#239 |
Drives: 10 Series #974 6m/t
Can't wait to see how the exhaust will look. Been following this awesome build for some time now.
| The Following User Says Thank You to NyC Zn6 For This Useful Post: | DustinS (01-06-2016) |
#240 |
Drives: 2013 Ultramarine FR-S
I am also looking into routing the radiator out the hood. I.E.
![]() ![]() ![]() ![]() I am sure I will have to split it into two different vents to clear the turbo, but I think it might be possible. Going to go over this a little later. Plans just keep piling up Edit: Well if I Had actually looked at my previous pictures, I would know its next to impossible with current turbo piping. Going to have to work on this one in the background.
#241 | |
Site Moderator
Drives: ichi 86 Project
![]() btw, good read. Keep up the awesome job! |
| The Following User Says Thank You to ichitaka05 For This Useful Post: | DustinS (01-06-2016) |
#242 |
The more I think about it, the more I think something like this may be possible:
![]() ![]() ![]() I will have to work around the A/C condenser, as I would like to keep the A/C. I have to tear into the car to find a coolant leak. So I may visualize things while I am in there. Or possibly tilt the top of the radiator/intercooler into the nose of the FRS bumper (about where the bottom of the intercooler is in the picture). Then I should have enough room to vent the back of the radiator up out the top of the hood. @mrk1 What are your thoughts on something like this?
#243 |
Worked on the cluster a bit. I tried moving the REV limit LED to under the RPM Needle. I think it would work if we didn't have so many LEDs lighting the needle. I may work on it later with a brighter LED. The RED leds I tried just couldn't overpower the 4 blue. There isn't enough power supplied to power more than 1 LED as well.
![]() I also changed over the Traction Control LEDs. I went with green because I had them and hate amber. ![]()
#244 |
Finally got snow. Not enough to do anything though:
![]() Suppose to get more today and Thursday. I hope it is a lot On a not so great note, I started smelling burning oil, was sure where it was coming from. After it didn't go away, figured it wasn't a car in front of me: ![]() ![]() Goes all the way down the block. Going to be a pain to clean up. Oil for the oil change should arrive today, so I will fix it all when I switch the filter today.
#245 |
leaking from the sandwich or line fittings?
#246 |
#247 |
Drives: 2013 Subaru BRZ Limted
OP, might be late one this. Do you happen to have any pics of the headlights at night? With your painted stock ones? Very much like the build.
| The Following User Says Thank You to Subie_Nubie For This Useful Post: | DustinS (01-19-2016) |
#248 |
The Demon Eyes, The HIDs, or the Headlights in General?
#249 |
#250 |
I guess I don't quite know what picture you would like.
![]() Here is one at night I took a bit ago: ![]() They just look black. Finally Got Snow!!!! ![]() ![]() I was getting super upset that I went so far as to switch suspension and pay the extra of Off-Road tires and we were getting any snow. Finally got some and the car handled great. I am happy now and the weather can do what it wants. Though more snow would be awesome. On another note. I have been looking at Getting ECUtek w/flexfuel and shooting for mid 300's power wise. Looking at everything involved. $2600 to make the switch. Which means that won't be happening for a while.
#252 |
Got an oil change and fixed my Oil leak today. The fact I have the Drain Valve, and the car is lifted made the oil change super easy. Didn't even need a lift.
Using Old Oil bottles make the prefect Funnel, pretty much threads in to the block and can be used to hold the other bottle while you get the top off the next one. ![]() ![]() @Subie_Nubie ![]()
| The Following 2 Users Say Thank You to DustinS For This Useful Post: | djdnz (02-03-2016), Subie_Nubie (01-26-2016) |
| The reason I'm always broke - Dustin's Supercharged 86 | Dustin | Member's Car Journals | 211 | 11-08-2015 11:57 AM |
| Help! New Car Engine Blew Up. What are my rights? | Obsidiank | Scion FR-S / Toyota 86 GT86 General Forum | 53 | 12-11-2014 12:43 PM |
| Midwest Modified - Auto Photography by Dustin Faulkner (aka Fancy) | Kuzuri | Great Lakes | 20 | 02-16-2014 06:23 PM |
| Engine Warm-up Time | Chad86 | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 01-10-2014 01:03 AM |
| So my engine blew up.... | alliedcam1 | Engine, Exhaust, Transmission | 57 | 12-28-2013 03:50 PM |
