Old 12-15-2014, 11:35 AM   #309
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Originally Posted by GT86_PRAGUE View Post
Thanks! Is it possible to combine OSG with FD 4.88/5.1?
I have the Cusco with 4.88s in my car.
Lunatic is offline   Reply With Quote
The Following User Says Thank You to Lunatic For This Useful Post:
GT86_PRAGUE (12-15-2014)
Old 12-15-2014, 02:21 PM   #310
Sure is. Let us know how we can assist you with your build.
GT86_PRAGUE (12-16-2014)
Old 03-02-2015, 02:01 AM   #311
The latest spec on the OSG diff is promising... need to test it with stickier tires now...
Old 03-02-2015, 11:51 AM   #312
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
I feel like every time you post you are basically saying "We're going to take all of your money. Maybe not today. Maybe not tomorrow. But we will....."
BatStig is offline   Reply With Quote
The Following 9 Users Say Thank You to BatStig For This Useful Post:
bhmax (12-20-2018), Captain Snooze (08-12-2015), civicdrivr (03-02-2015), drewbot (08-11-2015), GT86_PRAGUE (08-11-2015), new2subaru (12-19-2015), R2RO (12-23-2015), ultra (08-14-2015), wparsons (03-02-2015)
Old 03-02-2015, 03:38 PM   #313
Well, we do have a lot of failed experiments too... and until now, we haven't really had a OS Giken LSD setting that provided enough of a performance gain over an off-the-shelf unit that would be worthy of what we'd put a CSG-Spec label on.
We're gonna keep testing, but we're making progress.
Old 03-02-2015, 03:45 PM   #314
BatStig
Some say.....
BatStig's Avatar
Even if an OS Giken LSD doesn't end up with a CSG-Sec label, you had me interested in an LSD from the OP. A lot more research ensued and here I am: waiting for my wallet's permission to spend spend spend!
The Following 3 Users Say Thank You to BatStig For This Useful Post:
CSG Mike (03-23-2015), drewbot (08-11-2015), wparsons (03-02-2015)
Old 08-08-2015, 10:31 PM   #315
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Can we please delete all of Suberman's posts that derailed an otherwise very good thread?
Sent from my A0001 using Tapatalk
drewbot is offline   Reply With Quote
The Following 3 Users Say Thank You to drewbot For This Useful Post:
BatStig (08-09-2015), CSG Mike (08-09-2015), killboy (02-02-2016)
Old 08-11-2015, 11:42 AM   #316
GT86_PRAGUE
Drives: GT86
Can someone explain me real life advantages of helical LSD over stock torsen (if they are any) on small circuit, drifting and spirited driving (stock power)? Thanks.
GT86_PRAGUE is offline   Reply With Quote
Old 08-11-2015, 12:59 PM   #317
CSG David
CSG David's Avatar
It's actually very simple.
Torsen is load sensitive. As long as both tires have load, the Torsen will lock accordingly. When one tire has a significantly reduced load, the Torsen doesn't lock. We have been able to setup cars successfully to reduce this issue, but not completely eliminate it.
The clutch-type LSD locks...basically almost all the time. 1-way locks progressively during acceleration, 1.5-way locks progressively during acceleration and a little less on decel, 2-way locks progressively/aggressively in accel and decel. What I mean by locking is, both wheels are continuously receiving a consistent amount of power. Unlike the Torsen, when it stops locking, one side spins (all the power due to path of least resistance) and the other side gets nothing.
Hope this helps.
The Following 4 Users Say Thank You to CSG David For This Useful Post:
BatStig (08-11-2015), civicdrivr (08-11-2015), GT86_PRAGUE (08-12-2015), The Racers Line (08-11-2015)
Old 08-12-2015, 05:01 AM   #318
GT86_PRAGUE
Drives: GT86
Hope this helps.
Thanks. I was more interested in differences between stock LSD and Mfactory HELICAL LSD. I had Mfactory 1.5/2W LSD and crash it, so I am looking for a new LSD. I suppose it is like 1W with more grip?
Old 08-12-2015, 10:25 AM   #319
fika84
fika84's Avatar
The Torsen is a helical differential. The only thing you will be changing is the TBR (Torque Bias Ratio) by going to a different helical differential. Torsen/Quaife/OBX helical differentials all work the same, as soon as one wheel has 0 friction, all power goes to that wheel. Whereas with the clutch type/metal plate type when one wheel has 0 friction it will lock both rear.
Out of curiosity how did you brake the 1.5/2W LSD??
fika84 is offline   Reply With Quote
Old 08-12-2015, 12:13 PM   #320
GT86_PRAGUE
Drives: GT86
I jump on a catwalk sideways after/during powerslide. Now one wheel is spinning (zero traction), second is twitching. But it may be something wrong with this dif before, I described it here in some other thread.
Old 08-12-2015, 03:29 PM   #321
CSG David
CSG David's Avatar
Generally "helical" means "Torsen". Clutch-types are more predictable and consistent. If you would like a more custom setup, please let us know.
The Following User Says Thank You to CSG David For This Useful Post:
GT86_PRAGUE (08-13-2015)
Old 08-12-2015, 03:33 PM   #322
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Too bad WaveTrac don't make a diff for our cars.
Sleepless is offline   Reply With Quote
uberstupid
High-G Cornering Fueling Solution EAGLE5 Tracking / Autocross / HPDE / Drifting 24 02-22-2017 09:04 PM
cornering-on-rails feeling notout86 Scion FR-S / Toyota 86 GT86 General Forum 38 09-20-2015 08:00 PM
Engine cutting power after hard cornering... CSG Mike Tracking / Autocross / HPDE / Drifting 19 07-04-2015 09:40 AM
Traction control light comes even when not hard cornering? Yamajee Issues | Warranty | Recalls / TSB 26 04-10-2014 02:04 PM
Anyone have the radio switching modes during hard cornering?? silvercar CANADA 4 07-08-2013 01:49 PM
