#85 |
#86 |
Drives: 2013 FR-S, Manual, Argento
For my V1, I just used the concealed power outlet on the firewall, and ran a hidden cord behind the interior trim to a spot next to the rearveiw mirror. See page 30 of the document available here. Smooth as silk, and properly switched with the ignition.
#87 |
Drives: S14K
you do not need to go all the way to the fuse box for ignition power. you can tap the source from inside the cabin from the cig. lighter or radio.
V1 sells the concealed display kit if you dont already have it Direct-Wire Power Adapter Item 20305 and if you have it and your bringing it from another car you can just order the Wiring Harness Connector Item 20310 or just pick it up at a electronics store such as fry's or radioshack |
#88 |
F Z1LLA
Drives: Lexus IS-F Series 2
Has anyone done a DIY on HID bulb swap for BRZ ? Read in another forum that it was a real pain to do ?
2URGSE |
#90 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
Need a DIY for gear oil and how many qts do i need
#91 |
Drives: GTS86 Manual
hi ya .... would love a DIY to remove rear bumper
cheers |
#92 |
Drives: 13 GTI
Replacing the spark plugs without having to lift the motor.
#93 |
Glorious BRZ Master Race
Drives: Subaru Libird
I can't find a DIY on removing the radio surround/passenger side dash panel (the 2 pieces with textured mesh on the FR-S or silver on the BRZ). I don't want to break any clips and remember reading someone dropped fasteners down behind the dash panel when working on these pieces and had to order new ones. It's a seemingly simple thing to work on but I prefer to not be pulling on these pieces blindly hoping things don't snap/fall into the abyss.
#94 | |
Love Boost!!!!!!!!
#95 |
Love Boost!!!!!!!!
how to change Differential Oil???
#96 |
Drives: 2013 FRS Whiteout
It's a 7/16 if I'm not mistaken allen key for both drain and fill. Jack up and use jackstands front and rear to have car leveled. Unscrew the fill bolt and then the drain plug, watch it drain. Once drained get your quart, you'll need 1.2 quarts, use a little bottle pump sold at amazon to pump the fluid from your quart into your differential. Pump fluid till it drips out the diff, bolt back in. Clean your mess and you're done.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
| The Following User Says Thank You to yomny For This Useful Post: | whitefrs (09-23-2012) |
#97 | |
Love Boost!!!!!!!!
#98 |
if i could be of further assistance let me know.
| Going to Hermosa Beach this Saturday...Any requests? | dookie11 | BRZ First-Gen (2012+) -- General Topics | 97 | 03-16-2012 06:13 PM |
| Last second photo requests for TMS debuts? | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 40 | 11-30-2011 03:13 PM |
| Speedhunters article | KyShro | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 09-23-2010 06:09 AM |
