013 02:39 PM
FT/IL asphalt FR-S bumper for your asphalt BR-Z front cover asphalt_fr-s Exterior Parts (Aero, Lighting, Etc.) 0 06-04-2013 11:34 AM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs NY / NJ / CT / PA 11 08-21-2012 12:31 AM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs Tracking / Autocross / HPDE / Drifting 0 08-14-2012 07:46 PM
