#29 | |
Drives: Currently 2018 Taco
BTW, I bath in motor oil. I smell funny. Women leave me. Gots to stay passionate about something. Last edited by viscositosis.rex; 07-05-2014 at 01:51 AM. |
#30 | |
#31 |
driving smoother faster
Drives: Sold
I tried fresh Motul 8100 0w20 on track. 256F peak oil temps with JR oil cooler and 86F ambient. Ordered European formula Castrol Edge 0w30 06244 to try next.
#32 | |
Thank you. I can never hear enough about group IV vs group III+. |
#33 | |
Drives: Sold
I will run Castrol during at least summer street/track months. Took recommendation from someone trusted who knows better. Might have been related to oil quality and oil pressure at track temps. Do you have constructive feedback that's easily understandable by an oil noob like me? Thx |
#34 | |
I personally like Red Line 20W racing oil. It is both thin and very stable. There is plenty of zinc. There are minimal detergent additives, which compete with anti-wear components. It would involve a changeout on track days. |
#35 | |
Drives: Sold
Great, thank you. I use redline in my lotus elise and love it. 62k miles on engine and runs as strong as new. I also like to change oil frequently, especially during warm/tracking months. Will stick with Castrol for now to see how it works out and do some oil analysis. I read somewhere that zinc is a bit overrated, though redline doesn't use too much to affect cats, your thoughts on that? It gets pretty cold during the winter in tri-state area so will stick with 0w oil at least during winter months. Euro Castrol might be a good fit year-round if it holds up as well as it should. Also, your thoughts on low FA20 pressures at high load and using 0w30 to help a little? Much appreciate your insights. |
#36 |
#37 |
#38 |
j/k...zinc is underrated. Many people ignore warranty issues regarding oil ratings. They are more concerned with wear than cat poisoning. Your Belgian Castrol is an SL oil.
Royal Purple HPS 5W20, Amsoil Dominator 5W20, and Quaker State Defy 5W20 are favorites of mine. I can't comment on the issue you raised on low oil pressure/high load w/the FA20. You are right to be concerned about this issue. I don't have the knowledge base to comment. Well, Belgian Castrol 0W30 should serve you nicely in upstate New York. Mobil 1 0W40 is off the charts in cold weather capabilities. |
| The Following User Says Thank You to viscositosis.rex For This Useful Post: | dp1 (07-11-2014) |
#39 |
Drives: Limited Dark Gery Metallic BRZ
You do mean to not change it for aroung 10k but occasionally topping it off right? I found once that I didn't change it for around 10k once accidentally and found that the car was lower than minimum by then. Using OEM oil by the dealership's service. Thank you beforehand.
#40 | |
#41 | |
It's the phosphorus (the P in ZDDP) that is bad for cats, but the levels in Red Line street oil aren't bad unless you're burning a lot of oil. -Dennis |
#42 | |
Drives: Sold
Thanks for your feedback. Not sure if it's the new tune by Mike @moto-mike, or Castrol, or a combination, but my engine runs very strong and smooth now, oil temps are lower and I no longer have black exhaust tips and tiny black dots all over the rear of my car. I was planning to switch to 0w20 before the winter. Last edited by dp1; 07-17-2014 at 10:40 AM. |
| Eneos sustina oil question!! | cooldandani | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 27 | 08-25-2014 06:11 PM |
| ENEOS SUSTINA 0W20 MOTUL GEAR 300 | DAN_BRZ | Canada Classifieds | 4 | 05-12-2014 08:03 PM |
| Eneos SUSTINA 0W20 - Introductory Pricing | AlphaMotorsports.ca | CANADIAN Sales | 0 | 04-24-2014 05:43 PM |
| Eneos sustina oil. Where to? | tintumz22 | Northern California | 5 | 04-20-2014 02:38 PM |
| eneos sustina | 20valvewynn83 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 01-04-2013 10:43 PM |
