Old 06-29-2014, 12:41 PM   #15
arghx7
Drives: car
+1 for air pocket
arghx7 is offline   Reply With Quote
Old 06-29-2014, 06:20 PM   #16
steve99
Originally Posted by D K View Post
Tried all that.....
Will try again.
Temps got to 224 after 5-6 hard laps.
If you have bled system of air
Any chance of a restriction/partial blockage ?
Kinked pipe , thermostat not opening correctly, do you have one of those heat exchanger oil coolers ? that go into a radiator hose restricting flow or causing waterpump to cavitate.
do you have underdrive pulleys
check drive belt tension
Old 06-29-2014, 10:22 PM   #17
wparsons
wparsons's Avatar
I would bet it's either an air pocket or something wrong with the thermostat, and nothing to do with the sensor getting heat soaked.
flickr
Old 06-29-2014, 10:32 PM   #18
Poodles
Drives: 2015 Series.Blue
Full list of mods done?
Old 06-30-2014, 03:51 AM   #19
brn12345
brn12345's Avatar
So here are a few things that come to mind:
1. The FA20 uses Subaru Super Coolant (Blue). Any coolant you use should have similar cooling properties.
2. The bleeding procedure needs to be followed otherwise your sure to have cooling issues. Procedure is as follows:
- TURN A/C switch to off
- Fill through filler neck till full
- Pump radiator hose several times and add coolant if it drops
- Open the bleed valve located on the heater hoses near the firewall
- Add coolant as required
- When coolant comes out of bleeder close it and top up filler neck
- Fill reservoir tank to the full mark
- Tighten radiator cap
- Start engine and rev it a few times (don't let it warm up too much as you need to do the next step before thermostat opens!)
- Remove radiator cap, and open the bleed valve and fill with coolant and keep doing the procedure above until coolant does not drop
- Ok now turn on the heater to max hot and fan low and run the engine until the radiator fan starts and stops
- You want to wait now for the coolant to drop safely so that you can remove the radiator cap and check coolant level. Add coolant if needed.
- If you hear gurgling sound from the heater side it means you did something wrong and you have to redo the whole process.
Yes it might seem like a lot of work, but it really is imperative to get all air out of the system.
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
The Following 2 Users Say Thank You to brn12345 For This Useful Post:
Strife26 (05-28-2018), wparsons (06-30-2014)
Old 06-30-2014, 04:09 AM   #20
suaveflooder
Pretty sure @stugray nailed it. Get the nose up a little and get that air bubble out
suaveflooder is offline   Reply With Quote
Old 06-30-2014, 04:15 AM   #21
D K
Stig's dark passenger
Nope
Nope
Nope
Nope
All the obvious have been checked or I wouldnt have posted here....
Its fine on the street or light load on track.
When you hammer it, second lap, ck eng light/p0117
D
D K is offline   Reply With Quote
Old 06-30-2014, 04:16 AM   #22
D K
If it was the tstat, it would happen irregardless of load
Old 06-30-2014, 05:12 AM   #23
steve99
Nope
Nope
Nope
Nope
D
I admitt we are all guessing here mate but we also dont know what mods you have and what the history is.
Assume your boosted and reciently installed new radiator , as you say its fine on street and light track work but carnt cope with heavy work on track.
Would indicate sensor is ok and maybe it just carnt cope with a hard workout, what are ambient temps ? what boost are you running 15 psi plus ?
have you made any mods to front of car or airflow through radiator
have you removed or modified undertray ? vented bonnett or other engine bay venting ?
Old 06-30-2014, 02:06 PM   #24
D K
Yes supercharged. Very light boost, under 9.
No airflow mods (except the ic - which may be blocking)
Stock hood - no vents.
No mods to undertray
Oil cooler for both engine and sc.
Ambient 100 farenheit
Im gonna install a manual water temp gauge to get a better idea
Cheers
Old 06-30-2014, 03:13 PM   #25
wparsons
wparsons's Avatar
Are you currently logging the coolant temp? Does the log behave exactly like the gauge, or is it responding normally?
flickr
Old 07-01-2014, 05:03 AM   #26
D K
I don't have a logger at mo, but I used the AIM Solo DL for a couple of sessions, and it stayed in the 195 deg range. Gauge was normal.
I'm waiting for an ecutek cable, so I can log more.
Old 07-01-2014, 12:42 PM   #27
stugray
Drives: 2013 GBS BRZ Limited
you can log with a $10 ELM 327 from ebay & the Torque app.
Or for $140 you can log with a tactrix dongle/cable.
Neither of those require a Laptop to be connected to log.
Unless you have ecutek already and they dont allow third party OBDII logging. (I would have a hard time believing that)
Old 07-01-2014, 02:46 PM   #28
D K
Yea, I actually have that already.
I forgot, I've been very busy.
I will confirm, but I will bet my last dollar that one the street it won't go anywhere near the upper limit.
D
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 06:47 PM
p0198 code oil temp sensor malfunction circuit high kingkai23 Forced Induction 10 06-17-2014 02:22 PM
Coolant Temp Gauge? Pacific Auto Issues | Warranty | Recalls / TSB 4 01-20-2014 05:00 PM
OEM Oil Temp Sensor Location Khorne Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 01-15-2014 11:38 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-30-2013 12:50 AM
