#15 | |
Drives: White BRZ
And as renfield90 said, stay on the originals as long as possible. They will, in fact help you learn more than a RE-11 or RS-3 at this stage of your DE career. |
#16 |
Thanks
Thanks for the replies guys. I am going to run the stocks for this event then inspect them again after. I just had the wheels off to look at the brakes and there is some very minor chunking in some spots but I'm sure I can run them for these 2 days at VIR then reassess.
I think I am going to swap tires left to right because I saw more wear on the front left than front right. Also going to buy a better tire gauge so I can monitor them, I may have had improper pressures.
#17 | |
Drives: White BRZ
If that is the case I would not make the trip to VIR without an extra set of pads with me if not just go ahead change them now. Who are you going to run with at VIR? |
#18 |
Drives: 2013 Scion FR-S, 2014 Lexus IS350
Replace your tires when:
(a) the tire cord is showing; (b) the tire has blown out, or; (c) the tire has been stolen; Hope this helps ![]() But seriously, you do have some life left on those tires. Check the "tire wear indicator," which is a horizontal bump in the tred groves. You'll have to find it but once you do you'll have a good indicator when you should consider replacing the tires. Edit: I did see your wear indicators and they still look below the tire tred. I'd keep rocking the tires and keep your eye out for some good deals. Also, if you see any good deals on Tirerack.com or other good venders Discount Tires will usually match their prices so you don't have to ship tires online. I save about $60 a tire through them. :p Last edited by shiro; 07-01-2014 at 10:42 AM. Reason: Added info |
#19 | |
Drives: '13 FR-S
| Best Tires, Favorite tires. Thoughts? | samisons | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 12-14-2013 10:11 PM |
| TIRES, TIRES, TIRES! @ Pure Automotive Performance | Pure Automotive | Wheels and Tires | 1 | 02-04-2013 03:32 PM |
| Hate the Tires I got with my winter tires | PoRco | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 01-01-2013 12:49 AM |
| FS: Gramlights 57d 17x9 +38 5x114.3 w/ tires 1500 miles on tires, $1800 shipped | apexsti46 | Wheels and Tires | 6 | 09-05-2012 03:54 AM |
