#15 |
crew chief
Drives: Race car FR-S
and what kind of lsd has been proven to be good for this platform?
#16 |
Off Topic
Doesn't that defeat the purpose of having a limited slip differential? I recognize that it's not a locker, but suddenly having an open diff when one wheel loses traction makes it seem like the limited slip is REALLY limited.
#17 | |
i'm sorry, what?
Drives: Canada
please note this is for when one wheel loses complete traction (or on very different traction surfaces)
| The Following User Says Thank You to 7thgear For This Useful Post: | CSG Mike (06-18-2014) |
#18 | |
Yes, that's the downfall of a Torsen, but the Torsen type LSD has the least maintenance (change fluid) and makes zero noise no matter the situation. Any clutch type. OS Giken and Cusco are the two we've tested, and both work well, and can be set up to be very daily driver friendly. The Cusco is cheaper up front, but the OSG has a longer service interval for major services. The purpose is to prevent the slip to begin with. We use the Pedal Dance. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Maowc (08-03-2014), RehabJeff86 (06-19-2014) |
#19 | |
Drives: '23 BRZ
Both wheels on the ground, you shouldn't be getting inside wheelspin with a torsen diff. If the inside rear is lifting while on the gas, setup may be off. I haven't tracked an FR-S, so maybe its 55/45 weight distribution is more of a problem here on grippy tires... In my experience, the Torsens in my cars act similarly to the lightly-preloaded clutch/ramp-type in my 240Z. Actually, the FD's T2R acts more like the Z's clutch-type all around than the T2 in the S2k. Yeah, you can crank in a ton of preload and make a clutch-type act practically locked (very high effective bias ratio), but that sucks for handling (unless you just like understeer). With a torsen you're limited to about 2.5-4 bias ratio, but usually that's enough. At least with a well-balanced car... Then again they didn't put a Torsen in the Boss 302 LS (which has similar weight distribution issues as the FR-S/BRZ and a ton more hp) because it was *worse* than the clutch-type that went in lesser Boss 302s... Personally, I'm happy either way. Never felt the need for a Torsen or Quaife gear-type LSD in the Z while others were happily spending $$$$ for them, and don't feel a need for a clutch-type in the S2k or FD. If it works, it works. And if it doesn't work for one driver/car at the track, it doesn't necessarily mean it won't work for another car/driver at the same level. My opinions based on my experiences with other cars, so take it fer what it's worth
| The Following User Says Thank You to ZDan For This Useful Post: | toeout (06-22-2014) |
#20 |
Drives: AE86, 2x GT86, TE27
Mechanical diffs are quite brutal in a daily.
I have one. I run it because it's so much better for drifting. But it does take away alot of street comfort. |
#21 | |
If you're at the limit of adhesion of the rear tires under cornering and accelerating, you'll get single tire wheelspin before both tires spin, because the torque going to the inner and outer wheels are not the same. If you launch the car, then yes, you'll spin both wheels because they're getting relatively even loading, but under cornering, that just isn't the case. |
#22 | |
What brand do you have, and what is your current configuration? |
#23 | |
I'm just stating that the axle binding and tyre chirping that comes with these diffs is something most aren't aware about. I have a TRD 2way. |
#24 | |
The problem is, most retailers just sell LSDs, but don't have a clue about how to actually configure/customize them. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | CxG (08-12-2015) |
#25 | |
It depends how tight you set it. I wanted mine super tight, because its for drifting. There is always going to be binding and tyre squeal in a daily with a mechanical. It just depends on how tight the diff is set, as to how often it happens. Having it so lose that it NEVER happens in a street car, would mean its too loose IMO. |
#26 | |||
Drives: '23 BRZ
With either a clutch-type or a Torsen, frictional forces transmit torque that's trying to spin the inside wheel up over to the loaded wheel side. If setup is such that the rear becomes totally or nearly totally unloaded, then a highly-preloaded clutch type will have the advantage of continuing to drive the outside rear wheel when the torsen will spin the inside. Quote:
PLENTY of Torsen equipped cars have no problem putting pretty big power down at the track on DOT R tires. If your setup is such that you are lifting the inside rear a lot, yeah, you'll benefit from a highly-preloaded clutch-type diff. Lots of Z guys ran rear roll stiffness biased setups that required a superstiff diff, but I went with softer rear roll stiffness (no rear bar) and a very lightly loaded diff. Both methods work, but I liked the way mine handled better... |
#27 | |
IMO, the purpose of a LSD is to be able to have the wheels locked only when you need/want it to be. My interpretation of what you wanted would be that you want them locked permanently. |
#28 | |
If I'm super smooth and slow during a slow maneuver than I can stop it engaging, but its so slow often I don't bother and just let if bounce/bind. Also remember that no matter how tight the diff is, you can always use it like an open diff by pressing the clutch in. I'll often do that say if I need to make a u-turn, I just get enough momentum to do it without power. Every drift car and most of my rwd street cars ive run Nisbro diffs. (NZ Slang for a welded diff) They're good because they always work, unlike a torsen. (My torsen was already getting lazy after 2 drift days) But the 2 way gives me the compromise I wanted, basically all the good things of a locker, but with some small areas where it performs like an open. I don't disagree that I run it tighter than what would be ideal for circuit. I wouldn't even run a 2 way for a circuit car. I'd be much more inclined to run such a loose decel setting that I might as well run a 1 way. But my point from my previous post still stands, that if its so loose that it NEVER binds/engages on the street, then its probably too loose. |
| The Following User Says Thank You to diss7 For This Useful Post: | CSG Mike (06-20-2014) |
| Tags |
| uberstupid |
| High-G Cornering Fueling Solution | EAGLE5 | Tracking / Autocross / HPDE / Drifting | 24 | 02-22-2017 09:04 PM |
| cornering-on-rails feeling | notout86 | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 09-20-2015 08:00 PM |
| Engine cutting power after hard cornering... | CSG Mike | Tracking / Autocross / HPDE / Drifting | 19 | 07-04-2015 09:40 AM |
| Traction control light comes even when not hard cornering? | Yamajee | Issues | Warranty | Recalls / TSB | 26 | 04-10-2014 02:04 PM |
| Anyone have the radio switching modes during hard cornering?? | silvercar | CANADA | 4 | 07-08-2013 01:49 PM |
