| View Poll Results: What side seal have you had a problem with | |||
| Driver's side seal problems |
39 | 45.88% |
| Passenger side seal problems |
4 | 4.71% |
| Happend on both sides |
19 | 22.35% |
| Seal problems? I ain't got no seal problems! |
23 | 27.06% |
| Voters: 85. You may not vote on this poll | |||
#29 |
Drives: 2013 Scion FR-S - Argento
Mine do it, driver's side for sure, passenger's I think at time.
My bigger concern is the driver's side has started to leak air at the upper back corner. I can't feel it, but I can hear it and put my hand back there and push the rubber against the glass and make it stop. Not holding out much hope for a dealer fix, just like the other little issues w/ the car. |
| The Following User Says Thank You to cycleboy For This Useful Post: | suaveflooder (06-26-2014) |
#30 | |
#31 |
I noticed my car doing this after I washed it one day. It's not folding on the top part of the widow, but on the side.
| The Following User Says Thank You to funwheeldrive For This Useful Post: | suaveflooder (06-28-2014) |
#32 |
Drives: FR-S,GTI
Yeah
My car used to do this. It's caused by the window grabbing hold of the seal and pinching it as it goes up instead of sliding past it. I stopped it by armoralling it once a week. It makes the rubber soft and slippery as hell. |
| The Following 3 Users Say Thank You to WNDSRFR For This Useful Post: |
#33 |
Drives: 2014 BRZ Limited
I was wondering why nobody had mentioned that yet. Mine isn't doing it, but if it were my first thought would be to try Armorall to lubricate the seal. Does it have any down sides? (Discoloration, residue on the glass, etc.)
#34 |
Drives: 2013 Asphalt 6spd
I tried 303 protectant, but it didn't work for me. I saw others say that silicone sprays didn't work for them, I guess it goes on a case by case basis. worth a try anyway.
#35 |
I use 1Z Einszett Rubber Care Stick “Gummi Pflege” on mine. http://www.autogeek.net/1z-einszett-...are-stick.html
I didn't have the seal catching problem to begin with, so I can't say that the Gummi Pflege fixes trhe problem or even keeps it from developing, but definitely worth a try. What I 've heard about tint on windows, is that it's actually more slippery than glass. I'm also tinted. |
#36 | |
aeiou
Drives: WRB BRZ
For those with issues, do you have window tint?
And if so, did lube help out?
#37 |
Drives: Scion FR-S
Have window tint, lube has worked to a degree, but limited success. I've tried tire shine and I've tried silicone spray.
| The Following User Says Thank You to kodyo For This Useful Post: | suaveflooder (06-29-2014) |
#38 |
Master Installer
Drives: Scion FRS
I have it too!
-Wind sound on the freeway, I can pull in down to fix it -Water leaks a little when washing -No tint on car -15k miles, started shortly after getting car Going to wait for more serious problems before going to dealer to get everything fixed. Problems so far: -Dash peeling up -Crickets -Window seal |
| The Following User Says Thank You to Pacific Auto For This Useful Post: | suaveflooder (06-29-2014) |
#39 |
Drives: 86 GTS
Mine had been back 3 times to have this fixed. In the end I did it myself. Best option is to align the window internally so it puts less pressure on the seal when it closes.
This is the relevant adjustment screw. Best to take off the locknut and understand how it works before adjusting. If this concerns you then take note of how you adjust so you can put it back. |
| The Following 5 Users Say Thank You to 86•BRZ For This Useful Post: | civicdrivr (07-03-2014), extrashaky (07-01-2014), Joon525 (10-26-2017), roddy (09-09-2014), Target70 (07-01-2014) |
#40 |
Drives: '13 Ultramarine
I spoke with my service manager yesterday. They are going to replace both sides under warranty along with a couple of other things.
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 07:09 PM |
| window seal? | ravenblackfrs | Issues | Warranty | Recalls / TSB | 3 | 01-29-2014 06:12 PM |
| Drivers Side Window (Not Seal) | Mister | Issues | Warranty | Recalls / TSB | 20 | 12-16-2013 03:56 PM |
| Window Seal Leaves Marks on Windows | AsianStyle | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 13 | 09-22-2013 04:28 PM |
| Does anyone else have this problem after lowering their BRZ? (pics included) | Calin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 01-28-2013 12:59 AM |
