#183 | |
Drives: '23 BRZ
If you're running Hoosiers or slicks with aero that gives rear downforce at speed, I can see how you might need a stiff clutch-type diff to power out of lower-speed corners. For the vast majority of people who drive these cars "spiritedly", and for a solid majority of those who mod and track them, probably unnecessary. When my S2k is retired from street duty and becomes a track whore, the diff is going to be the LAST thing I mod, if ever. If I never get inside wheelspin, I'll never change the diff. |
#184 | |||||
Drives: '23 BRZ
If a well-developed nationally competitive track car *might* benefit, that does NOT mean that most of the cars on these forums that are tracked will benefit. Quote:
Totally agree that disconnecting a link is a great way to easily change handling balance. That you gained 2 seconds disconnecting yours doesn't necessarily mean the stock Torsen sucks, just that your suspension setup was off. Yes, a tight clutch-type diff will require very different suspension setup than a Torsen, but that's because a tight clutch-type induces understeer which you then have to *correct* with the suspension setup. A lightly-preloaded clutch type or a Torsen doesn't induce as much understeer and allows a more "natural" suspension setup. I've driven Z's with very tight clutch-types, and I greatly preferred the handling characteristics of mine with its ~20 lb-ft breakaway stock Z31 turbo diff. Never a problem putting 250ish rwhp down on Hoosers, even with stiffer rear wheel rates and the S30's higher rear roll center (further loads outside/unloads inside rear under hard cornering). FWIW, I didn't disconnect the rear bar due to inside rear wheelspin, it was because someone commented that I was going around the South Oval turn at about a 10 degree slip angle! I reasoned that that could *not* be the fastest way around... Last edited by ZDan; 08-09-2014 at 02:05 PM. |
#185 |
Drives: Hydra EMS Powered FRS Raven Black
[QUOTE=ZDan;1890605] Haven't tracked an FR-S/BRZ yet,.........[/QUOTE=ZDan;1890605]
Just want to make sure everyone knows that your strong opinions are based on zero FRS/BRZ track setup knowledge. I'm not saying you don't have valuable information to add about other platforms and how they "might" be similar to this car. Now Mike and I do have practical setup knowledge that will help most enthusiasts and I have knowledge that can help the 1% that are going for track records. Thanks, Phil Grabow |
#186 | ||
Drives: '23 BRZ
[quote=Element Tuning;1891063]
My experience with the Z was that many who tracked them were entirely too eager to either weld the diff (eww...) or shim the 300ZX turbo clutch type diff up to 90+ lb-ft for track work, which IMO did nothing at all for the handling of the car and wasn't at all necessary to put the power down anywhere. For sure car setup and driving style will be big players on whether or not a tight clutch diff is called for. To tell the truth, I had ordered the shims/belleville springs for the R200 clutch-type in the Datsun to bump it up to the Nismo-spec 45 lb-ft, but I never installed them because I never got inside wheelspin, even over 15+ years of tracking it with evolving suspension development. And I never tried to set the suspension to overcome any shortcomings in the diff. In my experience with the Torsens in my S2k and RX-7, I have found them to behave very similarly to the light-preload clutch-type I had in the Z. I just find it hard to believe that for the 99% an aftermarket clutch-type is warranted. For the 1%, maybe, but then again you yourself said you've been happy with the Torsen! With 400+hp, 325 *slicks*, and downforce! For sure, no one should just think buying a clutch-type will *for sure* be an improvement. I would strongly recommend that anyone buying a customizable aftermarket clutch type make sure what they really want/need. There are a TON of options, including initial breakaway preload and different clamping rates for accel/decel. Anyone who wants to look at the pretty staggering array of options for a cool aftermarket clutch-type, have a look at this: http://www.cuscousainc.com/downloads..._lsd_guide.pdf It is very cool to have a gazillion options (I would try the Hybrid, or maybe the ProAdjust with a low initial torque setting), but how many are going to even get close to optimizing them all for their specific setup and usage? Again, the 1% can take advantage of this, but the vast majority of casual track-day warriors aren't likely to be able to. Last edited by ZDan; 08-09-2014 at 06:33 PM. |
#187 |
Funny you say that... front/rear LSDs went in the WRX we're building before anything else... even before an initial alignment...
#188 | ||
If you're in Socal, I'll arrange for it to happen. Quote:
| The Following User Says Thank You to CSG Mike For This Useful Post: | ZDan (08-09-2014) |
#189 | |
Drives: FR-S Whiteout
Carry on, gentlemen. Just trolling by.
#190 | ||
Because compromise ®
Drives: Red Herring
Edit Still deciding upon shopping list delete.
#191 |
Drives: GT-86
Personally i think the Stock LSD is good but even i with limited track experience i have gotten the inside wheel spinning at some points on track. If i could put down more power on corner exit im sure i would be faster. So if i was serious about track times this would be a definite consideration.
#193 |
Drives: Red Herring
Argggghhhhh!!!!
#194 |
Drives: GT-86
Explain the arrghhhh. As a newbie to trackdays I'm trying to maximize what I have now. Learn the car to its fullest, lap times (in and of themselves) aren't a priority.
Basically I'm trying to upgrade the driver first (that's me btw) before the car |
#195 |
Until the car is holding you back, just work on improving your skills. Driver mods are the most affordable and also most effective.
#196 |
Drives: GT-86
Agreed. That's the plan. The major thing I have done so far are pads and fluid as I exceeded the limits of the stock setup fairly early.
| The Following User Says Thank You to acro For This Useful Post: | wparsons (08-10-2014) |
| Tags |
| uberstupid |
| High-G Cornering Fueling Solution | EAGLE5 | Tracking / Autocross / HPDE / Drifting | 24 | 02-22-2017 09:04 PM |
| cornering-on-rails feeling | notout86 | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 09-20-2015 08:00 PM |
| Engine cutting power after hard cornering... | CSG Mike | Tracking / Autocross / HPDE / Drifting | 19 | 07-04-2015 09:40 AM |
| Traction control light comes even when not hard cornering? | Yamajee | Issues | Warranty | Recalls / TSB | 26 | 04-10-2014 02:04 PM |
| Anyone have the radio switching modes during hard cornering?? | silvercar | CANADA | 4 | 07-08-2013 01:49 PM |
