86WORX
Old 08-28-2015, 07:20 PM   #645
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Originally Posted by Soyuhhh View Post
Yesterday I received and installed my OFH but I had trouble with screwing in one of the o2 sensors. I stripped one of the o2 sensors a little bit and I didn't screw the o2 sensor all the way so now the ring on the o2 sensor rattles when I drive. Anyone else have this problem?
Originally Posted by efactor84 View Post
I have the o2 rattle and haven't found a solution. As far as the o2 being loose or stripped, I would use Locktite. This helped my front o2 sensor from coming loose for awhile with no issues regarding to my fuel trims and afr balance.
Hey man, it's not stripped I don't believe. The OEM header had a metal outer cover that makes the washer flush. You just need to add a thick washer spacer in between the O2 and the header and the rattle is fixed
Sent from my SM-G900V using Tapatalk
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 08-28-2015, 08:32 PM   #646
Teseo
Drives: frs
Safe way for all aftermarket headers?
Old 08-28-2015, 09:47 PM   #647
Poodles
Drives: 2015 Series.Blue
No no no, you use ANTISIEZE on the O2 sensor threads!
Unless you like having to heat the O2 sensor and header up to red hot to remove the O2 sensor in the future...
Old 08-29-2015, 02:31 AM   #648
Aztec
Aztec's Avatar
yeah should be fine, the stock header had a huge heat manifold that made the washer snug
NEW CAR!🚨🏎️⛽
Old 08-29-2015, 03:27 AM   #649
steve99
+1 on that ,just don't get any on the sensor tips.
and run a M18x1.5 thread tap/chaser through the o2 bungs to clean them up so sensors screw in easy
Old 08-29-2015, 12:24 PM   #650
efactor84
efactor84's Avatar
Drives: 2015 Scion FR-S
Make sure you get the blue label. Avoid green and red, which would make it a permit seize.
efactor84 is offline   Reply With Quote
Old 08-30-2015, 02:06 AM   #651
Poodles
NO. Do not use thread locker! Antisieze is what you need.
If the threads in the header or O2 sensor are messed up, chase the threads. You can use a thread file too if needed.
Old 08-30-2015, 11:41 AM   #652
efactor84
efactor84's Avatar
I'll find out later this week as I plan on removing my headers.
Old 09-02-2015, 06:01 PM   #653
spicyricecake
spicyricecake's Avatar
Drives: 2017 CWP BRZ Performance Package
I have the OFT+OFH set up on my 15 Series blue BRZ.
@Shiv@Openflash
when will you push launch control in the tune for 15 series blue BRZ?
spicyricecake is offline   Reply With Quote
Old 09-02-2015, 06:19 PM   #654
cameronjones239
cameronjones239's Avatar
Drives: 2015 Subaru BRZ Series Blue
@Shiv@Openflash
http://www.ft86club.com/forums/showthread.php?t=93631
cameronjones239 is offline   Reply With Quote
Old 09-03-2015, 04:11 AM   #655
Lord09
Drives: 2015 BRZ
Apologies if this has been asked before, but I know it's highly recommended to replace the gaskets between the header and the engine and overpipe, but I've read many recommend unbolting the front pipe to the mid pipe to maneuver the overpipe away from the header to allow it's removal.
My question is, should the gasket be replaced between the mid pipe and front pipe?
Also, apologies if I've gotten my exhaust terminology incorrect.
Lord09 is offline   Reply With Quote
Old 09-03-2015, 04:43 AM   #656
steve99
i installed my ofh without loosening or removing anything other than header connections.
however we a right hand drive so might be some clearance issues on LHD car dont know
the midpipe/frontpipe gasket is a doughnut and can be re-used if you do loosen it
see the basic bolt on mods link below its got diagrams and tips on installing header
Lord09 (09-03-2015)
Old 04-08-2018, 01:31 AM   #657
febrz
Drives: silver brz 2013 lmtd
Is it me or are the tunes EXTREMELY raspy, the first 100 miles...
febrz is offline   Reply With Quote
Old 04-08-2018, 06:34 AM   #658
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I thought it was just my car? I know I have a shitty gasket between the mid-pipe and axleback, I figured it just got worse over time..... maybe I didn't have to order new gaskets after all and it's jut the tune?
Ah well, the axleback gasket and the donut gasket are getting changed out anyway!
Open Flash Header - Sound and Performance Comparison nlowell Engine, Exhaust, Transmission 41 05-19-2014 07:29 PM
FS: Open Flash Header - SoCal Pickup nlowell Engine, Exhaust, Bolt-Ons 9 05-12-2014 07:29 PM
Open Flash Tablet Andrew025 Engine, Exhaust, Bolt-Ons 3 04-26-2014 06:03 PM
Open Flash Header Catless Clip Vmax911 Engine, Exhaust, Transmission 25 03-08-2014 07:51 AM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
