Old 08-22-2014, 03:17 PM   #15
CrazyWookiee
Drives: Whiteout FR-S
I did not have to remove my real bumper. This is how I did it:
1. Cut out templates for cut outs and lip height mount.
2. Use a dremel to make holes and then after cut from hole to hole (kind of like pumpking carving)
3. Sanded using dremel.
4. Remove screws/bolts inside the back wheel well.
5. Remove all underside clips connected to rear diffuser area.
6. Turned all double sided tape outwards. Then two people stick to bumper.
7. Put screws on rear wheel well into bumper.
8. Check alignment with lip height mount template. Stick down.
9. Admire dope rear end.
It was actually a pretty simple process. Just cut, remove bolts/clips. Stick it down, then screw it all in, remove all double sided tape covers.
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
The Following 3 Users Say Thank You to CrazyWookiee For This Useful Post:
86Toyobaru (08-23-2014), TheBRZsKnees (03-09-2017), van_fc3s (08-28-2014)
Old 08-23-2014, 11:27 AM   #16
86Toyobaru
Drives: 86 & GRB
Awesome.
Can you more detail about step 2?
How many holes did you make first before cutting? And which spot to make hole?
For cutting tool, did you use supply knife/saw that came with kit? Or using dremel to cut?
Sorry to ask many question. I never did bumper cutting before so kind of worry about to mess up OEM bumper.
86Toyobaru is offline   Reply With Quote
Old 08-25-2014, 01:21 PM   #17
CrazyWookiee
Yeah, no problem.
I used my dremel's cutting tool to punch holes through it. It's pretty much a drill.
The template makes you line it up with the rear tow hook covers on the original bumper. There's the black squares, so the template lines up with that. I drilled a hole maybe every half inch all around based on the template. Then I used the dremel cutting tool to cut from hole to hole.
After i used the dremel down the rough edges.
Originally Posted by 86Toyobaru View Post
Awesome.
The Following User Says Thank You to CrazyWookiee For This Useful Post:
86Toyobaru (08-25-2014)
bumper, diy, exhaust, trd
WTB: South East PA BRZ front bumper, rear bumper. SterlingBrz Want-To-Buy Requests 1 06-10-2014 11:37 AM
Rear Bumper removal / bumper latch SmartedPanda Cosmetic Modification (Interior/Exterior/Lighting) 3 05-01-2014 02:27 PM
Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision n7011n Exterior Parts (Aero, Lighting, Etc.) 7 03-26-2014 05:46 AM
Big Dent in rear bumper, any carbon fiber rear ends? bdohazelnuts Cosmetic Modification (Interior/Exterior/Lighting) 4 10-22-2013 05:22 PM
WTB: WRB Rear Bumper afohlin Exterior Parts (Aero, Lighting, Etc.) 3 06-27-2013 10:30 AM
