#141 | |
Drives: '23 BRZ
Street, track, autoX, drift? What's your suspension setup? (spring rates, sway bars, alignment settings) What tires are you running? Last edited by ZDan; 08-05-2014 at 10:21 AM. |
| The Following 2 Users Say Thank You to ZDan For This Useful Post: | Captain Snooze (08-05-2014), wparsons (08-05-2014) |
#142 |
#143 | |
Drives: EVO
Absolutely. I think? Not sure if we are thinking the same or not honestly. I'm making the argument that for performance applications with no regard to noise and maintenance, clutch type LSDs are superior in all cases simply because nobody races on perfect tracks. The perfect solution to an imperfect problem. However, I have a dispute with an idea used in your post. You say you decrease front (spring) rates. I feel you should be decreasing front roll stiffness, not implicitly spring rate. A spring rate change should be based on ride frequency, not roll stiffness. |
#144 | |
#145 |
Drives: EVO
Softer sway bars seems as/more feasible than spring rate changes?
I mention this as it's kind of the limiting factor to what ZDan is suggesting? Yes, you could soften the front spring rate and then add more lock up and end up in some endless cycle...but your front/rear ride rates are going to get so out of wack that it's going to stop you from pushing into some endless loop. |
#146 | |
Because compromise ®
Drives: Red Herring
Front toe 0, camber -3.62/-3.74, rear toe +0.9mm/+0.9mm, camber -2.85/-2.95. Kumho v710.
#147 | |
Drives: '23 BRZ
For sure you shouldn't consider the investment a "plug-and-play" deal. Go to school on how these custom diffs work before you invest $$$$ into one. If your car is pretty well developed and you like how it handles now, but feel you could get better drive out of corners, I would go with light preload, which will still clamp better than the Torsen with the inside wheel unloaded and won't upset balance as much as a tight clutch-type. |
| The Following User Says Thank You to ZDan For This Useful Post: | Captain Snooze (08-06-2014) |
#148 | |
#149 |
Drives: EVO
I guess I'm confused where you're going there. Buy softer springs or buy an adjustable swaybar? You're buying something either way to change the roll stiffness up front.
#150 | |
Drives: BRZ Pearl White
There is good information on this thread and some not so good. Have a look at F1: two very, very talented drivers, say Hamilton and Rosberg driving the same car (supposedly) on the same track on the same day. One day Hamilton is faster and the next Rosberg is faster. Change tracks and it all starts over. Conventionally you deal with the problem of getting the power down at the rear by stiffening front roll or softening rear roll. Or, you could tighten up the lsd but that may or may not work for you. One thing is for sure, the more power you have to deal with the more you bias roll resistance to the front axle, unless you are dealing with fwd or awd. For these cars for street use the Torsen is pretty good. To go faster on whatever tires you have chosen to run you should first fit better shocks, as Subaru/Toyota have just done for 2015. Next consider increasing front roll stiffness relative to the rear as these cars are tail happy from the factory, even the BRZ which is the tamest of the 3 settings released into the World markets. If you fit a clutch type lsd then be ready for some serious understeer under heavy power applications. Once that lsd locks up the chassis will push unless it is already well turned in. Too bad this isn't made for our cars, yet: http://www.wavetrac.net/technical.htm Torsen also makes one: the T2R which incorporates a clutch type pre-load slip limiting device within the Torsen diff. http://www.torsen.com/products/T-2R.htm One wonders why Toyota/Subaru didn't spec one.... |
#151 | |
Drives: Raven FR-S 6M
“The World is Flat”
[||•]=(86)=[•||] |
#152 | |
Drives: 2014 BRZ
It is quite popular for road racing GM and Ford race cars. I had one in a 2003 Mustang Cobra and it is an excellent hybrid of a Torsen and clutch LSD. However, it seems they are larger than would be appropriate for our cars. Plus, it is obviously more expensive than the Torsen and for 90% of the owners the Torsen is just fine; probably more like 95%.
#153 | |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#154 |
Drives: 2012 Toyota 86
Although mike dosnt realy need the support of a novice, i have to agree. Everytime ive gotten oversteer ive done something to cause it.
| The Following User Says Thank You to troek For This Useful Post: | CSG Mike (08-06-2014) |
| Tags |
| uberstupid |
| High-G Cornering Fueling Solution | EAGLE5 | Tracking / Autocross / HPDE / Drifting | 24 | 02-22-2017 09:04 PM |
| cornering-on-rails feeling | notout86 | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 09-20-2015 08:00 PM |
| Engine cutting power after hard cornering... | CSG Mike | Tracking / Autocross / HPDE / Drifting | 19 | 07-04-2015 09:40 AM |
| Traction control light comes even when not hard cornering? | Yamajee | Issues | Warranty | Recalls / TSB | 26 | 04-10-2014 02:04 PM |
| Anyone have the radio switching modes during hard cornering?? | silvercar | CANADA | 4 | 07-08-2013 01:49 PM |
