#225 |
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
Awesome, can't wait to start my build next year
#226 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
[ame="https://www.youtube.com/watch?v=iGG3fv6qvXE&nohtml5=False"]2JZ FRS Setup - YouTube[/ame]
| The Following User Says Thank You to slicktop For This Useful Post: | Pat.Thornton (04-13-2016) |
#227 |
You're like the...
Drives: '13 6MT FRS / '14 Ram 1500 Sport
#228 |
Drives: Series10 FRS 6MT
dang, I need a 2jz in my frs
3/18/14: '14 Firestorm Monogram FR-S 6spd-Sold
2/6/16:'13 SILVER IGNITION Series10#322 FR-S 6Spd-sold 5/12/18: ‘17 Toyota 86 6-spd |
#229 |
Drives: Asphalt frs
Looks so good in this car!!! Perfect match.
Sent from my SM-G935T using Tapatalk |
#230 |
Dyno numbers are in.
93 octane 18.5psi 565whp 435ftq This is my "pump" tune. I'm on a low boost setting of around 500whp/14psi now which is plenty for the street. Once the surge tank goes in, the E85 tune comes in. Hopefully sometime in June/July... we'll see!
| The Following 6 Users Say Thank You to slicktop For This Useful Post: | Draco_PR23 (04-20-2016), GTHachiRoku (04-15-2016), Pure Automotive (04-19-2016), R2RO (04-15-2016), Stigasaur (04-14-2016), Tectoniic (04-19-2016) |
#231 |
Drives:
#232 |
Just went to install my Pro-level DSS axles. They're sized incorrectly so I'll get a hold of them tomorrow morning. Bottom line is I won't be able to participate in the drag race event on Saturday.
For those wanting to get DSS pro-level axles, install them as soon as you can with plenty of lead time before your events. Aside from that, the car plants the power down well at speed. 1st gear is silly, 2nd can plant with warm tires and 3-6th are 100% WOT. The car hooks phenomenally and it isn't even dialed in yet. People saying this car can't do "X" don't know what they're talking about. It speaks volumes that this platform is now the fastest import platform in the world.
| The Following 2 Users Say Thank You to slicktop For This Useful Post: | civicdrivr (07-01-2016), Sportsguy83 (04-27-2016) |
#233 |
Ok, clarification on the DSS axles after looking at it again today.
I spoke with DSS and they mentioned that they've had some customers say they fit, some say they don't (in my particular case). The part I notched looked like it was casting inconsistency. What I mean by that is it looked like extra casting slag left over, which I ground down. It's all together and fixed. Just took it around the block with no issues.
#234 |
Welp, diff blew up at the track. Launched it at about 3500rpm, spun a little, shifted to second and as soon as boost hit, diff grenaded. This is the M85 diff out of an IS300. So it's not indestructible like people have led me to believe. Maybe I got a bunk unit, but see here:
![]() Pinion sheared off, rear mounting points sheared. All fucked up. I'll get better pics tomorrow morning. It's late and I've had a long fucking fucked up day.
| The Following User Says Thank You to slicktop For This Useful Post: | Sportsguy83 (04-27-2016) |
#235 | |
You're like the...
#236 |
Drives: 2JZ FRS
That's strange. I launch at 6800 and have been fine with the stock/m85 lol. Even with the LS on nitrous it held with 1.5 60fts
| The Following User Says Thank You to spitfire481 For This Useful Post: | Sportsguy83 (04-27-2016) |
#237 | |
I'm not following what you're trying to say. Can you rephrase it? Quote:
That's what nobody is getting. Mine didn't even shear on launch. It was probably a defective unit. I replaced with my OEM diff, it was extremely noisy so I thought I had broke it. Brought it home and flushed the diff with several bottles of cheap gear oil, put some Redline 75w90 in and it's quiet. The issue now is that that drivetrain is very noisy on deceleration, whether in gear or not. It is noisier in gear though...
#238 |
Just purchased two M85 differentials, Whiteline Diff bushings, and new hardware. Should be ready to go this weekend.
| The Following 3 Users Say Thank You to slicktop For This Useful Post: |
| Tags |
| 2jz, 2jz brz gt86 frs swap, 2jz frs, 2jz frs swap, 2jz swap |
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 08:52 PM |
| Mr and Mrs FR-S Build | jaydee_do_work | Member's Car Journals | 2 | 12-04-2013 10:51 AM |
| 86 BUILD, AUS | JS86JS | Member's Car Journals | 9 | 05-31-2013 09:59 AM |
| My build... well some of it | cruzinbill | Electronics | Audio | NAV | Infotainment | 41 | 04-01-2013 05:02 PM |
| STX build | Evil86 | Tracking / Autocross / HPDE / Drifting | 2 | 01-08-2013 04:40 PM |
