Old 07-03-2014, 01:25 AM   #71
BolognaWalrus
Drives: too soon junior
Originally Posted by BolognaWalrus View Post
Will these new maps come with LC/FFS for the b01c roms?
Bump!
BolognaWalrus is offline   Reply With Quote
Old 07-03-2014, 01:25 AM   #72
steve99
Originally Posted by keen as View Post
Hopefully E85 tune improves cold weather starting. I've had some cold winter mornings in Sydney.
Add three or four litres of 98 petrol to full tank of e85, should sort it even E50 has enough octane rating for us NA guys
keen as (07-03-2014)
Old 07-03-2014, 07:46 AM   #73
ZZT86
ZZT86's Avatar
Drives: BR86
It will do the opposite ! But if you run E70 it will be just fine & dandy
ZZT86 is offline   Reply With Quote
Old 07-03-2014, 10:59 AM   #74
wparsons
wparsons's Avatar
I think he was saying he hopes the new e85 tune improves cold starts over the current one.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Old 07-03-2014, 02:12 PM   #75
Iamthebatman
Drives: Black Subaru BRZ
Slightly off topic:
If i currently run catless headers and stock OP/FP with an OTS UEL Stage 2 tune, and I swap out my OP/FP with a high-flow cat downpipe (Nameless), will I need a retune? Or will the OTS UEL Stage 2 map still work?
Iamthebatman is offline   Reply With Quote
Old 07-03-2014, 02:20 PM   #76
wparsons
wparsons's Avatar
Do you want a fully optimized tune, or just something that works safely?
flickr
Old 07-03-2014, 02:23 PM   #77
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
It should work just fine but with a custom tune and op do with high flow cat you should be able to pick up a few more horses at the most
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 07-03-2014, 10:40 PM   #78
PantsDants
Drives: Scion FR-S A/T, Whiteout
For the 1.6 testers running the 91 octane maps: What does the knock situation look like on the freeway? Particularly in the 2000-3000 rpm, 0.6-0.8 g/rev range?
PantsDants is offline   Reply With Quote
Old 07-04-2014, 12:12 PM   #79
wparsons
wparsons's Avatar
I can check some logs, but I'm getting some knock on the highway. Only enough to drop my IAM down to about 0.7-0.8 at worst, but it's still there. I haven't pulled any logs with 94 to see what it was like either.
flickr
PantsDants (07-05-2014)
Old 07-05-2014, 04:49 AM   #80
Pistol
Drives: 86
actually ran my battery flat this week, unable to start the car in the morning on e85
have switched back to "normal petrol " for now , i have a dealership service coming up anyway
probably go to the mixture e85/ petrol after that
Pistol is offline   Reply With Quote
Old 07-05-2014, 10:41 AM   #81
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by solidONE View Post
It seems the cam timing has been changed to reduce 'induction noise'. I'm assuming it's the vibration sound when the cams are fully advanced at the mid low range. I don't know about you guys, but if this means that there is a penalty in power output and no benefit besides noise reduction at that range... I no likey.
I'm going to assume it doesn't since Shiv posted earlier the 1.6 made 5-6whp more than the 1.59 stage 1 maps.
These are not mutually exclusive. He could have sacrificed a small amount of power lower in the lower rpm range and figured out how to get more up high.
Old 07-05-2014, 11:09 AM   #82
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Yeah, I guess so.
He's the only who knows for sure currently.
Old 07-05-2014, 06:56 PM   #83
Lytheum
Drives: 2013 BRZ Premium 6MT
Am I the only one that likes the noise?
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 07-05-2014, 07:37 PM   #84
KonTheory
Drives: '14 FRS
nope
'14 Raven FRS - Toyota Badges - Helix Smoked Side Markers - K&N Drop-in - 3" Nameless Axleback 4" Mufflers - Tinted Back Windows - RCE Yellow Springs - Openflash Tablet - OLM HID Kit - Cusco strut bar - TRD Quickshifter - 17x9 Enkei RPF1's with Nitto NT05's
KonTheory is offline   Reply With Quote
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 01:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
OpenFlash Tablet E85 (and gasoline) Maps now available Shiv@Openflash Software Tuning 401 08-14-2014 12:14 AM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 05:43 AM
OpenFlash Tablet: USDM Stage 2 EL/UEL testers needed Shiv@Openflash Software Tuning 13 01-05-2014 01:42 AM
