#57 |
Drives: Many types of cars in R&D.
If one has a clutch type, there isn't really a need for a Torsen to be mixed into it. It may help prolong the life of the clutch, but you also lose all the merits of a pure clutch system by introducing yet more variables in the setup, as well as complexities associated with the dual-pack system like that... Maybe it's good for those who STILL don't want the added maintenance, but... I personally prefer that if I am spending couple grand on the entire swap-over to gain control of a sports car, I would like it to be simple, predictable, and capable of it to be tuned very accurately.
Moto Miwa
www.club4ag.com R&D Driving Engineer, Product Planning Consultant Consulting Member at Cusco, OEM+, RS-R. www.club4ag.com |
#58 |
Because compromise ®
Drives: Red Herring
expletive!expletive!expletive! compromises!
#59 |
Drives: 2012 WRX, 2003 RSX Type S
the wealth of knowledge in this thread alone is epic.
#60 | |
AutoX-10/10ths every run
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
#61 |
Drives: Red Herring
I kind of understand/appreciate what a clutch diff will do coming out of bends on the power but I don't get what the (1.5-2 way) diff will be doing under brakes whilst cornering. Would some one be so kind as to explain the benefit?
#62 |
I'm not an expert, but I believe a 2 way has symmetric ramps for acceleration and braking, and the 1.5 has a different ramp profile for acceleration and braking.
#63 |
Drives: Red Herring
Sure, understood but I'm wanting to know what this does for performance.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | whataboutbob (06-21-2014) |
#64 |
Drives: Honda
As always, appreciate the data and the explanation.
Now show me the laptimes and then take my money
#65 | |
Drives: AE86, 2x GT86, TE27
A locked diff is always locked. A 2way locks up as quick under decel as it does under accel. It's not ideal for circuit, it's more for drifting. There's a couple of guys in NZ that put 2ways in their cars and use it for circuit. As they get more confident with braking and start to threshold brake, they start spinning their cars. On the street, I think a 2way is a bit dangerous unless you really understand the diff. Put it this way, I came around a corner around our hills, and there was some unforeseen road works. Because of the way the 2way works, when one wheel slipped, it locked the diff, it had the same effect as pulling the handbrake. That was not under any braking, just engine braking. I was just lucky that I've done enough drifting that my immediate instinct was to get on the power, not the brake. A 1.5way still has the ability for the diff to lockup in this manner, but the 1.5 means that the decel lockinng/ramp is 50% of the accel. So it would take more for lock up to occur under decel. A better way to understand these diffs is A 2 way is a diff where if the accel lockup is seen as the strength of 1.0, the decel lockup is also 1.0. 1.0+1.0=2.0 eg 2way A 1.5 way is as above, but the decel ramp is only half of accel. So 1.0+0.5=1.5 way. Finally a 1 way will never lock under decel. So 1.0+0 =1 way. So couple more things Those three different "way" diff types all act the same under accel, it's only the decel ramp up rate proportionate to the accel rate that changes. So all you need to ask yourself is how you want it to lock up under decel (if any) As I've said a couple of times, I would most likely run a 1way if all I did was circuit racing. Maybe a 1.5, but certainly not a 2way. I just think of those times when I don't want the rear locking up, and that is under heavy braking and turning into a corner. I think a lot of the confusion with these diffs comes from the 2.0 is a bigger number than 1.5, so it must be better. Eg people thinking of it like stage 1, stage 1.5 etc. But it has nothing to do with that at all. It's entirely to do with how much decel ramp up you want proportionate to the accel, either the same, not as much, or not at all. And I'd say most people don't want much (or any) decel lock up at all. Finally, you can still drift with a 1.5 or 1 way. They'll both still lockup the same under power as a 2 way. It's just it's a bit harder with a 1.5 to initiate a feint (or other 'slowing down' or decel) type drift; and a 1 way won't do it at all. But given the way drifting and particularly FD have become sideways drag racing, you could probably compete in high level drifting even with a 1way. But you'll learn more with a 2way, especially in a low power, low tyre grip car like the gt86. In short 2way - for drifters 1.5way - good all rounder, compromise between 2 and 1. Could be used for circuit. 1way - my choice for circuit. All a drag racer needs as well. Get this one of you never want lockup under decel. |
| The Following 5 Users Say Thank You to diss7 For This Useful Post: | CSG Mike (06-21-2014), GT86_PRAGUE (12-15-2014), killboy (02-01-2016), stevo_12v (06-21-2014), twasd (11-06-2022) |
#66 | |
Drives: Red Herring
#67 | |
But add in a corner to the braking situation and this is where the differences are In the corner the wheels are now spinning at different speeds. As you brake, the 2 way isn't going to be very tolerant of the wheels spinning at these different speeds, so will lock the diff. This means the outside wheel will partially slip as it is forced to only spin at the same speed as the inside wheel. Or the inside wheel will have to skip and bounce so that it can spin the same speed as the outside wheel. Or most likely a mixture of the two. Either way, it's a loss of rear traction, the last thing you want when threshold braking I'm a circuit car. It will likely induce a spin or big oversteer. A 1.5 way will be more tolerant of these different wheels speeds so this point won't be reached as quickly. This is also where the ramp up of the diff comes into play. You may have the ramp up set at a point so that this point with a 1.5 under decel isn't actually reached for a certain corner angle. Which is what csgmike was talking about when he said that a lot of the chatter and binding can be eliminated by not setting the diff up so tight. |
#68 |
Lsds aren't about getting power down (well they are) they are estentially about how tolerant you want the diff to be with regards to its primary function, that is allowing the rear wheels to spin at different speeds.
Sometimes you want them to be able to, sometimes you don't. Most of the time you don't want them locked, and only really want it locked when you want to get more power down than one tyre is able to on its own. |
| The Following User Says Thank You to diss7 For This Useful Post: | CSG Mike (06-21-2014) |
#69 |
Drives: Red Herring
Am I correct in saying that a 1.5 improves braking? My reasoning as follows: Foot on brake, equal braking force to the rear. But the inside wheel is somewhat unloaded compared to outside wheel so the inside wheel has a tendency to lock. So the diff prevents the inside wheel from locking up under brakes around bends.
Is this correct? (Ffs. My shopping list isn't getting any shorter.)
#70 | |
It would also lead me to think that you're onto something, as circuit guys seem to favour 1.5 over a 1, and this is possibly the reason why. |
| Tags |
| uberstupid |
| High-G Cornering Fueling Solution | EAGLE5 | Tracking / Autocross / HPDE / Drifting | 24 | 02-22-2017 09:04 PM |
| cornering-on-rails feeling | notout86 | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 09-20-2015 08:00 PM |
| Engine cutting power after hard cornering... | CSG Mike | Tracking / Autocross / HPDE / Drifting | 19 | 07-04-2015 09:40 AM |
| Traction control light comes even when not hard cornering? | Yamajee | Issues | Warranty | Recalls / TSB | 26 | 04-10-2014 02:04 PM |
| Anyone have the radio switching modes during hard cornering?? | silvercar | CANADA | 4 | 07-08-2013 01:49 PM |
